Hotsoup Neutral Newbie September 28, 2007 Share September 28, 2007 Hi , When we talk abt sixth element, reducing heat off the engine. Do we referring to modding air intake or something else? Thanks ↡ Advertisement Link to post Share on other sites More sharing options...
Normal_aspirated Clutched September 28, 2007 Share September 28, 2007 (edited) b4 u spend yer hard-earned marnee, i think u betta read this very old thread of year 2003........checkout here: http://www.mycarforum.com/forum/Aftermarke...er_Chip_P168142 or this webby: http://www.alibaba.com/catalog/12044575/Si...Power_Chip.html He Sixth Element power chip is a revolutionary product, researched and developed in Germany, and employing the latest cutting-edge quantum physics technology. The power chip has a influence on liquid and gas, helping them to increase the quantity of molecules, align them in a more regular pattern, and helps to promote a more efficient molecular flow. The power chip has also an influence on electrical current, enhancing a more efficient flow of the electrons. Application in Automobiles Sixth Element power chip has the following desirable results when used in Automobiles: 1. Increase in engine torque and horsepower 2. Reduction in fuel consumption 3. Reduction in temperature of the exhaust air from the engine ( up to 100 degree C) BEFORE 730 AFTER 630 4. Reduction in engine oil temperature 5. Increase in ignition voltage 6. Improvement in brake performance 7. Improvement in efficiency of turbo engine 8. Reduction in carbon build-up in engine 9. Improvement in shock absorber performance 10. Enabling the air-conditioner to be colder i still think u betta keep yer marnee fer a proper ECU upgrade. Edited September 28, 2007 by Normal_aspirated Link to post Share on other sites More sharing options...
Hotsoup Neutral Newbie September 28, 2007 Author Share September 28, 2007 (edited) thanks. My intention is looking at ways to maintain the ideal engine temp during ride or static mode Edited September 28, 2007 by Hotsoup Link to post Share on other sites More sharing options...
Normal_aspirated Clutched September 28, 2007 Share September 28, 2007 (edited) too good to be true isn't it? is like yer car wearing amulets (lucky charm)........ Edited September 28, 2007 by Normal_aspirated Link to post Share on other sites More sharing options...
Hotsoup Neutral Newbie September 29, 2007 Author Share September 29, 2007 sound like wearing diamond Link to post Share on other sites More sharing options...
Dwoon 1st Gear September 29, 2007 Share September 29, 2007 If you've not done anything to your car or do not drive the car hard and for long periods.... then the stock car cooling system should be fine. Link to post Share on other sites More sharing options...
Hotsoup Neutral Newbie September 29, 2007 Author Share September 29, 2007 cool..any recommand method of maintaining engine efficient? Tks Link to post Share on other sites More sharing options...
Followthelaw Neutral Newbie November 6, 2007 Share November 6, 2007 My car radiator got 2 fans,engine cool man,and efficient,pick up no problem,high end esp good. ↡ Advertisement Link to post Share on other sites More sharing options...
SCHNELL Engine Oil 5W40
P2096 Check engine light
DIY engine oil change
