Casey Neutral Newbie August 8, 2007 Share August 8, 2007 Any brothers here have amphifier and have found a way to prevent the knobs behind from "oxidising" thereby forming a grey rust. My 2 months old Denon knobs is starting to oxidised, have to rub it to give it its shine. For illustration purposes on the knobs im referring to.... ↡ Advertisement Link to post Share on other sites More sharing options...
Typhoonz 4th Gear August 8, 2007 Share August 8, 2007 I use a bit of WD40 to clean it... Just spray some on a cloth and give it a good wipe... Link to post Share on other sites More sharing options...
Apollo 1st Gear August 8, 2007 Share August 8, 2007 u say liao mah... oxidixising - the cathlystic effect of air and moisture corroding ferrous material. take away both and it will stop. but oxidising itself is also a form of protection. mebbe use a bit of dot 5.1 brake fluid, since it is not hypothermic, ie dun absorb water. but dun say i say one.. this type so cheem things i only toylet janitor, cannot understand... Link to post Share on other sites More sharing options...
Weiming 1st Gear August 8, 2007 Share August 8, 2007 Three step method to go about it (which I use for all my Hifi/HT equipment: 1. Use Caig's DeOxit to remove the oxidized film 2. Caig's ProGold to protect the surface from further oxidization 3. Buy those plastic RCA caps (available at SLT, SLS and Adelphi) to fit them over the unused connectors. Link to post Share on other sites More sharing options...
Madsumm 1st Gear August 8, 2007 Share August 8, 2007 Try to get the new Philips Contact Cleaner spray. Blue cap with no residue and oil. Its a good cleaner for this type of stuff. Then get the plastic caps to cover it. If you want to prevent oxidization in the future, spray with K-Power. Rgds Link to post Share on other sites More sharing options...
Apollo 1st Gear August 8, 2007 Share August 8, 2007 good to use small RCA caps. luckily apollo condom dun come in XXXXS size.. Link to post Share on other sites More sharing options...
Casey Neutral Newbie August 8, 2007 Author Share August 8, 2007 okie dokie!!! Thanks guys! ↡ Advertisement Link to post Share on other sites More sharing options...
Yusheng from Singapore, Malaysia or China
How to trace owner from vehicle registration number?
Black flakes from washing machine
No basis for employers to cut pay if flexi-work does not affect productivity: Gan Siow Huang
GSS 2021 join forces with Lazada
From India to S.Africa in an off-peak Hyundai Matrix
Blast from the past!!! WWF stars!!
Singapore Idol Hady Mirza BANNED from condo facilities
