Portable generator
Albert77
Does any bro here have some feedback on the meguirs machine? Is it comparable to PC? Thanks a lot... ...
Bro Benny,
I'am looking for a friendly-user polishing machine, can you recommend one to me?
Hi,
anyone gotten a PC and portable generator?
Im keen in getting one for myself. would like to know if portable generator give enough power for the porter cable.
Bro Benny,
The easiest one will be PC7424..Good for newbie..Has the ability to remove small defects..Only you need a step down transformer...Recently Latioboy got 1 for himself..I just teach him once and he knows how to use it..Very easy to use and will not damage paint.(correct pads for polishes)
Hi,
A 600watt portable Gen set will be more than enough to run a Portable cable..PC is ard 450watt..
the price for 600watt gen set is slightly less than $200 if i remember correctly...
Edited by Maddriver
Hi,
I am using a Tiger 650watts portable generator to power my PC
The generator is a 2 stroke engine, runs on petrol and require 2T
Noise level and exhuast level is acceptable
Size is about a 12" 1Cu feet woofer box
Weigh bout 10kg fully loaded with petrol (3 litre)
3 litre of petrol allow me to use it for around 6hrs.
Bought it at Kelantan for $185
Thank you!
Could i know where is Kelantan?
Do you still need the step down transformer for the PC?
Thank you!
Yes you need. Can get from HomeFix, remember to get correct wattage . . . . mine is 500W for my PC.
Kelantan Lane is near Sim Lim Tower area I think . . . .
Edited by Vroomtattat
Thank you!
Thank you!
Yes, a step down transformer is still needed if you are using a PC with the generator
eh.. running off main socket also need step down transformer. Just take note safer for Gen set got to have 2-3 times more wattage for your tools since it need the extra surge to power.
i just brought a 950 watts portable generator from a hardware shop at eunos industrial,ave 6 blk 1078,name of shop is sin ma hup kee. it runs on petrol mix with 2t oil...u can go take a look,i use it for polishing my car,so far its serving me very well.
Bro are those portable generator very noisy,in ten to buy one n used it in the mscp
Yes homefix should have it..Is a rechargeable batt generator.. some ppl uses it for camping..5 to 6hrs usage should be no problem..do a check first on your PC hp..
Has anyone bought similar battery generator to operate your DA. Can share your experience. I did some reading and not sure if it's correct. If powering our DA, the generator don't have sufficient power to go on for hours.
i'm interested in portable generator and gonna buy that....
we can use it anywhere and any time
somebody can say how to use this...
