Coils Adjustment for JDM Civic R
Simplyme
hey guys... my frd is cosidering buying the jdm CTR... the only hold back is the stiff rear suspension... i understand that its a coil spring so asking any pros on whether it can be adjusted anot?? thks in advance [flowerface]
me no pro. but this is what i know so far... [flowerface]
nope. not adjustable. damper and spring rates all factory preset for super hard driving. all the linkages and bushings are beefed up too.
furthermore, the low profile 18" RE070 tyres have super hard side walls. some say change tyre and put lower slightly lower pressure can soften the ride a bit liao.
but the 18" 225/40 RE070s are bespoke to the JDM CTR, this size can't be found anywhere as of now. think twice before changing cuz its a rare and very good tyre, and very ex too. if your friend is a trackie, keep the original rims and tyres for track and buy another set for daily driving. if not, he has to bear with liao [sweatdrop]
Edited by Relagsingh
weird eh? [sweatdrop]
no offence to JDM CTR owners. know what you're getting. its a full on track car the moment its spawned from the drawing boards. if dun frequent track, dun buy.
and changing to softer springs and dampers wun help alot too. but if that's the case, that brings to the question of why people get a CTR in the 1st place.
er.. see not much point in softening the suspensions for the JDM CTR
else get a euroR or uk type R or 2L FD2 or accord or legend...
but as some bros put it in other threads ... suspension get a bit used to it can liaoz... aft some time he itchy to get even stiffer suspension...
hey guys... my frd is cosidering buying the jdm CTR... the only hold back is the stiff rear suspension... i understand that its a coil spring so asking any pros on whether it can be adjusted anot?? thks in advance flowerface.gif
Yup, you should go and ask in SHC's Civic FD/FN folder - I believe there's a CTR meetup this Friday - see details in that folder.
It's best that you seek owners' opinions - no matter how good intentions are here, I doubt any of comments posted here so far is based on actual driving of the CTR or even feedback from the owners -- if they are, I stand corrected.
According to feedback from at least two CTR owners I know, the suspension, especially the rear, is set up specifically for track ie super-smooth surfaces -- they complained that at their usual cruising speed up to Sepang, the ride was pretty awful - bouncy and jarring.
Honestly I won't be surprised if properly set-up suspension kits sell like hot cakes later on, when they become available. Another option that I heard of - one owner has changed to Koni Yellow dampers but left stock springs alone.
OK no offence hor - just that sometimes too much is based on web reviews and hearsay -- I can only claim to get feedback directly from CTR owners -- personal experience too limited: only managed a short 5 min test drive and a slightly longer test ride on busy local roads - both times in front so no idea how bad the ride is at the back.
If buy the JDM CTR, then must enjoy the standard features which comes along with it [nod][nod][nod]
Your friend would get used of the rear stiff suspension and maybe as times passes by, he might wanna change it to stiffer ones [sly]
The stock one is unable to adjust as it is not a coilover [;)]
Mai Tu Liao, if pocket is deep enough, go for it [nod][nod][nod]
How i wish i could afford one [inlove][inlove][inlove]
Your friend is the first I've heard who wants to soften a Type R suspension.... [sweatdrop]
The Type R is immaculately setup. Don't mess with the handling unless with reputable aftermarket coilovers, which will be even harder.
Better ask your friend don't buy.
It's a lousy car. I'm driving 1 and the suspension sucks big time.
Si bei stiff and jumpy. Sometimes got the vomit feeling after a hearty meal.
The car is built for track and not daily usage.
A normal civic is a better choice.
yup. saw the touge vid? all the aftermarket suspension slower than the original set up during the 1st run. j's racing look promising but crashed out.
after several attempts by spoon then got improvement.
