Vvix 1st Gear February 18, 2008 Share February 18, 2008 Hi bros, I wash my car almost every week, some times with car shampoo, others just with plain water. Over the years, the wipers seem to cause dirt to accumulate on the windscreen. Lines of stubborn dirt can be found on the windscreen where the wipers are resting during inactivity and at the extreme position where the wipers would be able to turn to (see the green lines on the picture). Any ideas to clean away the dirt? Use mama lemon? Real lemon fruit juice? thinner? vinegar? lighter fluid? ↡ Advertisement Link to post Share on other sites More sharing options...
Ken_leong 2nd Gear February 18, 2008 Share February 18, 2008 Find MD and get #755. It should be able to do the job. Link to post Share on other sites More sharing options...
Fitzy Neutral Newbie February 19, 2008 Share February 19, 2008 (edited) The stains are already etched to the windsreen, you can try machine polishing the windscreen to remove the stain. Try checking this out - http://eglass.bravehost.com Edited February 19, 2008 by Fitzy Link to post Share on other sites More sharing options...
Rskeisuke Clutched February 19, 2008 Share February 19, 2008 i got the same thing too! will isopropyl alcohol work? Link to post Share on other sites More sharing options...
Imamiah Clutched February 19, 2008 Share February 19, 2008 previously when i notice water marks on wind screen, i use 2 parts water n 1 part cooking vinegar to wash. did help a little Link to post Share on other sites More sharing options...
Circuit Clutched February 19, 2008 Share February 19, 2008 cheapest way... use the 3M (sandpaper for windscrn) - can get at autobacs or stamdford. think less than 3 buck... if i can rem. and use soap water. to cheap. all dirt is scrub off without hurting scrn. ↡ Advertisement Link to post Share on other sites More sharing options...
Dirt cheap storage space.. recommendations?
how to remove micro/fine scratches on windscreen
Clean car seat belt
Clean car seat belt
Best water repellent
Windscreen crack
Windscreen crack
