Chucky2007 Turbocharged February 25, 2008 Share February 25, 2008 (edited) Hi guys, need some advice here. My current tyre is 205/45r16, thinking of changing to a slightly thinner tyre for a little better pickup as well as some FC saving. But thicker sidewall for more comfort as i personally feel 45profile tyre is too hard (now already pump down to 200kpa).. if i go for a thicker sidewall, at least i can pump up to 220-230kpa with the same effect. i am thinking of 195/55r16. is there such tyre profile around in singapore? personally i've seen 205/55r16, 215/55r16 but not yet 195/55r16. please advise... thanks.. Edited February 25, 2008 by Chucky2007 ↡ Advertisement Link to post Share on other sites More sharing options...
Rickster 5th Gear February 25, 2008 Share February 25, 2008 195/45r16 should be available. Though might not be 55 thick, but at least, the thinner tyre width at 195 should reduce FC and improve pickup a little. Link to post Share on other sites More sharing options...
Chucky2007 Turbocharged February 25, 2008 Author Share February 25, 2008 195/45 is a little too thin, sets back my over tyre profile, sidewall thinner than 205/45.. good for fc but will be quite stiff. Link to post Share on other sites More sharing options...
Ahdi Neutral Newbie February 25, 2008 Share February 25, 2008 195/50R16 is good. depends on the size of ur rim. 16" x 7JJ using 195/50 shld be fine. Link to post Share on other sites More sharing options...
Kyojin 1st Gear February 25, 2008 Share February 25, 2008 not advisable, the difference in diameter based on ur current size and 195/55-16 is more than 4%. it will increase your chance of brake failure. u may wish to consider 195/50-16, which is less than 2% difference. Link to post Share on other sites More sharing options...
Chucky2007 Turbocharged March 1, 2008 Author Share March 1, 2008 thanks all for the advice! ↡ Advertisement Link to post Share on other sites More sharing options...
Wheel Spacer Installation DIY
Wheel Spacer, where to buy?
Wheel Hubs
Wheel Hubs
Paddle shifters - fixed to wheel or column?
Wheel spacers - the real truth...
Steering wheel off centered from seat.
TSW wheel vs OZ hlt
TSW wheel vs OZ hlt
