Jkcs Neutral Newbie February 20, 2008 Share February 20, 2008 http://www.rev-1.com.sg/energy.htm Hi, can give comments on this brand of EO? Kimchi ride suitable to use? Thanks ya. ↡ Advertisement Link to post Share on other sites More sharing options...
Subzro Neutral Newbie February 20, 2008 Share February 20, 2008 Bro, I suggest u stick to more reputable brands IMHO.... Link to post Share on other sites More sharing options...
Glyuen 3rd Gear February 25, 2008 Share February 25, 2008 how much does it cost? TBN a little low i think. Link to post Share on other sites More sharing options...
Chucky2007 Turbocharged February 25, 2008 Share February 25, 2008 (edited) if 4L of Rev1 cost around S$30-$40, can try.. but dun think it will last long as TBN is low at 7 leh.. the Amsoil i am using is around $60 for near 4litre.. but specs wise is much better. https://www.amsoil.com/storefront/asl.aspx if it cost anything more than S$45... forget about it. Edited February 25, 2008 by Chucky2007 Link to post Share on other sites More sharing options...
Muchie Neutral Newbie February 26, 2008 Share February 26, 2008 Just to check does that mean Schaeffer 9k 5w30 also not as good? I have checked, the TBN is 7.1 only... Link to post Share on other sites More sharing options...
Trex101 3rd Gear February 26, 2008 Share February 26, 2008 TBN is the amount indication of acid fighting additives but does not necessary means that the higher the TBN the longer the oil can last. It's the TBN depletion rate that matters, Schaeffer is known to have very low depletion rate thus TBN 7 can usually last more than 10k miles (16k km) at least. Do a UOA search in BITOG, there's alot of Schaeffer samples that last more than 10k miles. Link to post Share on other sites More sharing options...
Ferrari7 Neutral Newbie February 26, 2008 Share February 26, 2008 Yes. Fully agree with Trex on TBN depletion rate. Link to post Share on other sites More sharing options...
Jkcs Neutral Newbie February 29, 2008 Author Share February 29, 2008 i dunno the cost as this EO is one of the oil used by a workshop. ↡ Advertisement Link to post Share on other sites More sharing options...
Energy Savings / Non Heat up LED Headlights Technology
Sun cable. Solar energy from australia
Energy Saving - Never turn on headlamp
Mileage 110k, Should use 5W30 or 5W40
5W30 or 5W40 Engine Oil Is Better For Your Car?
Planet of the Humans
5w30 vs 5w40
5w30 vs 5w40
