Gary84 1st Gear September 21, 2007 Share September 21, 2007 answer?? ↡ Advertisement Link to post Share on other sites More sharing options...
Sturtles 6th Gear September 22, 2007 Share September 22, 2007 Just a brain teaser Qn for you: 2 pipes takes 5 minutes to fill up a tank, and the smaller pipe alone takes 6 minutes more than the bigger pipe to fill the tank. How long would it takes for the bigger pipe to fill the tank alone? I will provide the answer shortly. Is it 8.653minutes? This question seems to also test the rationality of the students. Should be O-levels type of questions Link to post Share on other sites More sharing options...
Relagsingh 4th Gear September 22, 2007 Share September 22, 2007 5 mins? Link to post Share on other sites More sharing options...
Wolverman Neutral Newbie September 22, 2007 Share September 22, 2007 Just a brain teaser Qn for you: 2 pipes takes 5 minutes to fill up a tank, and the smaller pipe alone takes 6 minutes more than the bigger pipe to fill the tank. How long would it takes for the bigger pipe to fill the tank alone? I will provide the answer shortly. Correct your grammar dude Link to post Share on other sites More sharing options...
Enotsol Neutral Newbie September 22, 2007 Share September 22, 2007 The exact answer was given by Xtraun but seeing that this is supposed to be a brain teaser and not a number crunching game... I wonder if there's some catch to it.. Link to post Share on other sites More sharing options...
Jman888 Moderator September 22, 2007 Share September 22, 2007 elementary math means E maths in A level or PSLE maths? I think someone who dunno this would still be able to get through degree in accountancy in my times.. accounting is creative maths, has nothing to do with real maths Link to post Share on other sites More sharing options...
Cavver 4th Gear September 22, 2007 Share September 22, 2007 2.5 min ??? Link to post Share on other sites More sharing options...
Yc86 Clutched September 22, 2007 Share September 22, 2007 here's my attempt: s = small pipe b = big pipe s + 6min = b ---- 1 b + s = 5min s = 5min - b ------- 2 sub 2 into 1 5min - b + 6min = b b = 5.5mins am i correct? Link to post Share on other sites More sharing options...
Kingkong 5th Gear September 22, 2007 Share September 22, 2007 5( x/(y+6) + x/(y)) = x5y + 5y + 30 = y^2 + 6y y^2 - 4y - 30 = 0 y = (4 + 11.66)/ 2 = 7.83 I just couldn't get the last line out... But that should be the answer. Link to post Share on other sites More sharing options...
Chevypower Neutral Newbie September 22, 2007 Share September 22, 2007 (edited) my guess is 9mins. 9 + 6 = 15 9/15 x 5 = 3 6/15 x 5 = 2 3+2 = 5. hehehe... wild wild guess..... :) Edited September 22, 2007 by Chevypower Link to post Share on other sites More sharing options...
Leslielai 1st Gear September 22, 2007 Share September 22, 2007 (edited) You smell like a thoroughly incompetent tutor to me. It is not the first time you are posting mathematical questions in this forum and each time you expect people to come up with complete answers for you. So, are you one? Edited September 22, 2007 by Leslielai Link to post Share on other sites More sharing options...
Guyver 1st Gear September 22, 2007 Share September 22, 2007 (edited) Just a brain teaser Qn for you: 2 pipes takes 5 minutes to fill up a tank, and the smaller pipe alone takes 6 minutes more than the bigger pipe to fill the tank. How long would it takes for the bigger pipe to fill the tank alone? I will provide the answer shortly. Wah chim ... Edited September 22, 2007 by Guyver Link to post Share on other sites More sharing options...
Sfhuang Clutched September 22, 2007 Share September 22, 2007 Let the time for the bigger pipe to fill the tank alone be x minutes. (0 That means it would take the smaller pipe 6+x minutes to fill up the tank. Put the small pipe into one tank and the bigger pipe into another similar tank, in 6+x minutes you would have 1 filled tank (from the small pipe) and (6+x)/x full tank (from the big pipe). Now that means that both pipes put together would fill 6/x+ 1 + 1 tanks in 6+x minutes. From the fact that the 2 pipes put together takes 5 minutes to fill up 1 tank, we then have by virtue of direct proportion: [6/x+2]/1=[6+x]/5 30+10x=6x+x^2 x^2-4x-30=0 Solving the quadratic equation: We get x=7.83 or x=-3.83(rejected) So my answer is it takes the bigger pipe 7.83 minutes to fill the tank alone. [QED] Link to post Share on other sites More sharing options...
Sfhuang Clutched September 22, 2007 Share September 22, 2007 Steady same answer. Link to post Share on other sites More sharing options...
Chembeng Neutral Newbie September 22, 2007 Share September 22, 2007 5( x/(y+6) + x/(y)) = x5y + 5y + 30 = y^2 + 6y y^2 - 4y - 30 = 0 y = (4 + 11.66)/ 2 = 7.83 Quite a creative way to introduce 2 variables with different units - x is tank volume, y is L.P. rate. You could simply do without x. Do 'rate' balance, and u can skip first line. Good still. Link to post Share on other sites More sharing options...
Mummypenguin Neutral Newbie September 22, 2007 Share September 22, 2007 Just a brain teaser Qn for you: 2 pipes takes 5 minutes to fill up a tank, and the smaller pipe alone takes 6 minutes more than the bigger pipe to fill the tank. How long would it takes for the bigger pipe to fill the tank alone? I will provide the answer shortly. I've a feeling that this is a Pri school question that you need to use model to solve. My try: Time taken for big pipe to fill tank = B Time taken for small pipe to fill tank = B+6 Time taken for fill 2 tanks using both pipes = B+B+6 = 2*5min So 2B + 6 = 10 B = 2 correct? Trying very hard to follow my P2's math text, hoping that next time I'll be able to teach her using the model's method i.s.o algebra. Are you a parent trying to teach your kid or are you really a tutor that can't solve your students' questions? Because I've also notice that you usually ask for solutions to math questions. Link to post Share on other sites More sharing options...
Poper 2nd Gear September 22, 2007 Share September 22, 2007 Hhmmm... the TS has not made any response since day 1... Link to post Share on other sites More sharing options...
Poortraveller 1st Gear September 22, 2007 Share September 22, 2007 assuming the flow rate is the same ... bigger pipe will fill up the tank faster, my guess should be <6min ↡ Advertisement Link to post Share on other sites More sharing options...
PSLE Math: Is It Really That Tough? How Should Students Tackle Difficult Questions In The Exam?
South Korea reports first death from ‘brain-eating amoeba’
Girls vs. Boys: Brain Differences Might Explain Tech Behaviors
He went through brain surgery while awake
'heaviest recorded' brain tumour
"The Brain", "最强大脑"
"The Brain", "最强大脑"
Speeding With No Brain (200km/h)
Bird's Brain, They Are Smarter Than You Thought ......
