Serametin Neutral Newbie March 7, 2008 Share March 7, 2008 usually during starting of engine, my car's idling rpm is about 700. but recently, i found out that it is 1000 rpm. any reason for that? ↡ Advertisement Link to post Share on other sites More sharing options...
Contax 1st Gear March 7, 2008 Share March 7, 2008 you did any mod recently? aircon on or off ? Link to post Share on other sites More sharing options...
Serametin Neutral Newbie March 7, 2008 Author Share March 7, 2008 no mod and the air con is switch on only after the engine have started. Link to post Share on other sites More sharing options...
Showtime Neutral Newbie March 7, 2008 Share March 7, 2008 does it idle normally after the engine warms up? cars do idle slightly higher when the engine is cold. Link to post Share on other sites More sharing options...
Serametin Neutral Newbie March 7, 2008 Author Share March 7, 2008 ic... maybe that is the reason. cos after the car warmed up, the idle rpm drop down to 700 Link to post Share on other sites More sharing options...
Kklee 6th Gear March 7, 2008 Share March 7, 2008 Maybe it's the air filter... when was it last changed? Link to post Share on other sites More sharing options...
Silver_z 1st Gear March 7, 2008 Share March 7, 2008 That is definitely the reason. 1st time car owner? Link to post Share on other sites More sharing options...
Serametin Neutral Newbie March 7, 2008 Author Share March 7, 2008 yup Link to post Share on other sites More sharing options...
Silver_z 1st Gear March 7, 2008 Share March 7, 2008 Congrats!! Link to post Share on other sites More sharing options...
Contax 1st Gear March 7, 2008 Share March 7, 2008 then probably like what the bro above have said : it's a feature from the car mgmt system . Link to post Share on other sites More sharing options...
Zxcvb Turbocharged March 8, 2008 Share March 8, 2008 It's normal. Nowadays most cars have auto warm-up while starting the car with a cold engine. This is so that the engine can reach the optimum operating temperature. Once it reached the operating temperature, the rpm will drop to normal idling. So no worries, unless it remains high thru-out the entire journey. Link to post Share on other sites More sharing options...
Aimnfire 4th Gear April 13, 2010 Share April 13, 2010 sorry to dig this thread but this morning when i use remote start to start the car from my home. then sent my daughter to her school which is just directly under my block. after that when to proceed to the multi storey carpark to get my car. as i nearing the carpark, i heard a loud engine sound. to my surprise it was my car. i open the door and check that the rpm is at 6k. i quickly swicth off the engine. open the engine bay and my extractor was glowing red! i switch on the engine this time round the rpm is at 3k, switch on the aircon it drop to 2k. so drive slowly down. about 4 to 5 traffic light later, the rpm stabilise as normal at 0.8k. so anyone of you knew what is the probable cause as i do not wish to go to workshop and being chop. btw driving kia cerato fro 4.5 years and milage is 130k. so far it occur 5 times ever since collect the car from day 1. twice when the car still under warranty and inform the agent who claim nothing is wrong. thanks. Link to post Share on other sites More sharing options...
Aimnfire 4th Gear April 13, 2010 Share April 13, 2010 btw way, it is not only when cold start give me this problem. even when the car is restart after long journey it will give this problem too. Link to post Share on other sites More sharing options...
Silver_blade Turbocharged April 13, 2010 Share April 13, 2010 Maybe your ECU need to be reprogrammed/reflashed or the remote start system could be the root of the problem. Link to post Share on other sites More sharing options...
Aimnfire 4th Gear April 13, 2010 Share April 13, 2010 Maybe your ECU need to be reprogrammed/reflashed or the remote start system could be the root of the problem. hi bro thanks for the reply. i suspect my alarm got short as my rear right signal light not working. went to replace the bulb but when the mechanic help me to install he found out that my remote start might have problem that cause no supply to the signal light. but for the high rpm, how does remote start be the root of the problem? cause it even i start manually, it still give me high rpm? Link to post Share on other sites More sharing options...
Hondauto 1st Gear April 13, 2010 Share April 13, 2010 hi bro thanks for the reply. i suspect my alarm got short as my rear right signal light not working. went to replace the bulb but when the mechanic help me to install he found out that my remote start might have problem that cause no supply to the signal light. but for the high rpm, how does remote start be the root of the problem? cause it even i start manually, it still give me high rpm? U need to be careful with alarm with remote start function - wrong wiring could lead to several damages. I suggest to re-check on the wiring or go to a qualified wire man to re-wire the alarm. Link to post Share on other sites More sharing options...
Dwoon 1st Gear April 13, 2010 Share April 13, 2010 Dirty throttle position sensor??? Link to post Share on other sites More sharing options...
Chiangauto Clutched April 13, 2010 Share April 13, 2010 sound like Vacuum leaks. please Check all hoses and intake bolts. it maybe leaking EGR or plugged PCV valve. Air filter plugged. Leaking head gasket. Worn timing chain. Camshaft lobes worn. Valves burned or leaking. Fuel idle control system or sensor.Suggest you send to workshop for checking. ↡ Advertisement Link to post Share on other sites More sharing options...
Are You A Big Spender For A High End Bed Mattress?
ACS boy dies during high adventure course
High-rise littering
High-rise littering
HSA recalls 3 brands of high blood pressure drugs
How to tell if someone is high or low class?
High mercury fish to avoid
Would you buy a high mileage E200K (W211) ?
