Jkcs Neutral Newbie July 21, 2007 Share July 21, 2007 Hallo everybody! Me got a qns leh, that is my ride tends to move to the left whenever I have a front passenger. So I have to counter this problem by turning my steering wheel slighty to my right. i notice this does not happen when I am alone driving. mine is on steel rim and stock tires. Sometimes my wheels, usually it is the hind left and right, did hit/mount the kerb here and there especially at MSCP. Is this the caused? thanks ↡ Advertisement Link to post Share on other sites More sharing options...
Ccssgm 1st Gear July 21, 2007 Share July 21, 2007 Must be either Tyre or Alignment Problem.... Link to post Share on other sites More sharing options...
Avatarlow Neutral Newbie July 21, 2007 Share July 21, 2007 yr passenger is a 300 pounds beauty is it ? Link to post Share on other sites More sharing options...
Ccssgm 1st Gear July 21, 2007 Share July 21, 2007 Link to post Share on other sites More sharing options...
Shull Turbocharged July 21, 2007 Share July 21, 2007 tyre alignment problem usually no passenger also can feel one.. chances are, his tyres assembly something wrong liao..cannot take load.. Link to post Share on other sites More sharing options...
Ccssgm 1st Gear July 21, 2007 Share July 21, 2007 Possible....... Link to post Share on other sites More sharing options...
Jkcs Neutral Newbie July 21, 2007 Author Share July 21, 2007 hahaha no lah... only 400pounds just kidding does it help if I change my set of wheels? If cannot I will have no choice but to go back to CnC to rectify during my 10K km servicing which I am thinkin of not going back. Link to post Share on other sites More sharing options...
Yeobh 4th Gear July 21, 2007 Share July 21, 2007 There are few possibilities , the most possible cuprit looks like the left side suspension system is not in very good shape. The other possible cause can be the left front wheel bearing is not properly torque to spec or need to be replaced Link to post Share on other sites More sharing options...
Octopus 3rd Gear July 21, 2007 Share July 21, 2007 Is the tyre pressure ok? I would assume if your alignment out due to hitting kerb, it would still go one side with or without passenger... Or maybe the shock absorber worn out? Link to post Share on other sites More sharing options...
Slowmo Clutched July 21, 2007 Share July 21, 2007 you left hand on thigh and right hand on wheel 3 o'clock is it? maybe thats why steer to right Link to post Share on other sites More sharing options...
Jkcs Neutral Newbie July 21, 2007 Author Share July 21, 2007 Slowmo, u veri naughty leh.. Thanks to all bro/sis who replied, appreciate all your views. Actually me is an dumb dumb on car, only knows how to drive. Will ask Cnc to check on this prob of mine. Link to post Share on other sites More sharing options...
Legendary Clutched July 22, 2007 Share July 22, 2007 Link to post Share on other sites More sharing options...
Darkblue 1st Gear July 22, 2007 Share July 22, 2007 Double check tire pressure... if cannot then go check tires condition if still ok, got for balancing and alignment But worst case is steering, CV joint problems... = jiak lat ↡ Advertisement Link to post Share on other sites More sharing options...
CMPB Moving . . .
CMPB Moving . . .
Piano - moving piano
Deadly amusement park ride
Budget 2025 - February 2025.
Batteries for ride-on toys
Benefits of having bigger population in our day to day life.
Car F*ckability Test
