Eyke Supercharged October 12, 2007 Share October 12, 2007 car WILL SKID when you don't have ABS and stomp hard enough to lock up your wheels, no matter what tire of whatever compound/grip/traction you use. compound/grip/traction only comes into the equation to affect braking distance when wheels are not locked. ↡ Advertisement Link to post Share on other sites More sharing options...
Rentabass Neutral Newbie October 12, 2007 Share October 12, 2007 (edited) Yes, you have a point there, but if all things equal (i.e. same braking force applied), a tire with a grippier compound will definitely stop in a shorter distance. On an ABS equipped car, slamming on the brakes with a grippy set of tires will set the ABS off later than if you were to stand on the brakes with less grippy tires - this is testament to how tires would affect braking. Perhaps I'm making the mistake of reading you incorrectly. In your expert opinion, what is the most important factor in reducing braking distance? Edited October 12, 2007 by Rentabass Link to post Share on other sites More sharing options...
Eyke Supercharged October 12, 2007 Share October 12, 2007 at risk of sounding like a broken record, i'll rephrase: Cause of lockup (for non-ABS) & ABS coming on is ONLY due to high brake force applied. by saying: "grippy set of tires will set the ABS off later", you imply that "grippier" tires can somehow reduce the braking force applied. maybe you'll like to elaborate how you think that works? i no expert but i would think the following would affect braking distance: - weight of car - efficiency of braking system (brake fluid, pads, rotors, etc) - force applied on brake pedal - tire width/profile, compound, weight - rim weight & weight distribution Link to post Share on other sites More sharing options...
Rentabass Neutral Newbie October 12, 2007 Share October 12, 2007 (edited) http://www.turnfast.com/tech_brakes/brakes_balancing2.shtml Tires are scientifically proven to be a major factor in braking, along with other factors mentioned in the above article. After all, they ARE your only points of contact with the ground. Edited October 12, 2007 by Rentabass Link to post Share on other sites More sharing options...
Rasserie Neutral Newbie October 16, 2007 Share October 16, 2007 hi. im using accent 13inch. so far i cannot find good tyres that fit on 13inch Quote I believe V8 no have my size.. but V2 have rah.... time to give ur accent a new set of limbs....195/50/15 Link to post Share on other sites More sharing options...
Tkseah Turbocharged October 16, 2007 Author Share October 16, 2007 GR80 got 175/70/R13 also.. which is wat your accent needs.. U can also pm robertoon to find out which hankook got your size.. http://www.bridgestone.com.sg/storefront/C...sp?ContentId=61 Link to post Share on other sites More sharing options...
Rtth84 1st Gear October 17, 2007 Share October 17, 2007 some sizes shown are not available like whats stated at the bottom Link to post Share on other sites More sharing options...
Tkseah Turbocharged October 17, 2007 Author Share October 17, 2007 I think have leh.. at least this fella should sell.. though his price may not be the best.. http://www.myharmony.com.sg/tyreatcost.htm Link to post Share on other sites More sharing options...
Rtth84 1st Gear October 17, 2007 Share October 17, 2007 the models all very old leh G3 and so-3 discontinued liao... Link to post Share on other sites More sharing options...
King 1st Gear October 17, 2007 Share October 17, 2007 accent can use 195/55/15R Link to post Share on other sites More sharing options...
Tkseah Turbocharged October 17, 2007 Author Share October 17, 2007 195/55/R15 is a bit big... the correct R15 size for Accent is 195/50 Link to post Share on other sites More sharing options...
King 1st Gear October 17, 2007 Share October 17, 2007 more comfort mah..hanlde better also Link to post Share on other sites More sharing options...
Rentabass Neutral Newbie October 17, 2007 Share October 17, 2007 If I recall correctly, 205/50 R15 is closer to the stock rolling diameter...looks sexier too! ...but you'll need at least 15x7 rims for that... Link to post Share on other sites More sharing options...
Furrynadz 5th Gear October 17, 2007 Share October 17, 2007 205 need 6 to 6.5 only Link to post Share on other sites More sharing options...
Rentabass Neutral Newbie October 17, 2007 Share October 17, 2007 Basket...means the tire shop bluff me last time. Good information. To think just a few days ago, I was just wondering why 17x7.5 can fit up to 225 and even 235 section width, but 15x6.5 cannot accomodate 205 (according to what that tire shop told me about my old car 2 years ago). Link to post Share on other sites More sharing options...
Eyke Supercharged October 18, 2007 Share October 18, 2007 Quote hi. im using accent 13inch. so far i cannot find good tyres that fit on 13inch if you really want good tyres, then upgrade your rims. the logic is simple: if you don't mind 13" rims, you probable also won't mind lousy tyres. therefore, few, if any, manufacturers make good tyres for puny 13" rims. Link to post Share on other sites More sharing options...
Sfrtuscani Neutral Newbie October 18, 2007 Share October 18, 2007 maybe ur frnd pushed too hard...even the best tyres in the world will fail if driving beyond limits :-) Link to post Share on other sites More sharing options...
Tkseah Turbocharged October 22, 2007 Author Share October 22, 2007 Just an update that I've changed to GR80 185/60/R14.. Guess I picked the GR80 partly cos I'm curious to experience what all the acclaims are about.. ↡ Advertisement Link to post Share on other sites More sharing options...
Sg Election 2025!
Sg Election 2025!
Change Disc Rotors
Change Disc Rotors
Fatty Kim going crazy again
Tool to change Spark Plug
X for twitter change request
Soft drinks also wanna tax?
