Defi VSD concept Display help!
Icetrap
Anyone with VSD X meter (Similar to VSD Concept) from Defi?
My RPM is way Off in Defi VSD X. It's off by a lot!
Like my redline is around 6700rpm, it's displaying at 9150rpm. [thumbsdown]
Morning bro. So you have VSD also? Sians. I wonder if anyone is having the same issue as me!
Edited by Icetrap
Number 2 Switch? anyway call me if you can bro if you know how to "calibrate" the RPM. Thanks! As far as I know the RPM and the speedo should be the same wire. If Speedo is correct, RPM should be accurate too!
My number Nick 90705745!
thats y.. Defi VSD is direct plug n Play for most 1.6L cars.you only need to switch the cylinders if your car is 'slightly' special engine.
For using VSD,only need to connect 2 wires,Speed n RPM.Refer to the wiring diagram supplied and connect accordingly. [:/]
Wah....Glad that it is finally over for you.... [nod]
You even publicly leave your number in the forum. [thumbsup]
