Toalson 1st Gear October 1, 2007 Share October 1, 2007 Just a question, is it common for the left side tyres both front and back to have faster wear rate at the outer side than compared to the right side. Alignment seemed to be ok based on tyre wear on the last 10K rotation. ↡ Advertisement Link to post Share on other sites More sharing options...
Ixat 1st Gear October 1, 2007 Share October 1, 2007 I'm having the same issue. Left tires are at wear indicators and right tire still has 2-3mm more before wear indicator. So sayang to change but for the sake of safety must change! Seems like sometime through mid lifespan of the tires should remove from rim and do a swap. Link to post Share on other sites More sharing options...
Nine_eleven 2nd Gear October 2, 2007 Share October 2, 2007 it's a normal occurrence... because our cars are right hand drive, we take more sweeping right hand turns and low speed left hand turns...this will result in more front left tire wear... for normal tires, can do cross rotation to even out the wear, if directional tires, then just do normal front-to-back rotation... Link to post Share on other sites More sharing options...
Toalson 1st Gear October 2, 2007 Author Share October 2, 2007 Guess I have no choice since mine are directional tyres. Link to post Share on other sites More sharing options...
Toalson 1st Gear October 2, 2007 Author Share October 2, 2007 Cant do that cos mine are directional tyres. Link to post Share on other sites More sharing options...
Vooth 2nd Gear October 2, 2007 Share October 2, 2007 True, and also for the majority who lives in hdb estates with mscp...everyday must turn right a few times Link to post Share on other sites More sharing options...
Shorty Turbocharged October 2, 2007 Share October 2, 2007 i hv de same prob too.but mine more on de front left tyre.so much diff from de other tyres.wanna change only 1 lagi not worth it.now dunno wanna change or not... Link to post Share on other sites More sharing options...
N00b 4th Gear October 2, 2007 Share October 2, 2007 like mentioned, its due to our RHD tat givs us tis difference in the wearing of tyres Link to post Share on other sites More sharing options...
Cyberet Neutral Newbie October 2, 2007 Share October 2, 2007 its the numerous mscp we have ard sg. before, i was staying with those open air carpark, now its mscp, and i can see the obvious faster wear on my left tyres just after 3months plus Link to post Share on other sites More sharing options...
Colin03 4th Gear October 2, 2007 Share October 2, 2007 It could be your right turn vigiously on the road. rdgs Link to post Share on other sites More sharing options...
Toalson 1st Gear October 2, 2007 Author Share October 2, 2007 Oic Link to post Share on other sites More sharing options...
Toalson 1st Gear October 2, 2007 Author Share October 2, 2007 I guess so as mentioned by most of the forumers. Link to post Share on other sites More sharing options...
Yeobh 4th Gear October 7, 2007 Share October 7, 2007 (edited) Yr ride is apparently moving sideway ( crab like moving) due to camber and toe setting. If yr ride has Macpherson struts then it is 100% toe setting problem. Edited October 7, 2007 by Yeobh Link to post Share on other sites More sharing options...
Toalson 1st Gear October 7, 2007 Author Share October 7, 2007 Yup mine is macpherson struts. Guess it is still acceptable range. just a bit wear on the side. Will get the tyre shop to do alignment, didnt do it for the last rotation. Link to post Share on other sites More sharing options...
Yeobh 4th Gear October 7, 2007 Share October 7, 2007 The best method to detect wheel scuffing ( side slip) is to drive across a side slip tester. Adjusting wheels on wheel alignment ( at one point) will not detect the wheel scuffing even the toe angle maybe within specs. Link to post Share on other sites More sharing options...
Toalson 1st Gear October 8, 2007 Author Share October 8, 2007 Oic, and must i do it for every wheel or just one will do? Cos i remember the mechanic doing it the last time for the inspection. But he only did it for a single tyre but still managed to pass the inspection. Link to post Share on other sites More sharing options...
Yeobh 4th Gear October 8, 2007 Share October 8, 2007 (edited) Not necessary on two the both front wheels. Sometimes if the adjustment is very minute, adjusting one wheel should be able to take car of the camber rotating force. Edited October 8, 2007 by Yeobh Link to post Share on other sites More sharing options...
Toalson 1st Gear October 8, 2007 Author Share October 8, 2007 Sorry to trouble, but did you mean that the slip test only need to perform on a single front tyre? ↡ Advertisement Link to post Share on other sites More sharing options...
Petlas Or Giti?
Petlas Or Giti?
Is this tyre good? Made in SG!! Giti tyres!
