Freakman Neutral Newbie January 30, 2008 Share January 30, 2008 What's the difference between these 2?? i notice that my car 'idling' will drop after certain period, and have to tune up the idling point a bit inorder to maintain the same rpm, else it will be too low and it will vibrate too much...and also once the rpm drop below 1K, the fan vibration sound will be heard(mostly at night when headlight is on)... i am driving an old swife, with 3 piston engine. i know it will vibrate but sometime the idling needle will drop to near dead and suddenly jump back again... this is especially so when traffic jam. for info: engine mounting changed, throttle body not in good condition (as told by mechanic), spark plug new, aircon compressor changed, hmmm what else?? cant remember also. Any good ideas?? ↡ Advertisement Link to post Share on other sites More sharing options...
Wry85 Neutral Newbie January 30, 2008 Share January 30, 2008 My old marchie also lidat, got used to it liao. Just tap the accelerator if it really vibrate until very jialat. Engine retune is able to this problem but it will come back after a short while. Link to post Share on other sites More sharing options...
Dynaway 1st Gear January 30, 2008 Share January 30, 2008 buy a carb cleaner n spray clean ur throttle body.... other possiblities include worn shaft/lobe in the distributor, can cause iradict idling. idling is talking abt the engine rev at idle mode(non-load & non-working) timing is talking abt the ignition firing degree... either advance or retard, adjusted via turning the distributor housing. u will need a timing gun to get a precise timing adjustment. Link to post Share on other sites More sharing options...
Freakman Neutral Newbie January 31, 2008 Author Share January 31, 2008 no need leh.. i saw my mech only use spanner adjusting somewhere near the engine compartment there and can feel the 'breathing' of the engine sound more stable leh... as for my throttle body..i get it clean up frequently leh... now got somemore problem, my idling can drop to near 0 (dead) but able to bounch back to normal rpm 1.1K, this is esp when in stopping at traffic light... Link to post Share on other sites More sharing options...
Dynaway 1st Gear January 31, 2008 Share January 31, 2008 check ur vaccum hoses..... if harden, replace them, ur Idle control for Aircon may be leaking or out of tune ur mech is probably adjusting the idling screw... Link to post Share on other sites More sharing options...
Freakman Neutral Newbie January 31, 2008 Author Share January 31, 2008 ok thanks bro... ya my mech did always adjust the idle nuts.... i will get him to check the rest of the item.. ↡ Advertisement Link to post Share on other sites More sharing options...
Income tax Evasion
Income tax Evasion
Disputes between neighbours - A True story
Whats's the difference between rubbing compound and polishing compound?
Between Hyundai Elantra and Toyota Altis.....
What is the difference between Honda civic FD1 & FD2
Nets cards - what's the difference
Changing of water pump and timing belt.
Carburetor (or Carburettor if UK) servicing, what a difference!
