Eyke Supercharged November 15, 2007 Share November 15, 2007 Besides Stamford, which other workshops use torque wrench? Looking for a workshop to do tyre rotation and installation of rotors and pads... ↡ Advertisement Link to post Share on other sites More sharing options...
Nothingtodo 1st Gear November 15, 2007 Share November 15, 2007 I tot most workshops uses torque wrenches? Link to post Share on other sites More sharing options...
Yeobh 4th Gear November 15, 2007 Share November 15, 2007 99.9% of the HDB auto and tyre shops don't have them. Link to post Share on other sites More sharing options...
Elfenstar 3rd Gear November 15, 2007 Share November 15, 2007 why do u need a torque wrench for tyre rotation and pad and rotor change??? Link to post Share on other sites More sharing options...
Eyke Supercharged November 15, 2007 Author Share November 15, 2007 before you rotate & change rotors/pads, must take off wheels, then put them back afterwards right? and to put wheels back must tighten lug nuts, correct? Link to post Share on other sites More sharing options...
Kb27 Supersonic November 15, 2007 Share November 15, 2007 It's hard to find a workshop that used torque wrench. I bought a torque wrench and re-torque the lug nuts after I sent it for tyre balancing and rotation. Workshop always over-tightened as in kiasu. Link to post Share on other sites More sharing options...
Eyke Supercharged November 15, 2007 Author Share November 15, 2007 don't you find that a bit too late? if they strip the threads by over-tightening, then anything you do afterwards won't help. Link to post Share on other sites More sharing options...
Ah_liang Clutched November 15, 2007 Share November 15, 2007 Most workshop using compressed air wrenches, it should be good enough. Link to post Share on other sites More sharing options...
Sony 1st Gear November 15, 2007 Share November 15, 2007 hankook at Toh Guan. The supervisor instruct the guys to use that during my rotation due to my rims. If I remember correctly, if you are having hankook tyres, it's 15 plus N2 topup for rotation, otherwise it's 30. anyway, you can give them a call. they have quite a lot of branch all over s'pore Link to post Share on other sites More sharing options...
Sony 1st Gear November 15, 2007 Share November 15, 2007 not really. beside the issue of possible over tightening, the air wrenches also vibrate and might damage the rim.. you wouldn't want such minor damage on expensive rim Link to post Share on other sites More sharing options...
Sony 1st Gear November 15, 2007 Share November 15, 2007 you shd have brought the torque wrench to the workshop and ask them to use it. What's the point after damage have been done? Link to post Share on other sites More sharing options...
Garlic 1st Gear November 15, 2007 Share November 15, 2007 Automotive Technology @ 3 International Road. The mech there tightened the my wheel nuts by hand and then torque loaded each individual one with a torque wrench. The wheel hubs were also cleaned of rust with a steel brush before being repainted. They provide free rotation every 10K with every set of tyres purchased. Great service and workmanship. Link to post Share on other sites More sharing options...
Garlic 1st Gear November 15, 2007 Share November 15, 2007 Link to post Share on other sites More sharing options...
Elfenstar 3rd Gear November 15, 2007 Share November 15, 2007 So you just want a workshop that hand tightens via a socket wrench right? Beacuse those that use a pneumatic impact wrench tend to over tighten??? Link to post Share on other sites More sharing options...
Elfenstar 3rd Gear November 15, 2007 Share November 15, 2007 The problem with pneumatic impact wrenches is that very few workshops are willing to pay double the price for one that that has variable torque settings. And for those that do, most are too lazy, not to mention most only use the standard long sockets instead of the proper lugnut sockets. What happens is that the nuts get over tightened which in the long run can lead to the bolt snapping. The easiest way should be using the variable impact wrench at its lowest setting and thereafter tighten by hand. Link to post Share on other sites More sharing options...
Kb27 Supersonic November 15, 2007 Share November 15, 2007 (edited) Right, it's a bit too late, but better late than never. I do the balancing/rotation in JB and always forget to bring the torque wrench. The fully handtight method turns out to be around 110 to 120 ft-lb according to my torque wrench. My car manual specifies 60~80 ft-lb. That's how much overtighten it can get. Edited November 15, 2007 by Kb27 Link to post Share on other sites More sharing options...
Yeobh 4th Gear November 16, 2007 Share November 16, 2007 The airwrench with standard lug nut socket may sometimes scratch the alum rims. Hardly ever come across any tyre shops using special lug nut sockets designed specially for use on alum rims. Link to post Share on other sites More sharing options...
Sony 1st Gear November 16, 2007 Share November 16, 2007 That's why they use hand coz they know the airwrench cannot make it ↡ Advertisement Link to post Share on other sites More sharing options...
Torque wrench hunt
Torque wrench hunt
RS Chip Tuning
RS Chip Tuning
This Video Cleverly Uses LEGO To Explain Torque And Horsepower
Pro workshops doing Subaru
Help on Skoda Workshop/parts Needed
Professional Proton Workshops
Any recommendation for workshops for Mitsubitshi cars?
Automotive Glass: How does it differ from other types?
