Chowyunfatt Turbocharged October 22, 2007 Share October 22, 2007 I have recently bought a new car & installed Solar Film...During the installation, there was no cut out for the IU which made me slightly concern due to detection problems... The installers assured me that detection of the IU was not a problem & so I believed them since they are reputable...Sure enough the ERP gantry was not a problem, but some car parks were unable to detect the IU... For those Car Parks unable to detect, it is always during the exit, never the entrance...Why is this so?...Does anyone encounter this same problem?... ↡ Advertisement Link to post Share on other sites More sharing options...
Relagsingh 4th Gear October 22, 2007 Share October 22, 2007 nope. Link to post Share on other sites More sharing options...
Maxus-MIFA9 Supersonic October 22, 2007 Share October 22, 2007 Lights passing through the glass & reflection cause by the film, that's the problem. Certain car parks (like T Payoh Central) install spot lights (white light like those HID light) to shine onto the windscreen so as the reader able to read your IU. Those readers install under shade take a longer time to read your IU while those under open air read faster. Link to post Share on other sites More sharing options...
Nutty 4th Gear October 22, 2007 Share October 22, 2007 Is your solar flim ceramic based or metallic based? I believe it's more important for metallic based flim to have a cut out for the IU. Link to post Share on other sites More sharing options...
Chowyunfatt Turbocharged October 22, 2007 Author Share October 22, 2007 But funny rite...come into the Car Park no problems...But when going out then kena...are they using different sensors for the entrance & exit?... Link to post Share on other sites More sharing options...
Chowyunfatt Turbocharged October 22, 2007 Author Share October 22, 2007 I'll be honest here...I have no idea... Link to post Share on other sites More sharing options...
Tonyg Clutched October 22, 2007 Share October 22, 2007 (edited) When u go into the car park, even without cash card, the barrier will still open. It detects on your IU. But going out, they need to deduct the money, so cash card must be inserted into the IU. Edited October 22, 2007 by Tonyg Link to post Share on other sites More sharing options...
Freestylers09 5th Gear October 22, 2007 Share October 22, 2007 u can enter means they can sense ur IU...when go out is with IU+Cash card...ur reader got problem to read the cash card issit?? Link to post Share on other sites More sharing options...
Acemundo Supercharged October 22, 2007 Share October 22, 2007 that depends on where they place the sensor as well....one placed 45degree to the iu vs one placed 180degrees to the iu may go thru different degree of rarefaction. remember this is is system whereby the ray sent to the iu is meant to read and the return ray to confirm and deduct. if there is certain degree of rarefaction, the responding ray may not be sent out Link to post Share on other sites More sharing options...
Apollo 1st Gear October 22, 2007 Share October 22, 2007 i hv this problem, but i got no solar film either. problem is my card is faulty... Link to post Share on other sites More sharing options...
Chowyunfatt Turbocharged October 23, 2007 Author Share October 23, 2007 I know lar...Its bad habbit, but I will always leave my cash card in my IU...I will only remove it when I need to top up the value... Link to post Share on other sites More sharing options...
Chowyunfatt Turbocharged October 23, 2007 Author Share October 23, 2007 No leh...Cos if reader got problem, then the IU will sound & an Error will appear at the display rite?... Link to post Share on other sites More sharing options...
Chowyunfatt Turbocharged October 23, 2007 Author Share October 23, 2007 These ppl damn funny...don't they have a guide line to install these sensors if they realise that certain angles cannot detect consistantly?... Link to post Share on other sites More sharing options...
Chowyunfatt Turbocharged October 23, 2007 Author Share October 23, 2007 Ok...That I can understand...But that can be easily rectified... Link to post Share on other sites More sharing options...
Sony 1st Gear October 23, 2007 Share October 23, 2007 If you want to get a detail answer, pls display more details in your question such as name and type of solar film and which particular carparks. It's like I'm telling you I see a doctor for a problem but problem not solved. So how? Link to post Share on other sites More sharing options...
Acemundo Supercharged October 23, 2007 Share October 23, 2007 usually the reason is because the engineer tested it with 1 particular car with a particular solar firm and cutting.. probably lazy or oversight that he didn't tested enough different samples. Link to post Share on other sites More sharing options...
Tarzan666 2nd Gear October 23, 2007 Share October 23, 2007 good morning far-ker, my film no hole & can detect leh. 1st time hear this problem...maybe ur IU spoil or u want to try different carparks Link to post Share on other sites More sharing options...
Sony 1st Gear October 23, 2007 Share October 23, 2007 (edited) Lights passing through the glass & reflection cause by the film, that's the problem. Certain car parks (like T Payoh Central) install spot lights (white light like those HID light) to shine onto the windscreen so as the reader able to read your IU. Those readers install under shade take a longer time to read your IU while those under open air read faster. I don't really understand this. When you use the word, "read", does the sensor really need lights to read the IU? if you ask me, those lights are there more for drivers that need to print receipt or for them to see that there's a barrier and not ram thru it. but to read the IU? that's new to me Edit: if your theory is used on those old style of sensor such as those used in NUS that read number plate, then maybe it need lights.. Edited October 23, 2007 by Sony ↡ Advertisement Link to post Share on other sites More sharing options...
How to tell if your coffee is good
How to tell if someone is high or low class?
Someone left a bag containing $40k on bus 63
"Limbey tell you" N " I want haolian"
How to stop someone from digging/picking his nose?
I succeeded in getting someone to turn off his high beam!
How To Tell If Aftermarket Rim Is Original Or Replica?
Tell Tale Signs Before Disaster Struck
