Carlover76 Neutral Newbie January 5, 2008 Share January 5, 2008 Guys, I understand some of you have put the Thirsty Hippo in your car to absorb the moisture in the car, may I check with you where you put it? Inside Glovebox or cabin? Care to advise me, thanks. ↡ Advertisement Link to post Share on other sites More sharing options...
Hamburger Hypersonic January 5, 2008 Share January 5, 2008 enclosed car cabin is very dry n low in humidity unless air con h2o leaks in ur cabin. Link to post Share on other sites More sharing options...
Carlover76 Neutral Newbie January 5, 2008 Author Share January 5, 2008 I was told that putting the Thirsty Hippo in the glove box can help to absorb the moisture from the air-con system, is that true? Link to post Share on other sites More sharing options...
Apollo 1st Gear January 5, 2008 Share January 5, 2008 open door, close door. outside air comes in... how deep is ur wallet? Link to post Share on other sites More sharing options...
Carlover76 Neutral Newbie January 5, 2008 Author Share January 5, 2008 What do you mean wallet? You mean the panel on the door? Quite deep. Link to post Share on other sites More sharing options...
Adawang 1st Gear January 5, 2008 Share January 5, 2008 Hippo put in wallet??? kekekekeke Link to post Share on other sites More sharing options...
Application9999 Clutched January 5, 2008 Share January 5, 2008 friend...'how deep is your wallet''...meaning how much money u prepare to spend on this Hippo thingy...Once car door open, outside air come in...full of moisture...how many hippo u need to use and how much u can spend? Link to post Share on other sites More sharing options...
Fcw75 Hypersonic January 5, 2008 Share January 5, 2008 I put it at the centre console, where I can stuff it in. Good stuff, can last me abt 2 mths b4 it becomes full. You will be surprised at the amount of water collected. Link to post Share on other sites More sharing options...
Leech Clutched January 5, 2008 Share January 5, 2008 Guys, I understand some of you have put the Thirsty Hippo in your car to absorb the moisture in the car, may I check with you where you put it? Inside Glovebox or cabin? Care to advise me, thanks. Hi, buy a packet of charcoal. Will do the trick liao lah... afterwards can also use for BBQ ! Link to post Share on other sites More sharing options...
Ttpowertt Clutched January 5, 2008 Share January 5, 2008 Hi, I bought a pouch big enough to contain the Thirsty Hippo at Stamford Tyre and hang it behind the drive seat. I dont use Thristy Hippo, too expensive, I use another brand call Clever Camel 2, it's Cheaper. Cost about $1.60 to $2.00 for a pack of two. Sheng Siong got sell. Link to post Share on other sites More sharing options...
Rev2redline Neutral Newbie January 5, 2008 Share January 5, 2008 Best is put it somewhere that is not easily seen... Maybe under the front seats... Glove box is okay unless you have a lot of stuff in it... In the boot is also good... Maybe place it in the cabin and in the boot... And remember to secure it so it doesn't move around... i'm sure you dun want that container with water to be sliding around in your car when u drive.. worse still, spill the sticky water onto the carpet in your cabin... Link to post Share on other sites More sharing options...
Rev2redline Neutral Newbie January 5, 2008 Share January 5, 2008 Though it may be dry and low in humidity, it may still be quite damp especially due to the carpet in the cabin.. it may create a musky smell in your cabin if the cabin is quite humid.. Link to post Share on other sites More sharing options...
Rev2redline Neutral Newbie January 5, 2008 Share January 5, 2008 The air con system actually dehumidify the cabin... Unless you leave it in the fresh air mode.. cos in singapore, our air is quite humid... unless other non - tropical countries... The Humidity is intoduced when u open the door or wind down the window and introduce fresh air into the cabin... in this case, it'll help to reduce the humidity in the cabin.. Link to post Share on other sites More sharing options...
Rev2redline Neutral Newbie January 5, 2008 Share January 5, 2008 Opening and closing the door can't be helped... But the thristy hippo will help to reduce the moisture content in the cabin... If the cabin is kept dry, it will prevent odour especially the musky smell from take away food, market stuff, shoes, etc... By the way, the thirsty hippo can last about a month or two... And it's not that expensive... some pple may spend more on the perfume/ ionizer for their ride... Link to post Share on other sites More sharing options...
Zakuii 1st Gear January 6, 2008 Share January 6, 2008 yup, i've a pack of charcoal under my seat as well. Link to post Share on other sites More sharing options...
Carlover76 Neutral Newbie January 6, 2008 Author Share January 6, 2008 Thanks for your reply, currently I have put it in the glove box but just wonder will it be effective cos it is like enclosed area. I have also put a packet of bamboo charcoal under driver's seat and the boot area, so far no bad odour. Link to post Share on other sites More sharing options...
Apollo 1st Gear January 6, 2008 Share January 6, 2008 musky smell can b removed by air ioniser. Link to post Share on other sites More sharing options...
Cplaw Neutral Newbie January 27, 2008 Share January 27, 2008 I brought this bamboo charcoal at Esso Mobil @ $8.90 ↡ Advertisement Link to post Share on other sites More sharing options...
Where to mod fuel needle?
Where to get those plastics that allow your to stick the road tax/decal on screen
Wheel Spacer, where to buy?
Where you cut your hair?
Going to Batam. Where to park overnight ?
NBA - Where Amazing Happens
