Emils 2nd Gear December 7, 2007 Share December 7, 2007 Hi Bros and Sis, Wonder if anyone can share where I can get my car de-badged and how much it will cost? Thanks! ↡ Advertisement Link to post Share on other sites More sharing options...
Fcw75 Hypersonic December 7, 2007 Share December 7, 2007 Can DIY mah. Buy fishing line and cut thru' the double sided tape behind the emblem can liao. After that remove the residue and polish that part. Link to post Share on other sites More sharing options...
Apollo 1st Gear December 7, 2007 Share December 7, 2007 $4.. good fishing line DIY. get fr B2 (sports section) shelf next to nike product. Link to post Share on other sites More sharing options...
Porche 5th Gear December 7, 2007 Share December 7, 2007 dental floss also can Link to post Share on other sites More sharing options...
Poortraveller 1st Gear December 7, 2007 Share December 7, 2007 some model cant debadge just like that ... mine is attached to the body and will leave 2 holes there Link to post Share on other sites More sharing options...
Arowana1 1st Gear December 7, 2007 Share December 7, 2007 fishing line is the least of the problem. the double sided tape can be a bitch to remove. not the usual tape but some sticky gooey thing that cannot be peeled off. u gotta rub and rub using cloth to remove it. Link to post Share on other sites More sharing options...
Slowmo Clutched December 7, 2007 Share December 7, 2007 If just removal of badge, can DIY.. If after remove, needs to putty and respray, then best to ask for quote from spray shops. Link to post Share on other sites More sharing options...
Emils 2nd Gear December 7, 2007 Author Share December 7, 2007 What about the front badge? I'm driving a Civic... Can also DIY? Link to post Share on other sites More sharing options...
Crv007 Neutral Newbie December 7, 2007 Share December 7, 2007 Hi Bros and Sis, Wonder if anyone can share where I can get my car de-badged and how much it will cost? Thanks! I de-badged my CRV tag myself, following step is how I do. 1. like most Bros here say use a fishing line to pull/cut out the badge. 2. buy Spirit from Hardware store, dap a cloth with spirit to rub the sticky double side taped out slowly. Go hardware store tell them you wanna de-badge they will pass you the spirit. dun use Tinner or other stuff as they are too strong can rub off your paintwork. 3. lastly use polish to polish over de-badge area. took me around 15 min Link to post Share on other sites More sharing options...
Crv007 Neutral Newbie December 7, 2007 Share December 7, 2007 Honda Logo Badge need to unscrew, you need to dis assemle stuff.......er...not that straight forward Link to post Share on other sites More sharing options...
Emils 2nd Gear December 7, 2007 Author Share December 7, 2007 Mm.. thanks for sharing the info.! I will go "explore" a bit more tmr. keke. Link to post Share on other sites More sharing options...
Johnthese Neutral Newbie December 7, 2007 Share December 7, 2007 if i drive coe car and debagde,will there be a shadow of the badge on my paint? Link to post Share on other sites More sharing options...
Sickscientist Clutched December 13, 2007 Share December 13, 2007 DIY.. - Remove using G-string(Guitar string) - Remove residue using kerosene/WD40 - Treat the area with wax - Wipe off - Wash car(Esp the concentrated area) Fingers might hurt after that.. Link to post Share on other sites More sharing options...
Sickscientist Clutched December 13, 2007 Share December 13, 2007 Most likely there will be... If can, bring to body shops... Link to post Share on other sites More sharing options...
Dafansu Turbocharged December 13, 2007 Share December 13, 2007 can i used real g string Link to post Share on other sites More sharing options...
Powerhouse Clutched December 13, 2007 Share December 13, 2007 Think I saw a spray can of "DE-BADGE" somewhere in the DIY shop. cost a few dollars. Link to post Share on other sites More sharing options...
Kaer Neutral Newbie December 13, 2007 Share December 13, 2007 1. use hairdryer to heat out the double side or pour soapy water over the badge 2. use dental floss or fish line and cut between the badge and the car 3. the sticky goo, use soapy water and rub it out 4. sure will have "suntan" mark, polish it off have fun! Link to post Share on other sites More sharing options...
W2K_83 1st Gear December 13, 2007 Share December 13, 2007 I just simply pull them out slowly and then wax the area. But have to do when the car's new. No marks or anything. My dad's been doing that to his cars for years and I just practise the same thing. ↡ Advertisement Link to post Share on other sites More sharing options...
Wheel Spacer, where to buy?
What do you really spend on and how much?
Where you cut your hair?
Going to Batam. Where to park overnight ?
NBA - Where Amazing Happens
