Turbobrick Neutral Newbie January 10, 2002 Share January 10, 2002 Anyone tried Sensatracs? I nearly got a set but went on the Koni/Bilstein search after hearing that Sensatracs are comfort and not performance biased. Very pleased with my Bilsteins now ↡ Advertisement Link to post Share on other sites More sharing options...
Spinner Neutral Newbie January 10, 2002 Share January 10, 2002 Saw Autobacs stacking it up on the staircase... the most prominent brand in shock absorbers since they spent so much efforts on adverts. Link to post Share on other sites More sharing options...
Turbobrick Neutral Newbie January 10, 2002 Author Share January 10, 2002 Don't get from Autobacs! Too expensive, parts shop in Sin Ming or Unico at Selegie cheaper. Link to post Share on other sites More sharing options...
Skoda_Man Neutral Newbie January 10, 2002 Share January 10, 2002 Am told that it is best used with stock spring. Get lowered spring, these will start to leak.... Link to post Share on other sites More sharing options...
Turbobrick Neutral Newbie January 10, 2002 Author Share January 10, 2002 Lowering springs causes premature compression in the Sensatracs? Well I guess it is a stock replacement rather than performance upgrade then. Link to post Share on other sites More sharing options...
Skoda_Man Neutral Newbie January 10, 2002 Share January 10, 2002 Right on! meant to be a OEM replacement.... with improved handling or so it claim Link to post Share on other sites More sharing options...
Ghostrider 3rd Gear January 12, 2002 Share January 12, 2002 IMHO,not very lasting as OEM replacement. My bro in law replaced the sensatrac for his Swift GTi and after 7-8 months....one side already leaking liao..... Performance is sure better than stock. Tired his car & can corner much better. But do a few corner hard & the car will still roll. Link to post Share on other sites More sharing options...
Skoda_Man Neutral Newbie January 12, 2002 Share January 12, 2002 Please lah, Swift GTi using original spring??? Not a problem to 2 close colleague who use them with original spring and they last over a year and still counting. I know you will reply me with something, but remember I said 'OEM replacement using original spring' So dun tell me will leak cause owner change to lower spring, cause I knew that already.... Link to post Share on other sites More sharing options...
Ghostrider 3rd Gear January 13, 2002 Share January 13, 2002 Please lah....still orginial spring for the GTi lah....springs still the same. If its aftermarket springs then dun say lah....but orginial springs leh..... Link to post Share on other sites More sharing options...
Madarmour Neutral Newbie January 13, 2002 Share January 13, 2002 Maybe the GTi comes with lowered performance springs? If so, add an OEM-like shocks sure kaput early. Link to post Share on other sites More sharing options...
Turbobrick Neutral Newbie January 13, 2002 Author Share January 13, 2002 GTi use sensatracs? Kinda putting flower on cowdung leh.......time for your bro-in-law to look to Konis then! Link to post Share on other sites More sharing options...
Pisces69 6th Gear January 13, 2002 Share January 13, 2002 Hi Gavin, I dont think sensatracs will suit u. They r more like oem replacements with a little thrill thrown in. I got my sensatracs re-done a few days back after those idiots at comfort auto scvs did a screw-up on the installation a few months back. Initially they would be very soft at low to moderate speeds(upto abt 60kmh) and would even make me feel a little sea-sick at times. (When installed by CAS). Now after re-installing them at another workshop, they r like oem shocks upto about 70kmh(no more sea-sickness thank god) and as the speed increases you feel them tightening up. At about 110-120kmh, they r pretty firm, even after hitting some undulations, the car feels steady n in control. (My springs are all stock). I would say they feel better at speed, then oem's, & cost is about same. For their durability, i'm cant comment as they r about only 4 mths old but so far so good. (As i mentioned, my springs r stock).Previously, i installed the normal monroe gasmatic in a hyundai & found that they lasted longer than the oem's i put in previously so i'm waiting to see if these sensatracs r just as good. Link to post Share on other sites More sharing options...
Turbobrick Neutral Newbie January 13, 2002 Author Share January 13, 2002 Hey Martin, how's things? We're chatting up on Sensatracs whether being OE replacement or performance part. I personally am using Bilstein Sports so handling is way up there but comfort is at rock bottom Hard, hard, hard.....all the way! Link to post Share on other sites More sharing options...
Pisces69 6th Gear January 13, 2002 Share January 13, 2002 Hey Martin, how's things? We're chatting up on Sensatracs whether being OE replacement or performance part. I personally am using Bilstein Sports so handling is way up there but comfort is at rock bottom Hard, hard, hard.....all the way! Link to post Share on other sites More sharing options...
Turbobrick Neutral Newbie January 13, 2002 Author Share January 13, 2002 I believe that OEM replacements like Monroe Sensatrac or Sachs Supertouring has an edge of being a gas shock compared to oil shocks some manufacturer are still using. Most OEM gas replacements are twin tube type for progressive comfort shock absorbsion but still could be bouncy when pushed hard. Well, my interior is rattling like I have a pet rattle snake living in my brick. No probs for me, rattling better then buanging! Link to post Share on other sites More sharing options...
Pisces69 6th Gear January 13, 2002 Share January 13, 2002 Yup, was comparing my sensatracs with the oem/toyota gas shocks i used previously. I never used aftermarket oil shocks b4. I went to jb when i was looking for replacement shocks a few months back, n seems they still using mostly oil shocks. The workshop boss even had the cheek to tell me that oil shocks r better than gas. What a load of crock. Link to post Share on other sites More sharing options...
Yongwd 1st Gear January 13, 2002 Share January 13, 2002 So how u find those oem shocks compared to original? Personal preference I will go for oem as original are relatively expensive. For Toyota spares, I would look for Tokinco or KYB as most of these shocks are made by them. As for ride comfort, I would not go for australia gas shocks - find them pretty stiff. Yup, was comparing my sensatracs with the oem/toyota gas shocks i used previously. I never used aftermarket oil shocks b4. I went to jb when i was looking for replacement shocks a few months back, n seems they still using mostly oil shocks. The workshop boss even had the cheek to tell me that oil shocks r better than gas. What a load of crock. Link to post Share on other sites More sharing options...
Pisces69 6th Gear January 13, 2002 Share January 13, 2002 (edited) [reply]So how u find those oem shocks compared to original? Personal preference I will go for oem as original are relatively expensive. For Toyota spares, I would look for Tokinco or KYB as most of these shocks are made by them. As for ride comfort, I would not go for australia gas shocks - find them pretty stiff. Edited January 13, 2002 by Pisces69 ↡ Advertisement Link to post Share on other sites More sharing options...
Replaced my Koni to Monroe
Monroe Reflex Abosrber for Swift GTi
Monroe Sensatrac
Monroe Sensatrac
Monroe reflex VS KYB [gas shock abs]
Monroe Sensatrac Shock Absorbers
Monroe Shoks
Monroe Shoks
