Latiosedan Clutched November 12, 2007 Share November 12, 2007 I just have my tyres swop at a tyre shop near AMK area. Within a week, when i inspect the wheels, I discovered that the 4 nuts on my front left wheel came loose. I can even unscrew them using bare hands. Luckily the wheel did not come off while driving, otherwise the car sure go out of control. I am wondering if the screw nuts will loosen over time? or is it a bad job done by the tyre shop? ↡ Advertisement Link to post Share on other sites More sharing options...
Roberttan 5th Gear November 12, 2007 Share November 12, 2007 don't you feel any vibration and funny sound after the job? Link to post Share on other sites More sharing options...
Kyojin 1st Gear November 12, 2007 Share November 12, 2007 you can undo them with your bare fingers?! Link to post Share on other sites More sharing options...
Sash7 Neutral Newbie November 12, 2007 Share November 12, 2007 it won't loosen over time unless ws never tighten properly. maybe someone sabo???? but you can hear some noise if the nuts r not tighten poperly.. in your case sure got sound... hand also can turn... thats bad Link to post Share on other sites More sharing options...
Beei 1st Gear November 12, 2007 Share November 12, 2007 should not come loose over time.. but maybe u are strong?? anyway if the nuts are loose, u should hear some 'knocking' sound from below ur car.. Link to post Share on other sites More sharing options...
Furrynadz 5th Gear November 12, 2007 Share November 12, 2007 tyre shop fault Link to post Share on other sites More sharing options...
Spiderman302 2nd Gear November 12, 2007 Share November 12, 2007 It should not happen if tightened properly. Possible reasons : 1. Mechanic did not tightened properly. 2. Worn out threads, but happen on all 4 nuts ? quite strange 3. Sabo. Link to post Share on other sites More sharing options...
To_be_advised Neutral Newbie November 12, 2007 Share November 12, 2007 If the nuts come loose till the extent you mentioned, then you should be able to feel some vibrations on your steering wheel when you drive. Happened to me once and i stopped driving at once when i feel the steering wheel vibrations. KAO!!!! Probably a lousy job at the tyre shop i guess..... Link to post Share on other sites More sharing options...
Kb27 Supersonic November 12, 2007 Share November 12, 2007 (edited) Most likely, the mechanic used hand tightened first, but forgot to really tightened it. It's easy to forget if you are rushing around. So try to avoid really busy shop. Edited November 12, 2007 by Kb27 Link to post Share on other sites More sharing options...
Mzrmazda3 6th Gear November 13, 2007 Share November 13, 2007 Bro, either tio sabo or that tyre shop did not do a proper job for you Luckily, you realised it before anything tragic happens Link to post Share on other sites More sharing options...
Watwheels Supersonic November 13, 2007 Share November 13, 2007 Maybe the air compressor to power the pneumatic torque wrench gun did not build up enough pressure due to multiple usage. Ppl tend to rely on the air compressor and dun bother to maintain it. They should use a wrench to hand tighten after using their pneumatic tools to make sure the nuts are secured. Link to post Share on other sites More sharing options...
Yeobh 4th Gear November 18, 2007 Share November 18, 2007 (edited) If you are using compressed air impact wrench day in day out for almost the same kind of job, you should be able to notice the different in the wrench tightening noise and air discharge. On top of that , all electric motor powered air compressors are designed to auto kick in once the tank pressure reaches the min pre set pressure. The biggest headache is not pressure but air volume due to accumulatoin of condensed moisture in the tank. I used to adv customers to install auto drain unit at the base of the tank. Edited November 18, 2007 by Yeobh Link to post Share on other sites More sharing options...
Ivan96935sg Neutral Newbie November 18, 2007 Share November 18, 2007 Quote I just have my tyres swop at a tyre shop near AMK area. Within a week, when i inspect the wheels, I discovered that the 4 nuts on my front left wheel came loose. I can even unscrew them using bare hands. Luckily the wheel did not come off while driving, otherwise the car sure go out of control. I am wondering if the screw nuts will loosen over time? or is it a bad job done by the tyre shop? Lesson learned: Dun patronize that tireshop AGAIN n inform all friends to boycott that shop..... Link to post Share on other sites More sharing options...
Cheerios Neutral Newbie November 18, 2007 Share November 18, 2007 Quote I just have my tyres swop at a tyre shop near AMK area. Within a week, when i inspect the wheels, I discovered that the 4 nuts on my front left wheel came loose. I can even unscrew them using bare hands. Luckily the wheel did not come off while driving, otherwise the car sure go out of control. I am wondering if the screw nuts will loosen over time? or is it a bad job done by the tyre shop? is that shop called pXh XXXX??? i have heard alot of stories about them.. u are not the first one.... what to do? cheap mah.. then cheap services Link to post Share on other sites More sharing options...
Silverado1 Neutral Newbie November 18, 2007 Share November 18, 2007 Did you return to the shop to complain? Sometimes, the mgt don't know what's happening! You should highlite this to them! It's very serious! Do it before something serious happens! Link to post Share on other sites More sharing options...
Watwheels Supersonic November 19, 2007 Share November 19, 2007 Accumulation of moisture will result in water "leaking" from their tools. Believe me I know. Usually they have a dryer installed to auto remove and drain most of it. The rubber hose might have cracks somewhere and started leaking for all we know. Link to post Share on other sites More sharing options...
Yeobh 4th Gear November 19, 2007 Share November 19, 2007 You got the wrong guy, me driving BMW , nothing to complaint. Link to post Share on other sites More sharing options...
Guniang Clutched November 19, 2007 Share November 19, 2007 which tire shop....i went to soh which is opp ph and their service is excellent...no wait no fuss...good pricing too... ↡ Advertisement Link to post Share on other sites More sharing options...
Photos of the week
Photos of the week
Volvo Servicing
Volvo Servicing
Servicing at Tan Chong
Is Tan Chong Servicing Package NPMP value for money?
