Kyojin 1st Gear September 17, 2007 Share September 17, 2007 1. ok, whenever i go really slow over humps or road irregularities, the rear suspension seems to be squeaking. like "quuuiick quuuuick" does this mean the shocks are goners? or is this because of the bouncier shortened springs? if i am correct, i have KYB sports adjustables + shortened EP80 springs. 2. also when reversing, seems like there's squeaking from the wheels. no brakes applied. doesn't sound too normal... what gives? no noise going forward. 3. brake squeals when braking lightly, but firm braking does not produce any noise. Ferodo pads. are they gone? ↡ Advertisement Link to post Share on other sites More sharing options...
Kyojin 1st Gear September 17, 2007 Author Share September 17, 2007 when is the next meet up? maybe some bros can see if i'm too paranoid Link to post Share on other sites More sharing options...
Route88 2nd Gear September 17, 2007 Share September 17, 2007 Squeeks sound most prob come from the spring....what do you mean by shortened spring,did you cut it? Link to post Share on other sites More sharing options...
Kyojin 1st Gear September 17, 2007 Author Share September 17, 2007 it was cut (by the previous owner) Link to post Share on other sites More sharing options...
Route88 2nd Gear September 17, 2007 Share September 17, 2007 Better dont use tis type of spring As for reverse squeeks...try checking the wheel bearing. Brake squeek....pad or rotor dont like each other Link to post Share on other sites More sharing options...
Cavver 4th Gear September 17, 2007 Share September 17, 2007 Cut ??? Link to post Share on other sites More sharing options...
Kyojin 1st Gear September 17, 2007 Author Share September 17, 2007 yes. cut, to lower. many people do this to save cost on lowering springs, but it screws up the spring rates... yea Route88 i figured it was to do with the springs. as for the brake squeals, i think it's just being finicky, but i will try to take a look at the pads when i rotate the tyres. Link to post Share on other sites More sharing options...
Dionyeo Neutral Newbie September 17, 2007 Share September 17, 2007 change your springs before anything happens. for your safety. Link to post Share on other sites More sharing options...
Kyojin 1st Gear September 18, 2007 Author Share September 18, 2007 dion bro, any recommendations? Link to post Share on other sites More sharing options...
Kazuo Neutral Newbie September 18, 2007 Share September 18, 2007 his brake pad is rather new leh... don't think so fast gone la. Link to post Share on other sites More sharing options...
Emperor Clutched September 18, 2007 Share September 18, 2007 join us for meet up. We'll check your car and give you a diagnostics. just like we did to all the other cars.... No seriously... join us for meet up and we'll do a diagnostic. Link to post Share on other sites More sharing options...
Mcff_1980 Neutral Newbie September 18, 2007 Share September 18, 2007 sorry to hijack, do u guys experience the suspension give out a soft "farting" sound sometimes when u sitting in the car with engine off? wonder whats wrong or is it normal Link to post Share on other sites More sharing options...
Kyojin 1st Gear September 18, 2007 Author Share September 18, 2007 u sure not ur gf? hehe usually will be more of a gentle 'psssssss' sound. B>> yea, sure i will watch out for the next meetup, then you sifus can sort me out. Link to post Share on other sites More sharing options...
Satinepink Neutral Newbie September 18, 2007 Share September 18, 2007 Change your bearings and your springs. The cut springs are screwing your shocks. Link to post Share on other sites More sharing options...
Kyojin 1st Gear September 18, 2007 Author Share September 18, 2007 sounds sensible. how much would wheel bearings set me back? Link to post Share on other sites More sharing options...
Satinepink Neutral Newbie September 19, 2007 Share September 19, 2007 last time i changes, did it as a complete package, caliper-rotors-bearings. one time labour charge. should set you back by, i think, 70 per side. Link to post Share on other sites More sharing options...
Emperor Clutched September 19, 2007 Share September 19, 2007 when you're standing outside the car.. the car goes over the hump the sound it gives the same sound. This is normal. Its your gas absorbers in action. But usually it only produces the sound when its pressed hard. If you hear this when you sit in your car.. think something might not be right.. unless you're really heavy...(apologies). Link to post Share on other sites More sharing options...
Mcff_1980 Neutral Newbie September 19, 2007 Share September 19, 2007 usually if go over hump.. the normal sound for shocks should be slight creaking or "Eee" "eee" sound. but the sound i encounter when the car is parked for a period of time something like farting sound "WOOooo.." haha.. by the way im not heavy, in fact im quite light la ↡ Advertisement Link to post Share on other sites More sharing options...
Brake squeak every morning
Gearbox issues; and problems at VW Service Centre
Common Problems with Optra 5
Headlight problems with modern cars?
Squealing/Squeaking brakes
Anybody experience problems engaging gear for Fiat Punto?
Hybrid cars - any problems?
Power window problems
