Canon Powershot A610
Cupid
Hi, any bro or sis own this camera? Would like to know if this cam could support SD card which is more than 2 GB. Thanks.
Standard SD card has a max. limit at only 2GB. Although a lot of the memory card manufacturers come out with 4GB SD cards, they are considered non-standard so the only way to find out is to put the card in and try it out.
A word of caution, if you are using card reader to get the photos out, you will need to check and see if the 4GB SD card is incompatible with your card reader as well.
A610 only supports SD and MMC cards so you cannot use the newer SDHC card which will have a higher capacity.
OIC.......thanks for the info....However, this cam can support 2GB SDHC....so was wondering 4GB SDHC got support or not as I think can forget abt 8GB liao.
Oh, if it can support SDHC, then 4GB SDHC is no problem. However, I thought you were talking about 4GB SD which is not the same as 4GB SDHC. 4GB SDHC conforms to industry standard but 4GB SD does not.
