Try_conti 2nd Gear July 24, 2007 Share July 24, 2007 Guys/gals, I had encounter this perculiar problem over 4 instances. Its only during startup, can be 1st start in the morning or after driving & park for a while & engine still warm. When I crank the engine, all I hear is only the crank sound. Either engine doesn't fire up or it will come up half-dead, sputters & die. All over in less than 2 seconds. The last time I encountered this when I crank the engine, it started half dead, sputter, I step on the gas pedal immediately to rev the engine a bit before it had a chance to die off, & it was ok. Idling was ok after that, not really smooth but doesn't sputter. Any idea or suggestion what could be the problem ? As I said, it doesn't always happens & couldn't really be repeated. It comes once in a blue moon. So far, in almost one year, I encountered 4 times already. ↡ Advertisement Link to post Share on other sites More sharing options...
Osiris 1st Gear July 24, 2007 Share July 24, 2007 i encounter the problem on warm start. can crank but engine won't start on first try. on 2nd try it works. cold start np. had to replace fuel pump. but mine's a sunny Link to post Share on other sites More sharing options...
Spango Clutched July 24, 2007 Share July 24, 2007 I encountered this before a few times as well. The engine can start up, but sputters and dies off. Stepping on the accelerator helps. One fine day, the engine just refused to start up. Had to replace the fuel pump. But mine is a Chevy... Link to post Share on other sites More sharing options...
Chucky2007 Turbocharged July 24, 2007 Share July 24, 2007 most likely battery dying. change it before u are stuck somewhere inconvenient. Link to post Share on other sites More sharing options...
Try_conti 2nd Gear July 24, 2007 Author Share July 24, 2007 i was suspecting that it might be the battery too. Just wanted to hear from more experts out there. Link to post Share on other sites More sharing options...
Simpleman 1st Gear July 24, 2007 Share July 24, 2007 You may wanna check that the throttle body is clean. Erratic idling, and stalling of engine may occur. Link to post Share on other sites More sharing options...
Genie47 1st Gear July 24, 2007 Share July 24, 2007 Check your ignition system. The coils, driver, distributor, flywheel pickup sensor, wires and plugs. Link to post Share on other sites More sharing options...
Silver_blade Turbocharged July 24, 2007 Share July 24, 2007 I second that. Could be any of the above. Weak batt would means that it either wouldn't start at all or take a few cranks to start. Link to post Share on other sites More sharing options...
Fortress Clutched July 24, 2007 Share July 24, 2007 Experienced this a number of times....Do you notice if there is a "car" looking indicator light goes blinking....if it is so, a very common issue...let me know and will tell you how to rectify it. Link to post Share on other sites More sharing options...
XLR8 1st Gear July 24, 2007 Share July 24, 2007 Guys/gals, I had encounter this perculiar problem over 4 instances. Its only during startup, can be 1st start in the morning or after driving & park for a while & engine still warm. When I crank the engine, all I hear is only the crank sound. Either engine doesn't fire up or it will come up half-dead, sputters & die. All over in less than 2 seconds. The last time I encountered this when I crank the engine, it started half dead, sputter, I step on the gas pedal immediately to rev the engine a bit before it had a chance to die off, & it was ok. Idling was ok after that, not really smooth but doesn't sputter. Any idea or suggestion what could be the problem ? As I said, it doesn't always happens & couldn't really be repeated. It comes once in a blue moon. So far, in almost one year, I encountered 4 times already. Bro, did you install a fuel regulator? If not, then you better change your battery. Same symptoms as my octy. Link to post Share on other sites More sharing options...
Echelon 3rd Gear July 24, 2007 Share July 24, 2007 Also since your last servicing check your battery is connected properly. Link to post Share on other sites More sharing options...
Try_conti 2nd Gear July 24, 2007 Author Share July 24, 2007 nothing out of the ordinary on the panel. no extra lights that light up when its not supposed to. when you mention blinking, I supposed u mean when I turn the key to 'on' (without starting the engine), that light blinks ? Didn't really noticed but I'll pay special attention to that indicator when I start my car tomorrow. Link to post Share on other sites More sharing options...
Try_conti 2nd Gear July 24, 2007 Author Share July 24, 2007 last servicing didn't remove batt connectors lah ... just oil & filter change niah ... so cannot be battery connector. Also, jus check the connectors on Sunday, beri tight.... Link to post Share on other sites More sharing options...
Try_conti 2nd Gear July 24, 2007 Author Share July 24, 2007 I noticed the MF batt has this note near an indicator that says "if it appear clear or yellow, change the battery" or something like that. I don't notice any color on the indicator leh .... maybe that means 'clear' & its time to change batt liao .. so fast ah ... less than a year, batt dying already ? And I didn't even have any big ICE setup in there. Everything still stock. Link to post Share on other sites More sharing options...
Pisces69 6th Gear July 24, 2007 Share July 24, 2007 Cud b some small leak in your fuel system & when it is left for awhile, the fuel evaporates. When u start, the remaining fuel is not enough to fire up the engine. By the time u start again, the fuel system has already been charged with fuel. I'm just guessing cos I only had this long ago on a carb car. I found out the carb was faulty. I don't know if there cud b some problem with your throttle system??? Link to post Share on other sites More sharing options...
Jesse Neutral Newbie July 24, 2007 Share July 24, 2007 mine also used to behave the same like yours. refused to start up when initial cranked on the igniton switch. had to turn-off the switch and try again. sometime up 3 try lah. Now, the problem had all gone away liao. Maybe, you should try the following: Turn on the ignition and Do remember to be patient and wait forwait[/b] for the system check to complete and the warning buzzer sound to go off. Then crank start your engine. The Problem should go away. Link to post Share on other sites More sharing options...
Try_conti 2nd Gear July 24, 2007 Author Share July 24, 2007 hmmm .... leak in fuel system ... sounds dangerous leh ..... like anytime can catch fire & explode like that ... how do you check for leak in fuel system ? Are you referring to dirty throttle body when u mention prob with throttle system or something more problematic ? Unlikely dirty throttle body as problems did not surface only recently. Has been around for the past 10 months & this sputtering startup only happened 4 times so far. Maybe I should bring it back to the AD for them to troubleshoot but I doubt they will know what to do .... apart from taking things apart & then missed one or two screws while putting everything back together .... Link to post Share on other sites More sharing options...
Try_conti 2nd Gear July 24, 2007 Author Share July 24, 2007 That's what I ALWAYS do. Wait until everything complete, then only crank the engine but I can't remember if these happenings were during the times when I was rushing or not Always the case, right, when you're in a rush, it tends to be slower because of more obstacles in your path .. ↡ Advertisement Link to post Share on other sites More sharing options...
SCHNELL Engine Oil 5W40
P2096 Check engine light
