Mixing of petrol...
Typhoonz
i mix all the time whenever i go in jb...(3/4 tank sg fuel + 1/4 jb fuel)....no problems at all for my previous 3 makes! laugh.gif
I guess everyone does as the petrol grades in JB differs from ours... Unless you are pumping V Power... I understand that the lowest grade is RON 91 right?
So long it is petrol of certain Octane, water & sediment free - there should not be any problem. Always avoid old petrol stations as thier underground petrol tanks may containt accumulated sediment and moisture over the years. Also petrol stations that are sited at low laying areas where flood water can easily seep into the underground tanks via the ground level opening
My "virgin" top up was at the Caltex station near the check point. My last pump was at Shell after City Square. Will be pumping Shell all the way liao...
As long as is petrol anyhow mix also can regardless of brand/model. Unless you want to try to mix diesel wif petrol. laugh.gif
Wah... Sometimes I'm a bit neurotic as I constantly check the pump to make sure before I start pummping... I have the "mindset" tendency as I was driving a Caddy previously...
Might be... I guess that basic "ingredients" are the same, just that different brands will try to outdo each other but adding cleaning agents that boasts better performance for your car...
ya bro lowest shd be 91 ron....does ur car req a certain min level? if yes then jus go for the 97ron...shld be more than safe for most cars....unless the TC ones....
my ride also.. always mix different grades of petrol..
no prob
V Power liao this sunday!!
wah so rich...my last pump of V power was almost 5 years ago...
anyway i always mix Singapore's SPC 92 with JB's Caltex 97...
no issues at all... [nod]
Mine can go down to RON 91 but I don't think that's necessary... For the last 2 top ups, I was pumping RON 97... Will go for V Power this sunday morning...
