Toy_car Neutral Newbie August 4, 2007 Share August 4, 2007 Hi Bros, need your advice on what kind of suspension to change for my coming 5years G9. My requirements are comfort yet hopefully dun have the feeling of car turn turtle when doing a fast turning. ↡ Advertisement Link to post Share on other sites More sharing options...
Vit4wd 1st Gear August 4, 2007 Share August 4, 2007 I think you are referring to shock absorbers? The Monroe range of shocks should meet your needs. Do take note thhat your G9's CG is high and body roll is very prominent. Pls do not attempt any fast corners on the G9, even with upgraded tyres. Link to post Share on other sites More sharing options...
Toy_car Neutral Newbie August 4, 2007 Author Share August 4, 2007 Actually i just know that i need to change my suspension as i was told that my back wheels tyre has uneven wear due to weak suspension during i did my tyre rotation. But again if i were to change to a new set of original suspension, toyota suspension seem to be very weak as heard from the other bros here before. thats y i need the bros here to recomend me of what to change. Link to post Share on other sites More sharing options...
Vit4wd 1st Gear August 4, 2007 Share August 4, 2007 What is your mileage? Any accident to the rear of your vehicle? Link to post Share on other sites More sharing options...
Toy_car Neutral Newbie August 4, 2007 Author Share August 4, 2007 Mileage just pass 100K. so far no accident..touch wood. Link to post Share on other sites More sharing options...
Vit4wd 1st Gear August 4, 2007 Share August 4, 2007 Should not need to change suspension then. Just change shocks will do. Link to post Share on other sites More sharing options...
Toy_car Neutral Newbie August 4, 2007 Author Share August 4, 2007 Izzit? cause i went to my colleague workshop and the mechanic told me need to change suspension...think should be about $440 for the orginal as what he quoted me. anywhere to that u can recomend in order to have a "confirm" just the shocks that need to be change and what is the cost? Link to post Share on other sites More sharing options...
Vit4wd 1st Gear August 4, 2007 Share August 4, 2007 You can try Yap Brothers or Leong Seng at Paya Ubi Ind Pk Link to post Share on other sites More sharing options...
Toy_car Neutral Newbie August 4, 2007 Author Share August 4, 2007 Thanks Bro for your advice, so i think they should be able to solve my problm..by the way any idea how much will my damage be? Link to post Share on other sites More sharing options...
Vit4wd 1st Gear August 4, 2007 Share August 4, 2007 In the region of S$200+ depending on model. It may be less. Best to drop by to ask. Link to post Share on other sites More sharing options...
Toy_car Neutral Newbie August 4, 2007 Author Share August 4, 2007 Noted..thanks for your advice bro... Link to post Share on other sites More sharing options...
Streetbumpkin Neutral Newbie August 4, 2007 Share August 4, 2007 (edited) I lowered my g9 using eibach pro kit springs and kyb shock absorbers..coupled with low profile tyres.. handling improved alot Edited August 4, 2007 by Streetbumpkin Link to post Share on other sites More sharing options...
Toy_car Neutral Newbie August 4, 2007 Author Share August 4, 2007 u mean u lower ur ride? but do u still get a comfort rde and how much it cost to replace the springs n absorbers? Link to post Share on other sites More sharing options...
Toy_car Neutral Newbie August 4, 2007 Author Share August 4, 2007 what should i do to my 100K G9? i mean things that i should change in order to keep my ride. Link to post Share on other sites More sharing options...
Vit4wd 1st Gear August 5, 2007 Share August 5, 2007 Are you those who approach corners at neck breaking speeds? If not, just stick to stock replacements. Does not make sense to spend extra on a car with just 5 years' life span left. And you may change cars before its 10th yr too. Link to post Share on other sites More sharing options...
Oriki Neutral Newbie August 5, 2007 Share August 5, 2007 Hi... mine is altis, think shud be able to fit also hehe it the price $200+ U mentioned per shocks or 4 shocks? thx Link to post Share on other sites More sharing options...
Streetbumpkin Neutral Newbie August 5, 2007 Share August 5, 2007 Definately comfort is compromised a little if you are to compare with stock.But passengers have all given positive feedback and find it acceptable. Link to post Share on other sites More sharing options...
Toy_car Neutral Newbie August 5, 2007 Author Share August 5, 2007 thanks for your advice..will ask u again if i need more advice. ↡ Advertisement Link to post Share on other sites More sharing options...
ACG Performance - Official Distributor For Brembo, AirBFT Air Suspensions & GFG Forged Wheels!
2026 Corolla Concept WAH JIN SWEE LEH! Best since AE86 GT-Apex
2022 Toyota GR Corolla
