Magiclamp Neutral Newbie August 3, 2007 Share August 3, 2007 Feeling my brakes a soft nowadays. I wonder where I can change the brake pads? Do normal workshops change brake pads also? Last of all, how much to change the pads? Front are disk brakes and rear are drum brakes. Thanks!!! ↡ Advertisement Link to post Share on other sites More sharing options...
Evo7788 Neutral Newbie August 3, 2007 Share August 3, 2007 hi Magiclamp, 1st of all, what is ur ride, and which year's model? secondly, there are many brands of brake pads in the market, from original, aftermarket replacement, performance, to the not-so-originals. a set of new pads can cost anything from $60 to a few hundred dollars, depending on what brand and which workshop you go to. if you go back to agent, it may cost more than workshops outside, as agent prices are normally higher even for changing the same parts. my suggestion is go to a reputable workshop, and ask for a reputable brand of brake pad, as brake pads, together with tyres play an important part in daily driving safety. fyi, continental brands like Mintex, Bendix and Ferodo will generate more brake dust, but generally the braking power is slightly better than most stock pads for asian vehicles. cheers Link to post Share on other sites More sharing options...
Magiclamp Neutral Newbie August 3, 2007 Author Share August 3, 2007 Mine is an old 91 corolla. What is stock pads? Any good recommendations with reasonable price? Link to post Share on other sites More sharing options...
Firefox Neutral Newbie August 3, 2007 Share August 3, 2007 Try Project U(read as mui) at stamford tyres. Better than stock but will cost you ard 100++ for disk type. Drum, not sure but shld cost lesser. Btw, the brake dust is really minimum & braking is . Link to post Share on other sites More sharing options...
Yuan 6th Gear August 3, 2007 Share August 3, 2007 Bro, rear drum brakes how to change brake pads? Link to post Share on other sites More sharing options...
Ray7456 3rd Gear August 3, 2007 Share August 3, 2007 Hi, sorry to hijack a bit. My ride is a 2002 Lancer GDI engine. Any recommendation on brake pad too. Many thnks Link to post Share on other sites More sharing options...
Firefox Neutral Newbie August 3, 2007 Share August 3, 2007 Sorry, bro. I mean changing that 2 pcs of drum brake inside lah. Link to post Share on other sites More sharing options...
Dwoon 1st Gear August 3, 2007 Share August 3, 2007 For disks brakes.... the labour I pay for pad change is $20. Link to post Share on other sites More sharing options...
Theoldjaffa Hypersonic August 3, 2007 Share August 3, 2007 Feeling my brakes a soft nowadays. I wonder where I can change the brake pads? Do normal workshops change brake pads also? Last of all, how much to change the pads? Front are disk brakes and rear are drum brakes. Thanks!!! u can get mintex from evo7788. i got mine from him too. so far so good, good enuff as OE replacement with better biting capability. price Link to post Share on other sites More sharing options...
Yuan 6th Gear August 3, 2007 Share August 3, 2007 Thanks for the clarification bro. Cos I went to look for brake pads for rear drum brakes...They say brake pads for front disc brakes only...Rear drum brakes no need..... So I become very confused..... Link to post Share on other sites More sharing options...
Yuan 6th Gear August 3, 2007 Share August 3, 2007 Bro, yours is mintex 1188 right? Link to post Share on other sites More sharing options...
Firefox Neutral Newbie August 3, 2007 Share August 3, 2007 actually not true. they are 2 pcs of c shape light pads(if i were to call it) in each drum that need to replace over time also. it does not wear off as fast as the disk type. but do cx it also.And 1 more thing, if u can, get ur mech to remove the brake dust trapped inside the drum brake once in a long while. my 2cts thots. cheers Link to post Share on other sites More sharing options...
Ea_falcon Neutral Newbie August 3, 2007 Share August 3, 2007 For drum brakes they are usually called brake shoes, not pads. Link to post Share on other sites More sharing options...
Firefox Neutral Newbie August 3, 2007 Share August 3, 2007 thanks bro, had problem recalling the right term. cheers Link to post Share on other sites More sharing options...
Ea_falcon Neutral Newbie August 3, 2007 Share August 3, 2007 no problem. It happens sometimes. Link to post Share on other sites More sharing options...
Yuan 6th Gear August 3, 2007 Share August 3, 2007 Thanks...Brake shoes got brands like our brake pads or not? Like brake pads got brands like mintex, ferrodo etc? I have a set of project mu brake pads. Haven't changed yet. I am using stock pads now. Still left 40%...Dunno change now or wait for stock pads to be used up first..... Link to post Share on other sites More sharing options...
Ahyoo2002 2nd Gear August 3, 2007 Share August 3, 2007 Hi, sorry to hijack a bit. My ride is a 2002 Lancer GDI engine. Any recommendation on brake pad too. Many thnks I normally replace original one, cost about $130, labour included. Link to post Share on other sites More sharing options...
Theoldjaffa Hypersonic August 3, 2007 Share August 3, 2007 Thanks for the clarification bro. Cos I went to look for brake pads for rear drum brakes...They say brake pads for front disc brakes only...Rear drum brakes no need..... So I become very confused..... rear use brake shoe.. ↡ Advertisement Link to post Share on other sites More sharing options...
New car discount/price/promo
Changing of Spark Plugs
Changing halogen to LED
