Subwoofer to perform in small box 5.5 cubic feet only?
Danzdanz
hi people....
any idea which sub can perform in 5.5 cubic feet of space enclosure?
wat size of subwoofer is suitable?
5.5 is alot of space.
Used to run 4x10" Rockford Fosgate Pro Series SPP104 in a ported 4.2 customed box, tuned to 40hz.
That was when i was younger and crazy enough to do that, at the expense of boot space
[laugh][laugh][laugh][laugh][laugh]
Edited by Redliner_sg
[laugh][laugh][laugh][laugh][laugh][laugh][laugh][laugh][laugh][laugh][laugh][laugh][laugh][laugh][laugh][laugh]
Thats a good one!!!!!!!!
Anyway, you could get by with a single sealed 10" i think, but that will be the bare minimum for it, and bigger will definately play better.
Might be better off sounding with a sealed 8" without the extension.
Hope this helps and lemme go continue laughing again
ya i know.... [lipsrsealed]
anyway i really have a hard time man....
thanks for advice..... but i think 8" is out....
wat long excursion 8" are around anyway ?
If you can squeeze 0.66 cu/feet,
you can get the 10" Kicker Solobaric in a sealed box
Otherwise, 8" Kicker Solobaric in a sealed box will be more make it for 0.55 cu/feet
Hope this helps
actually been doing some research and settled for a diamond cm3 10 inch
works with 0.5
heheheh....
Where did you get the Diamond cm3 from and what is the rated rms? I am also looking for a woofer that can squeeze into the smallest sealed box.
Thanks
If you have already bought your sub, well and good. But just in case you have not, you could also consider the Boston Pro 10.5LF sub. High quality bass from a 0.5 cu ft box.
Is there any other woofer that can fit into a 0.5 cu ft box?
My amp rated at 280 rms.
Thanks
Edited by Msck
