Llfr Neutral Newbie September 10, 2007 Share September 10, 2007 What's the difference between the SOHC and DOHC. I have read up on the definitions but I still don't understand. ↡ Advertisement Link to post Share on other sites More sharing options...
Porker Turbocharged September 10, 2007 Share September 10, 2007 SOHC = Single Overhead Cam DOHC = Double Overhead Cam SOHC = 2 valves (1 intake and 1 exhaust) DOHC = 4 valves (2 intake and 2 exhaust) Hope I'm correct also Link to post Share on other sites More sharing options...
Quantum 5th Gear September 10, 2007 Share September 10, 2007 this is quite interesting topic, do a search in MCF you will find many many... discussion regarding SOHC and DOHC good luck Link to post Share on other sites More sharing options...
Seanboi 1st Gear September 10, 2007 Share September 10, 2007 Maybe u can do a search on Wikipedia to learn more? DOHC more power at high end. Link to post Share on other sites More sharing options...
Llfr Neutral Newbie September 10, 2007 Author Share September 10, 2007 I did a search and understand the different valves involved. Does SOHC and DOHC valves both opens up at 5000rpm once which is different from the VTEC SiR model? Link to post Share on other sites More sharing options...
Mcff_1980 Neutral Newbie September 10, 2007 Share September 10, 2007 very simple lar SOHC = One leg hopping DOHC = two leg running so which faster? Link to post Share on other sites More sharing options...
Mcff_1980 Neutral Newbie September 10, 2007 Share September 10, 2007 (edited) with a vafc, u can easily set what point u wan vtec to kui Edited September 10, 2007 by Mcff_1980 Link to post Share on other sites More sharing options...
Porker Turbocharged September 10, 2007 Share September 10, 2007 VTEC and SOHC/DOHC are totally unrelated concepts. VTEC = opening more of the valve via lift so the engine can breathe better (sorta like the human nose) SOHC/DOHC = number of cams and valves More valves = Engine breathes better cos more openings VTEC is controlled by the cam design. Link to post Share on other sites More sharing options...
Llfr Neutral Newbie September 10, 2007 Author Share September 10, 2007 Then how come a 92' civic vti DOHC opens once and a 96' civic Sir DOHC opens twice? Sorry ah.. I'm a noob to VTEC Link to post Share on other sites More sharing options...
Quantum 5th Gear September 10, 2007 Share September 10, 2007 One leg hopping is faster coz, 'One leg hopping' Honda Civic eats most 'two leg running' cars in same sergment Link to post Share on other sites More sharing options...
Crummytyre Neutral Newbie September 10, 2007 Share September 10, 2007 Blame Honda marketting. There are so many versions of VTEC that it confuses everybody. The different versions of VTEC are common in name only. They are very different engines with very different working principles. Some are brilliant, some are not so fantastic. But since they are all badged as VTEC.... Link to post Share on other sites More sharing options...
Vidz 6th Gear September 10, 2007 Share September 10, 2007 Quote very simple lar SOHC = One leg hopping DOHC = two leg running so which faster? when running very fast, 2 legs faster but when hopping, one leg faster cos, 2 legs are heavier when sitting down, no diff Link to post Share on other sites More sharing options...
Route88 2nd Gear September 10, 2007 Share September 10, 2007 Nowadays SOHC come with 16 valve...4 valves per cyclinder 2 intake,2 xhaust Link to post Share on other sites More sharing options...
Porker Turbocharged September 10, 2007 Share September 10, 2007 Oops hehe Link to post Share on other sites More sharing options...
Mcff_1980 Neutral Newbie September 10, 2007 Share September 10, 2007 Quote Then how come a 92' civic vti DOHC opens onceand a 96' civic Sir DOHC opens twice? Sorry ah.. I'm a noob to VTEC 92vti b16a2 is about the same as the 96sir b16a4, just that the b16a4 got about 10 more bhp. both vtec open once. if u say vtec open twice, should be the b18c (integra dc2) Link to post Share on other sites More sharing options...
Quantum 5th Gear September 10, 2007 Share September 10, 2007 (edited) as the manufacture tech improving, SOHC will takeover back DOHC in small cc engine honda civic is a good example Edited September 10, 2007 by Quantum Link to post Share on other sites More sharing options...
Mcff_1980 Neutral Newbie September 10, 2007 Share September 10, 2007 Quote One leg hopping is faster coz, 'One leg hopping' Honda Civic eats most 'two leg running' cars in same sergment agree Link to post Share on other sites More sharing options...
Route88 2nd Gear September 10, 2007 Share September 10, 2007 SOHC and DOHC already being discussed,go and do a search. If between both on Honda engine,you might wanna highlight,what type of engine code do you refer too. There are differences cos type of cams Honda use. ↡ Advertisement Link to post Share on other sites More sharing options...
Income tax Evasion
Income tax Evasion
This is the REAL VTEC! VTEC IS THE BEST! 真正的 VTEC!
Whats's the difference between rubbing compound and polishing compound?
What is the difference between Honda civic FD1 & FD2
Nets cards - what's the difference
Carburetor (or Carburettor if UK) servicing, what a difference!
COE Honda Integra DC5
