Kelpie 2nd Gear January 20, 2008 Share January 20, 2008 1. Based on my preliminary understanding on wheel alignment, there are 3 areas to be alignmed, i.e. toe, castor and camber. a) Toe - increase in toe-in will typically reduce over-steer and toe-out to reduce under-steer. RWD tend to toe-in to benefit its rearward movement. FWD usually have slight toe-out to improve handling. b) Caster - for adjusting forward and rearward wheel position. Increaseing forward usually improve steering effort, straight line, high speed and cornering. c) Camber - to alter the angle of the wheel relative to a vertical line. Lowered car usually result in a negative camber angle, hence require aftermarket camber kits to adjust the angle. A lowered car without camber kit may have its tyre sidewall wear out faster and thus loose grip. 2. So to optimise handling, for FWD, slight toe-out and forwarding castet should improve handling. So what sort of adjustment in turn of degree do you guys go for? or no one actually bother about this . Regards, Regards, ↡ Advertisement Link to post Share on other sites More sharing options...
Qr25vet Clutched January 20, 2008 Share January 20, 2008 never toe out....u'll struggle to keep your car in a straight line...i'd rather to that in the rear to indice oversteer postitive caster is good....camber...always go for negative camber... Link to post Share on other sites More sharing options...
Kelpie 2nd Gear January 20, 2008 Author Share January 20, 2008 Usually variance is low, between +/- 5 degree. The only way to find out the optimized configuration is to check the alignment as soon as one gotten a new stock car. Who knows, slight degree of toe-out is already part of the factory default. Regards, Link to post Share on other sites More sharing options...
Sky_vinz Clutched May 8, 2009 Share May 8, 2009 Anyone to share their front and rear camber angles? ↡ Advertisement Link to post Share on other sites More sharing options...
Wheel bolts and Wheel spacer
Wheel Spacer Installation DIY
Wheel Spacer, where to buy?
Wheel Hubs
Wheel Hubs
Paddle shifters - fixed to wheel or column?
Planetary alignment
Planetary alignment
Wheel spacers - the real truth...
