Cool_tiger Neutral Newbie December 5, 2007 Share December 5, 2007 Hi, Need to replace my Skoda Oct door rubber seal and power window device (no sure what they call it...). I checked with CA and was told the rubber seal cost $170 (need to wait for 3 weeks) and the window device cost a few hundreds. Anyone can advice on other alternative or source for cheaper parts. Thank you. Rgs ↡ Advertisement Link to post Share on other sites More sharing options...
Othello Supersonic December 5, 2007 Share December 5, 2007 servo, CAG, xinzhong ...... do a search for the contacts Link to post Share on other sites More sharing options...
Cool_tiger Neutral Newbie December 5, 2007 Author Share December 5, 2007 Thank you. will check from the internet. Link to post Share on other sites More sharing options...
Fortress Clutched December 6, 2007 Share December 6, 2007 (edited) Hope it helps, I have solved the rubber issue by using high heat resistance glue, which cost about S$8. As for the window, I have learned from the guys that VW has a load of problems and heavy cost involved with it, hence, decided not to fix it and use the door instead. Xin Zhong is very competitive. They are at 247 Lavender Street, try looking for Jeffrey or David, they are great guys. Edited December 6, 2007 by Fortress Link to post Share on other sites More sharing options...
Dudemobile Neutral Newbie December 6, 2007 Share December 6, 2007 The window lifters, there are some OEM ones you can look at. If the cables are still ok, you'll only need to replace the plastic piece. I stopped using the window when i heard and addtional click winding up. That saved me the cable and motor assembly. Only had to replace the plastic lifter. Link to post Share on other sites More sharing options...
Cool_tiger Neutral Newbie December 6, 2007 Author Share December 6, 2007 Hi Fortress, The rubber seal already damage and cannot glue back. Need to buy a new one which is quite costly. Link to post Share on other sites More sharing options...
Cool_tiger Neutral Newbie December 6, 2007 Author Share December 6, 2007 Hi Dudemobile, I think the cables already broke but still can hear the window clicking sound when operate it. Don't intend to repair the window device (too costly) but want to fix it into position. Currently I just used a paper to prevent the window dropping down. :P Any advice? Link to post Share on other sites More sharing options...
Beanoyip Turbocharged December 7, 2007 Share December 7, 2007 What can be done is stick a piece of wood or whatever inside to prevent the lifter from 'dropping'. Link to post Share on other sites More sharing options...
Fortress Clutched December 7, 2007 Share December 7, 2007 You may want to try Xin Zhong. Link to post Share on other sites More sharing options...
Cool_tiger Neutral Newbie December 8, 2007 Author Share December 8, 2007 Hi, You have Xin Zhong contact no. ? tks. Link to post Share on other sites More sharing options...
Fortress Clutched December 8, 2007 Share December 8, 2007 you might like to try +65 62916051 Link to post Share on other sites More sharing options...
Cool_tiger Neutral Newbie December 8, 2007 Author Share December 8, 2007 Thank you. ↡ Advertisement Link to post Share on other sites More sharing options...
Both BYD and Tesla will now sell you Cat A versions of their popular Seal and Model 3 saloons
Window grill lock
Window grill lock
Where can I get rubber sheet
Digital Door Lock
Digital Door Lock
