Timmz Neutral Newbie October 30, 2007 Share October 30, 2007 (edited) On my last 60k servicing, the mech recomend me to change the brake rotors by the next svc interval. says there is uneven wear and some grooves appearing that will compromise brake ability. Any one has some concrete ways to verify that. My brakes work fine so far, the occasional 'e-brake' to avoid crazy drivers. so far so good. How do I tell the mech is not trying to wrangle me of unnecessary changes? Seems common on conti cars, my jap car experiences do not have such requirements till like 120k inputs appriciated. ps: no more warranty, is a rather low mileage car :) Edited October 30, 2007 by Timmz ↡ Advertisement Link to post Share on other sites More sharing options...
Tigershark1976 Turbocharged October 30, 2007 Share October 30, 2007 60K? urs OPC?? should be under warranty, go back to ur dealer to change.... its not a standard part that required to be change on certain millage. But got problem at 60K is really quite rare. Link to post Share on other sites More sharing options...
Edrollbrick Neutral Newbie October 30, 2007 Share October 30, 2007 I think rule of thumb 2 sets of pad then rotor. Conti brakes tend to wear faster. At 60k, I think no more warranty as brakes are wear and tear items. Some work shop "skim" the rotors if it is not already too thin. Normally done only once, if scoure again better change. Link to post Share on other sites More sharing options...
Joe_Legal October 30, 2007 Share October 30, 2007 Change rotors at 60K quite suprising, esp when you say braking still ok. Your pads are stock factory types or the performance, aftermarket ones with metallic compounds? Link to post Share on other sites More sharing options...
Timmz Neutral Newbie October 31, 2007 Author Share October 31, 2007 all compoents are stock. any info on how to make sure that it is in fact required to change? the thickness of the brake pads n the rotor? such information is not easily available to the man on the street Link to post Share on other sites More sharing options...
Eyke Supercharged October 31, 2007 Share October 31, 2007 (edited) there is a minimum thickness for pads and rotors, you can check with your dealer/manufacturer for the specs since it's stock. to make it easier to see, you may consider changing to rotors that has indicators for when minimum thickness is reached, eg. some Brembo rotors: using dots: http://www.brembo.com/ENG/AfterMarketBrake...tseasycheck.htm using slots for Brembo Max: Edited October 31, 2007 by Eyke Link to post Share on other sites More sharing options...
Circuit Clutched October 31, 2007 Share October 31, 2007 yesh go get brembo max disc... cheap and good, slotted looks good and better than the flat stock ... i bought 160 there each disc... from Lintrex , brembo agent at yishun Link to post Share on other sites More sharing options...
Fabby27 Neutral Newbie November 8, 2007 Share November 8, 2007 Hi bros. im driving a G6 camry with 30k mileage.. recently when i for my 30k servicing at an outside workshop, the mechanic asked me whether i wanna do some servicing for my brakes and i asked him to go ahead.. i saw him took out the brake pads and sand them on a sandpaper. 1 week after driving, i realize that there are 2 different tones on both my front rotors. this only happened after the servicing. those it mean that only half the brake pad is working on the rotor? wat can be done to solve this? thanks! Link to post Share on other sites More sharing options...
Yeobh 4th Gear November 8, 2007 Share November 8, 2007 Frankly , the mech has taken yr money and wasted yr time, trying to remove hard /glazed spots with sandpapper which achive nothing at all. It's like trying to polish a rare diamond with sand dust. The end result is the some fine abrasive from the sandpaper get in between the rotor and pad thereby causing uneven heat distribution on the rotor. Link to post Share on other sites More sharing options...
Shull Turbocharged November 8, 2007 Share November 8, 2007 my civic mileage is 120k liao..everything servicing, they didnt say anything about changing rotors leh.. Link to post Share on other sites More sharing options...
Silver_blade Turbocharged November 8, 2007 Share November 8, 2007 Agree with Yeobh. What you mech did was 'rubbish'. I guess you can try to skim the rotor and get a new brake pad. Or...you can just get a new pad. The 'damage' on the rotor doesn't look too bad. Link to post Share on other sites More sharing options...
Axeman24 2nd Gear November 8, 2007 Share November 8, 2007 Friend don't mind me asking did you use after market brake pads? If yes, it mind be the cause of grooves on your rotor. I experience it before and regretted using after market brake pads. So if your are using after market pads my advice is pay a bit more and get the original ones. Link to post Share on other sites More sharing options...
Fabby27 Neutral Newbie November 8, 2007 Share November 8, 2007 nope still on the stock pads... Link to post Share on other sites More sharing options...
Fabby27 Neutral Newbie November 8, 2007 Share November 8, 2007 these lines only appeared after the brake 'servicing'.. which probably mean that it has caused more harm den good? wat's a cheaper alternative to solving this? skim the rotors or to change the pads? if i leave it alone.. will braking power be compromised or would there be further damage? thanks Link to post Share on other sites More sharing options...
Yeobh 4th Gear November 14, 2007 Share November 14, 2007 If the pads are reach the min thickness, than I suggest replacing them, if not do a clean up. I am sure of the pad material, but try using a fine cut woodwork file if not possible opt for fine cross cut metalwork file. Link to post Share on other sites More sharing options...
Apollo 1st Gear November 14, 2007 Share November 14, 2007 dun like the tone? so how... go back to him and ask him adjust key + or minus? ↡ Advertisement Link to post Share on other sites More sharing options...
Budget 2025 - February 2025.
Change Disc Rotors
Change Disc Rotors
Tool to change Spark Plug
X for twitter change request
