DarkLord 1st Gear October 22, 2007 Share October 22, 2007 No more juddering. Kena conned by AD to change wiper blades and removed my sunshade also cannot solve juddering! ↡ Advertisement Link to post Share on other sites More sharing options...
Haurus85 Neutral Newbie October 22, 2007 Share October 22, 2007 Wah..AD change wiper blade cost how much? Can DIY 1 lehz.. And sunshade will cause juddering? First time i heard of such things.. Link to post Share on other sites More sharing options...
Maddriver 4th Gear October 24, 2007 Author Share October 24, 2007 Link to post Share on other sites More sharing options...
Marcoin Neutral Newbie October 24, 2007 Share October 24, 2007 If I finished Polished, then seal, can I use AW as wax and how long will AW last as wax? Should I apply collinite wax instead and use AW after that? Please advise Benny. Link to post Share on other sites More sharing options...
Maddriver 4th Gear October 25, 2007 Author Share October 25, 2007 AW is a sealant..We use it mostly as a topper for collinite or #105.. Link to post Share on other sites More sharing options...
Crabby Neutral Newbie October 27, 2007 Share October 27, 2007 Hi Maddriver, I am a friend of gadgeter. You have any stock of #845 and the drying cloth? Would like to get 3 sets. Link to post Share on other sites More sharing options...
Maddriver 4th Gear October 29, 2007 Author Share October 29, 2007 Hi Bro Crabby, Yes,i have stock for #845.. My waffle weave towel..wax applicators and wash mitt will arrive early Nov..once is here .. you want me to pass to Gad? Link to post Share on other sites More sharing options...
Ken_leong 2nd Gear October 29, 2007 Share October 29, 2007 #253 comes with applicator? Link to post Share on other sites More sharing options...
Baluku Neutral Newbie October 29, 2007 Share October 29, 2007 Quote I have another trick on #105 and AW application ... remind me to let you know when we met during the detailing session.. Bro wat tip, share leh? my car shine getting muted le, need new method to revive it! Link to post Share on other sites More sharing options...
Maddriver 4th Gear October 29, 2007 Author Share October 29, 2007 u never maintain si bo... Link to post Share on other sites More sharing options...
Maddriver 4th Gear October 29, 2007 Author Share October 29, 2007 No bro... Link to post Share on other sites More sharing options...
Holyavartar Clutched October 29, 2007 Share October 29, 2007 Quote I have another trick on #105 and AW application ... remind me to let you know when we met during the detailing session.. Hey bro, i aso interested to know ur the other trick on #105 and AW application leh cuz i had tried the one that you had stated earlier. Really impressed & wanted to try something new. Link to post Share on other sites More sharing options...
Civicfd Neutral Newbie October 29, 2007 Share October 29, 2007 Maddetailer, I brought a #476 from you a couple of months back and I must say an 'impressive' wax, no regret . Last week, I have coated a two layers of sealant and topped off with #476 but [sunny] until 'the ant slipped and fell off'. After a week, small dotted Tar can be seen all over the place & oxidation started to form . If I use #101 or clay, all my sealant & wax will be ripped off (what a waste). May I ask, what is the best & effective method to remove the stained Tar/road grime without removing of coated sealant and #476? Link to post Share on other sites More sharing options...
Maddriver 4th Gear October 30, 2007 Author Share October 30, 2007 Hi Bro.. I guess is a white FD rite..for white..usually tar can be notice easily..actually if mild abrasive type of clay..it will not strip sealant or #476.. u can try to use a QD with good cleaning properties to clean away tars or road grimme.. i have tried #521 on white and it works.. Link to post Share on other sites More sharing options...
Civicfd Neutral Newbie October 30, 2007 Share October 30, 2007 (edited) Maddetailer, rite, white FD, we met at Hougang Stadium. You are a good man. The #476 is real good wax, ease of application, wet & have a depth sliky look (attached pix). Can I ask you, after a few days on the #476, I run my finger on the surface, I can feel that the wax stick on my finger. It seems like the wax does not have a strong bonding into the surface although it can last. While I know that most of the wax will slowly wear off, is there any solution to extend the #476 and stay on the surface further? I'll call you tomorrow for the #521. Edited October 30, 2007 by Civicfd Link to post Share on other sites More sharing options...
Ken_leong 2nd Gear October 30, 2007 Share October 30, 2007 Quote Some of us may encounter a little hazy after a day with Collinite#476 on the bonnet.This is what you can do to solve it. 1)Apply #476 2)Before buffing it away,spray DG#951 AW on it.Spread it with the applicator 3)Buff everything off.. Second 1)Instead of damping the wax applicator,spray a bit of #951AW on the applicator 2)Apply wax with the applicator damp with #951AW .. 3)Dun drools For DG#105 1)Use #101 to clean up surface. 2)If you are using #601 PBA,apply it after buffing #101 away.Let PBA haze for at least 15mins. 3)Spray a bit of #951 AW on the applicator,if you have those mist sprayer,spray a bit on surface, 4)Dun need to buff away PBA 5)Apply #105 6)Haze for 15mins and remove. 7)Dun drools Got a question. Can I drive off after I apply and buff off PBA and #105? Cos my part of my bonnet became hazy. Was wondering if I applied wrongly or it's due to the heat from the engine. Am I supposed to let it cure for at least 4 hrs before moving off? Link to post Share on other sites More sharing options...
Maddriver 4th Gear October 31, 2007 Author Share October 31, 2007 Hi Ken.. there is no problem driving off after applying #601 and #105.. few things to take note.. 1) Try not to apply on hot surfaces 2) sometime uneven application may causes the patechy effect.. 3) Surface prep is very impt.. Use #101 if necesssary 4) Always remember to apply thin layer.. try to dam wax applicator with water for application 5) If you encounter hazy..use a QD to run down it again.. Link to post Share on other sites More sharing options...
Maddriver 4th Gear October 31, 2007 Author Share October 31, 2007 Hi Bro.. thanks for the compliment.. the feeling is actually like the warm and oily rite? wax is basically another layer of coating .. dun worry abt #476 wearing off..it will last up to couple of mths.. ↡ Advertisement Link to post Share on other sites More sharing options...
Attention all Duragloss #951 Aquawax user.
Marbella DashCam Users
Audi A4/A5 Sportback owners thread
Time to buy some US dollar?
THINKWARE / INAVI Users, Come In
For Android Users, Google Play Celebrates 25 Billion Downloa
