Limws1 1st Gear June 4, 2003 Share June 4, 2003 Hi, I got two exhaust modification options from two shops: 1. Change to hotbits centre box Replace pipe starting from flexible joint from original 1.5" to 1.6" Operate on stock muffler 2. Change to hotbits 4-2-1 extractor (Cat removed) Keep stock pipe Change to hotbits muffler Option two will require visit to workshop yearly before inspection. You'll know what I mean. So which option is better and which option is louder. Don't want to attract white ants. Price wise, it's about the same. I'm driving Accent 1.5 manual ↡ Advertisement Link to post Share on other sites More sharing options...
Gadgeter 2nd Gear June 4, 2003 Share June 4, 2003 I'll go for Option 2. You can use those not-so-noisy muffler. Link to post Share on other sites More sharing options...
Limws1 1st Gear June 4, 2003 Author Share June 4, 2003 Will changing to 4-2-1 extractor generate a lot of noise? Link to post Share on other sites More sharing options...
Gadgeter 2nd Gear June 4, 2003 Share June 4, 2003 Nope... it wun... Link to post Share on other sites More sharing options...
Limws1 1st Gear June 4, 2003 Author Share June 4, 2003 sorry to ask so many questions, but what will be the adverse effect if the cat is removed. Will there be a bad smell from the exhaust? Link to post Share on other sites More sharing options...
Gadgeter 2nd Gear June 4, 2003 Share June 4, 2003 When remove Cat, there will be some slighty smell from exhaust. But most important of all, you might fail the CO2 test when you go for inspection. Link to post Share on other sites More sharing options...
E36UDM Neutral Newbie June 4, 2003 Share June 4, 2003 (edited) I would choose option 1 which is cheaper right? Dun remove your meow, you will lose the low end torque Yes smell will be stronger but not necessary fail inspection also Edited June 4, 2003 by E36UDM Link to post Share on other sites More sharing options...
Limws1 1st Gear June 4, 2003 Author Share June 4, 2003 Actually, option 1 is more expensive. Maybe its the workshop pricing that is high. Link to post Share on other sites More sharing options...
E36UDM Neutral Newbie June 4, 2003 Share June 4, 2003 actually just operate muffler good enough my 2 cents Link to post Share on other sites More sharing options...
Hktan Neutral Newbie June 4, 2003 Share June 4, 2003 I think opiton 1 also need to visit workshop before inspection. Not too sure. Anyone? Option 1 also illegal? Inspection how? Link to post Share on other sites More sharing options...
Saaber Neutral Newbie June 4, 2003 Share June 4, 2003 Take option 2 lah... and keep your original manifold and muffler.... Link to post Share on other sites More sharing options...
Limws1 1st Gear June 4, 2003 Author Share June 4, 2003 Dun quite understand. If take option 2 means changing manifold and muffler, why you say keep them? Link to post Share on other sites More sharing options...
Saaber Neutral Newbie June 4, 2003 Share June 4, 2003 keep the original one in case you need to revert back to original when you sell car mah... Link to post Share on other sites More sharing options...
Hkfung Neutral Newbie June 4, 2003 Share June 4, 2003 Will changing to 4-2-1 extractor generate a lot of noise? depends on the muffler. there will be increase exhaust pressure to the muffler, during certain RPM (3-4K), u may hear knocking metal sounds. Link to post Share on other sites More sharing options...
Hkfung Neutral Newbie June 4, 2003 Share June 4, 2003 u drive manual or auto ? change extractor and upgrade to a better muffler. if can decat, even better the centre box dun really makes a diff. u got any workshop in mind for this ? Link to post Share on other sites More sharing options...
Duadua2 Neutral Newbie June 4, 2003 Share June 4, 2003 how much they quoting u? Link to post Share on other sites More sharing options...
Limws1 1st Gear June 4, 2003 Author Share June 4, 2003 Driving manual. I dun know is it because of my ride or what, when changing to extractor, the cat has to be removed. I'm also worried about removing cat. Is there a way to change extractor without removing cat? The stock cat is just after the stock exhaust manifold in the engine compartment. I've PM you about the workshops. Link to post Share on other sites More sharing options...
Mel4fun Neutral Newbie June 4, 2003 Share June 4, 2003 Hi LIMWS1, May I ask what is your ride ?? IMHO, taking out the Meow has it's pros and cons :- Pros - Less restrictive and better pull in between gears, good for manual car Cons - May have some smell during early morning startup, not environmentaly friendly and not white ants friendly too It really depends what type of replacement Meow are you putting on, and I know there are cases where it won't required to take in/out for those annual exercise As for the extractor, heard that 4-2-1 is pretty good for torque and drivability. Never install before but can always get more advise from other pals in MCF Cheers ↡ Advertisement Link to post Share on other sites More sharing options...
Advice on exhaust.
Advice on exhaust.
Need Advice on Self Storage
WTB wagon - seeking opinion
