Emils 2nd Gear January 1, 2008 Share January 1, 2008 Hi Bros, Today, after driving thru the rain, I parked the car at a shopping centre. After about 2 hrs, when I drove off, I start to notice this squealing sound while the car is moving. It seems to be coming from the front wheels/engine region. The sound stops as soon as the car stops. I got down to check to see if it was due to air leaking out from a punctured tyre but it doesn't seem like the case. Could see anything stuck on the wheel region that could have caused the sound while the car is moving too. Was told that the sound cld be due to a wet transmission belt and it cld go away after it has dried out. Do the bros here ever encountered this before and can shed some light on this? Thanks! ↡ Advertisement Link to post Share on other sites More sharing options...
Gary84 1st Gear January 1, 2008 Share January 1, 2008 u may want to check on ur belts....i.e timing or fan belt... Link to post Share on other sites More sharing options...
Carmaniac Neutral Newbie January 1, 2008 Share January 1, 2008 Did the squealing sound only occur in the carpark? Because some carparks have cement/concrete floor which results in squealing sounds when the car turns Link to post Share on other sites More sharing options...
Sickscientist Clutched January 1, 2008 Share January 1, 2008 Squeal or screech? Car transmission? Link to post Share on other sites More sharing options...
Emils 2nd Gear January 1, 2008 Author Share January 1, 2008 Nope, not just in the carpark. The squealing sound was there all the way, incl. along AYE... Link to post Share on other sites More sharing options...
Emils 2nd Gear January 1, 2008 Author Share January 1, 2008 sound more like a squeal... Don't know if it's due to the transmission. Mine's on CVT... Link to post Share on other sites More sharing options...
Sickscientist Clutched January 1, 2008 Share January 1, 2008 Maybe the wheel bearing or belting or even pulleys.. Link to post Share on other sites More sharing options...
Emils 2nd Gear January 1, 2008 Author Share January 1, 2008 Thanks. Are these supposed to be covered under the warranty? I need to know my 'rights' when I send it in to the workshop tmr. Link to post Share on other sites More sharing options...
Sickscientist Clutched January 1, 2008 Share January 1, 2008 I dont think so.. They part of wear and tear... What ur mileage btw? Link to post Share on other sites More sharing options...
Emils 2nd Gear January 1, 2008 Author Share January 1, 2008 10,000km. Just sent it in for preventive maintenance last week... Link to post Share on other sites More sharing options...
Enzomatrix 2nd Gear January 1, 2008 Share January 1, 2008 i got squeaking sound on and off too... was due to belt.. after tighten seems ok now Link to post Share on other sites More sharing options...
Sickscientist Clutched January 1, 2008 Share January 1, 2008 Link to post Share on other sites More sharing options...
Sickscientist Clutched January 1, 2008 Share January 1, 2008 In that case, go back to AD and make noise.. Link to post Share on other sites More sharing options...
Rev2redline Neutral Newbie January 5, 2008 Share January 5, 2008 it may be due to your brakes as well... does it squeal only when u move? even when u dun accelerate? it may be due to the brake pads rubbing on the rotor... sometimes it may be the brake dust that accumilate between the rotor and the brake pads... Link to post Share on other sites More sharing options...
Emils 2nd Gear January 6, 2008 Author Share January 6, 2008 Thanks for the advice. It was nearly spot on. :) I have sent it in for inspection at the AD last week (wasn't a terribly nice experience but there's another story). They only found out that there was a stone lodged in the disc brakes after one whole day... ↡ Advertisement Link to post Share on other sites More sharing options...
Sound Proofing the car
Whole car sound proof
Right side speakers no sound
Metal grinding sound on civic
Engine dies while in stationery
NEW 3 Door Double Decker Buses OTR soon
