Alvinchua1975 Neutral Newbie January 29, 2008 Share January 29, 2008 as above? I intend to insualte the stock air filter box so that it won't be easily heated up by the engine bay. Any recommendations what materials, and what to get and the cost as well? ↡ Advertisement Link to post Share on other sites More sharing options...
Kb27 Supersonic January 29, 2008 Share January 29, 2008 Go to North East Refrigeration at 35 Ubi Crescent and buy Armaflex sheet. Then glue over the air box. But seriously, you don't need to worry about the air heating up inside. It moves so fast, it doesn't have time to stay inside and get warmed up. Link to post Share on other sites More sharing options...
Alvinchua1975 Neutral Newbie January 29, 2008 Author Share January 29, 2008 oh is it? so why do people do that anyway? thought can protect the heat from radiating into the air box? Link to post Share on other sites More sharing options...
Sickscientist Clutched January 29, 2008 Share January 29, 2008 Unless ur car is stationary most of the time, u no need to insulate the air box... Just do a CAI can alrdy.. Link to post Share on other sites More sharing options...
Apollo 1st Gear January 29, 2008 Share January 29, 2008 i think lah is lidat... bigger space for bay = lower suction head/ pressure . restricting to one section not necce is good unless it is totally leakproof. if it is not then pressure differential will force heat into the lower pressure region, heat flow in and get trapped inside the very place u wanna to prevent. Link to post Share on other sites More sharing options...
Alvinchua1975 Neutral Newbie February 19, 2008 Author Share February 19, 2008 so what u saying is unless i seal it all the way from the CAI tube to the air filter box then it will be effective? Link to post Share on other sites More sharing options...
Kklee 6th Gear February 19, 2008 Share February 19, 2008 Any price indication? Link to post Share on other sites More sharing options...
Kb27 Supersonic February 19, 2008 Share February 19, 2008 Depends on the thickness, Armaflex average about $15 per meter (x 1.5m width) Link to post Share on other sites More sharing options...
Kklee 6th Gear February 19, 2008 Share February 19, 2008 Thanks, will check it out. Link to post Share on other sites More sharing options...
Kb27 Supersonic February 19, 2008 Share February 19, 2008 No problem I frequent that place since I do a lot of diy soundproofing Link to post Share on other sites More sharing options...
Koxxic Neutral Newbie February 21, 2008 Share February 21, 2008 u can try owen road...there's one shop selling such material also Link to post Share on other sites More sharing options...
Ogima Neutral Newbie February 21, 2008 Share February 21, 2008 Link to post Share on other sites More sharing options...
Ogima Neutral Newbie February 21, 2008 Share February 21, 2008 sorry, need to borrow this thread cause not authorize to start new ones. any idea where to get the heat reject wrap that goes around the battery in the hot engine bay ? understand that this helps to minimize the possibilty of battery bulging due to heat. thanks in advance. Link to post Share on other sites More sharing options...
Yeobh 4th Gear February 21, 2008 Share February 21, 2008 (edited) You may end up with more heat problem - hot air will get trap inside the warpping. Best is to get more air to circulated pass the battery. Edited February 21, 2008 by Yeobh ↡ Advertisement Link to post Share on other sites More sharing options...
Where you cut your hair?
NBA - Where Amazing Happens
Upgrading stock horn
