Thermodynamics Neutral Newbie August 18, 2007 Share August 18, 2007 Hi all Is there a proper way to adjust our car seat to get the best driving position? Can share what you know and what you do? Nowadays cars come with telescopic steering wheel. My ride is equipped with it but I never adjust it all. ↡ Advertisement Link to post Share on other sites More sharing options...
Jayq Neutral Newbie August 18, 2007 Share August 18, 2007 Normal I will depress the clutch fully make sure my leg is not fully straigtened. Link to post Share on other sites More sharing options...
Toyo 1st Gear August 18, 2007 Share August 18, 2007 As long as u r comfortable with it Link to post Share on other sites More sharing options...
Ghostrider 3rd Gear August 18, 2007 Share August 18, 2007 Adjust your seat so that your leg when pressing fully on the brake or accelerator is not straight. It should be slightly bend. Hands on steering wheel and your arms should be bend at an angle of around 90 degree. Seat belts should be firm...you should be able to slip your fist between the belt and your body without any problem. If you can adjust the belt height from the B-pillar, it should slip over your shoulder and not higher or lower. Sitting position should be slightly lean back (while maintaining your steering-arm position). Centre of the headrest should be at the back of your head to protect it from whiplash. I tot this kinda thingy learn driving that time would have taught you already ? Returned to the coach liao ah ? Link to post Share on other sites More sharing options...
Singaporesiao Neutral Newbie August 18, 2007 Share August 18, 2007 my coach nv say so much leh... only mention that the legs when cluch in cannot be straight.. the arms n headrest part nv mention... Link to post Share on other sites More sharing options...
Rustyz 5th Gear August 18, 2007 Share August 18, 2007 To me as long as you comfortable with good room leg space and able to reach out the pedal with ease. As for me what I feel the most important thing is back and neck support which will let you enjoy your journey. Link to post Share on other sites More sharing options...
Sony 1st Gear August 18, 2007 Share August 18, 2007 It's in the book.. either advanced or Basic theory... Link to post Share on other sites More sharing options...
Sony 1st Gear August 18, 2007 Share August 18, 2007 Sit inside the car.. driver side hor.. see, feel, observe and turn left and right. check that you are comfortable, otherwise adjust accordingly. The best position is the position you like best. We can tell you till the cow come home that model A is the best but if you don't like it, it will not work. I, myself got different sitting position for the type of driving I'm doing. so there's no 1right driving posture for myself as well. Link to post Share on other sites More sharing options...
Ccjna Clutched August 18, 2007 Share August 18, 2007 Hi all Is there a proper way to adjust our car seat to get the best driving position? Can share what you know and what you do? Nowadays cars come with telescopic steering wheel. My ride is equipped with it but I never adjust it all. Usually, i dun adjust the car seat. i will just start the engine & go liao. Link to post Share on other sites More sharing options...
Thermodynamics Neutral Newbie August 18, 2007 Author Share August 18, 2007 But comfortable may not mean the best position right? Link to post Share on other sites More sharing options...
Thermodynamics Neutral Newbie August 18, 2007 Author Share August 18, 2007 Let's say for a long drive up Malaysia. What driving position you use? Link to post Share on other sites More sharing options...
Thermodynamics Neutral Newbie August 18, 2007 Author Share August 18, 2007 What about seat height? Is there a recommended position? Or just as we like it? Link to post Share on other sites More sharing options...
Thermodynamics Neutral Newbie August 18, 2007 Author Share August 18, 2007 What about the telescopic steering wheel? Meant for people with long legs and short arms? Link to post Share on other sites More sharing options...
Sony 1st Gear August 18, 2007 Share August 18, 2007 (edited) I use the position that is not upright coz there's no direct corner or short distance to judge. At the slanting position, it allow a direct sight of the longer distance ahead which is inline with the speed travelled. and I'm not stress up with an upright position. How to adjust, it's your own preference edit: in twist and winding road, i would sit upright, close to the steering wheel coz it allow quite movement and easy control of gear shift. but the above is just me. Otherwise can have their own way to drive. Edited August 18, 2007 by Sony Link to post Share on other sites More sharing options...
Sony 1st Gear August 18, 2007 Share August 18, 2007 (edited) equate to the height of your car's overhanging distance. You shd be able to see or judge the end. but people can determine which height they want. It's their own car and their own judgement. otherwise how come you can't see the short tai tai in their S class or 7 series Edited August 18, 2007 by Sony Link to post Share on other sites More sharing options...
Thermodynamics Neutral Newbie August 18, 2007 Author Share August 18, 2007 Do you bother to adjust the tilt angle of your steering wheel and its telescopic extension? Link to post Share on other sites More sharing options...
Sony 1st Gear August 18, 2007 Share August 18, 2007 ya... why not... No one have a fix sitting height and reach.. Link to post Share on other sites More sharing options...
Toyo 1st Gear August 18, 2007 Share August 18, 2007 But comfortable may not mean the best position right? But if it is the best position but not comfortable also cannot, right? ↡ Advertisement Link to post Share on other sites More sharing options...
Drink Driving Is An Act Of Irresponsibility!
Boomers on the road should take mandatory tests
Worth to be a Grab Driver now?
All the best to parents of PSLE candidates
Who's your favorite lau-chiobu actress ?
Class 4 Driving License
