En0203 2nd Gear August 17, 2007 Share August 17, 2007 I reach 6 gear everytime I drive because I shift at 1,300rpm. Don't even need to go above 2,000rpm. So yeah I hit 6 and cruise at 1,200rpm thereabouts. Why not? bro, ur car's low end only turbo diesel can match leh... ↡ Advertisement Link to post Share on other sites More sharing options...
Mormort Neutral Newbie August 17, 2007 Share August 17, 2007 Heard that the engine is totally different from evo 8 & 9. what will be the price at ? Link to post Share on other sites More sharing options...
Weichien Clutched August 17, 2007 Share August 17, 2007 Have received information from Japan regarding EVO 10 SpecsEstimation arrival date nov-dec 3 Models RS 5MT GSR 5MT GSR TC-SST (twin clutch sst 6AT with pedal shift) Size.Weight L - 4495mm W - 1810mm H - 1480mm Wheel base - 2650mm Front and rear - 1540mm Weight RS = 1420kg GSR = 1520kg GSR TC-SST = 1540kg Engine TYPE - 4B11MIVEC I/C/T/C VALVE SYSTEM .No. of Cylinder - DOHC 16V INLINE 4 CYLINDER Inside Diameter x operation - 86.0 x 86.0 Total Displacement - 1998L Compressure Ratio - 9 Max Power [NET] kW/rpm- 206[280PS]/6500 Max Torque (N.m/rpm - 422[43.0kg-fm]/3500 Fuel Supply Sytem - ECI-Multi (Electronic Control Injection) Tank capacity RS - 50 GSR/GST TC-SST - 55 Driving System Steering - Rack and Pinion Suspension FRONT - MC PHERSON STRUT REAR - MULTI LINK Ventilated Disc Brake RS -15" (front and rear) GSR/GSR TC-SST - front 18" , rear 17" Tire Size RS - 205/60R16 GSR/GSR TC-SST - 245/40R18 DRIVELINE RS/GSR 5MT 1st - 2.857 2nd - 1.950 3rd - 1.444 4th - 1.096 5th - 0.761 Reverse - 2 892 Final Recuced change gear ratio - 4.687 GSR 6 Speed Twin Clutch SST 1st - 3.655 2nd - 2.368 3rd - 1.754 4th - 1.322 5th - 1.008 6th - 0.775 Reverse - 4.011 Final Recuced change gear ratio - 4.062 I have left out the detail equipment list (2pages ++, dunnoe how to type all out) Hope the information above is sufficent for all forumers who love evo to discuss and feedback and compare with the evo 9 MR :) Have a Good day bros. Cheers :) Regards Ashley wow. too bad i can only afford the 2nd fiddle of evo. LANCER. haha.or evo 7 at most. Link to post Share on other sites More sharing options...
Weichien Clutched August 17, 2007 Share August 17, 2007 bro poker. what horse u riding Link to post Share on other sites More sharing options...
Falc 3rd Gear August 17, 2007 Share August 17, 2007 6 speed more suited for sports cars mah. STI is 6 speed, WRX 5 speed. All the Honda Rs nowadays are 6 speed. Even hot hatches like Focus ST, GTI and Megane RS are 6 speeders. Now EvoX GSR MT only 5 speed. How to pass? Only rationale is they want to sell more SST. Link to post Share on other sites More sharing options...
Ashley1108 1st Gear August 17, 2007 Author Share August 17, 2007 I agree with you thou. Actually to me, there's both pros and cons for 5 speed and 6 speed yea? It all ties down to the user perference only. Dun you all agree? Anyway i really learn alot from this thread i started. To be frank, i only know minimal knowledge on turbo charged car as i'm more active in SHC forum and most of my customers and friends are from there. Now with EVO X, i'm learning more things in this thread and also evoclub. Like what they always say, Every day is a learning phase for every man Cheers :) Link to post Share on other sites More sharing options...
Falc 3rd Gear August 17, 2007 Share August 17, 2007 No worries. Actually 5 speed should suffice for TC cars with huge torque. Eg LGT Spec B 280hp only 5 speed, IIRC. But then Legacy is not the same as Evo. While it's user preference, the manufacturer should consider the typical user profile. I don't think people who buy EVO GSR, somemore, will not kiasu to want the best out there (6 speed) even if they may not find it that useful. Link to post Share on other sites More sharing options...
Ashley1108 1st Gear August 17, 2007 Author Share August 17, 2007 That's true thou. However don't you think there might be some reason for doing it this way? Any speculation apart from claiming that Japan are trying to push their TC-SST Link to post Share on other sites More sharing options...
Porker Turbocharged August 17, 2007 Share August 17, 2007 My horse has 3350 brake husky power. Max torque at 1,300rpm and stays flat all the way till 5,000rpm hehe Link to post Share on other sites More sharing options...
Masschaoz Neutral Newbie August 17, 2007 Share August 17, 2007 nt true, im currently drivin a CT9A and at 80km/hr on 5th gear, rpm is at abt 3k liao. 6 speeder are gd for drag keekee. and also enable the car to be kept at optimal powerband. but 5 speeder also has it pros too. the pullin gear on highend is impressive keekee. i second ur opinion on this... kekeke.. i always hit 6th gear almost everywhere also.. i love our 1st gear pullllll... hahahah/.. Link to post Share on other sites More sharing options...
Wrcfan 1st Gear August 17, 2007 Share August 17, 2007 (edited) Actually on expressways not possible not to hit e 6 speed, how to cruise normally at 100km/h with the rpm above 3k on 5th? Maybe on track like PG where a 6speeder not appropriate cos got to shift alot as band too close, e 5speed's more idea. Edited August 17, 2007 by Wrcfan Link to post Share on other sites More sharing options...
Falc 3rd Gear August 18, 2007 Share August 18, 2007 However don't you think there might be some reason for doing it this way? My guess, either pushing SST or ... cut cost. Ok one more, maybe 5 gear is enough to match the engine characteristics perfectly already. Link to post Share on other sites More sharing options...
Vblaster_w211 2nd Gear August 18, 2007 Share August 18, 2007 Here's the reason why 6MT is used for DC5R. It is an NA engine that produces its power band at high revs. Hence we need close ratios to maintain that high revs to extract the power. However, that'll mean a high rpm for cruising also, hence the provision of the 6th gear. For TC engines, it may not need the 6th gear, as TC power and torque bands usually kick in a bit lower, so the gear ratios need not be so close. Link to post Share on other sites More sharing options...
Mmatrix Neutral Newbie August 18, 2007 Share August 18, 2007 Whats the diff?? GSR SST = 138k GSR SST premium = 153k Link to post Share on other sites More sharing options...
Ashley1108 1st Gear August 18, 2007 Author Share August 18, 2007 Mainly it's cosmetic differences. I'll post it up tml or monday. My equipment and spec sheet for evo X is in the office lol. Anyway the price above mention is not from me. Link to post Share on other sites More sharing options...
Ashley1108 1st Gear August 18, 2007 Author Share August 18, 2007 nt true, im currently drivin a CT9A and at 80km/hr on 5th gear, rpm is at abt 3k liao. 6 speeder are gd for drag keekee. and also enable the car to be kept at optimal powerband. but 5 speeder also has it pros too. the pullin gear on highend is impressive keekee. i second ur opinion on this... kekeke.. i always hit 6th gear almost everywhere also.. i love our 1st gear pullllll... hahahah/.. IcIc. Thanks for the insight coz i really not very sure Thus there's pros and cons for 5spd and 6spd for a TC car, however to summarise, which one will be a better choice in terms of performance for a TC car? Sorry i'm not very good in TC cars so need to learn from you guys to become this ----> Link to post Share on other sites More sharing options...
Falc 3rd Gear August 19, 2007 Share August 19, 2007 There's no one size fits all answer. Though 5sp may fit TC better than NA, still it depends. So await your 5sp MT customer review. I suspect the 6sp auto MT will be a much more popular choice for GSR though. Link to post Share on other sites More sharing options...
Ashley1108 1st Gear August 19, 2007 Author Share August 19, 2007 I'll definitely post the reviews up very soon. One of my colleague getting the GSR 5MT, thus i'll be able to test it and leave my comments here. ↡ Advertisement Link to post Share on other sites More sharing options...
2019 Honda Accord PHEV Specs
Traffic light infrastructure
Replacing front tyres with different specs
Not confirm yet???
Not confirm yet???
Can anybody confirm this?
Specs of the World CHEAPEST Car
How to throw get rid of old specs
Lexus LFA N
Lexus LFA N
