Curahee 1st Gear July 15, 2007 Share July 15, 2007 Dear Bros, i have a problem recently. I cannot shift my gear from P to other mode. May i know what is wrong with the car? I drive a honda civic auto. Car abt a year old. Whenever i switch on engine, pull down handbrake, i cannot shift the gear from P to D. In the end, stuck in the car, cannot move. Need to try many many times and pray hard that it will engage. It become a headache esp in shopping malls when ppl waiting for my car to move off from the lot, i take 5 to 10 mins to move off, very inconvenient and pai sei. Any bro can en light me on this issue? Tmr gg to Kah Motor to rectify this problem. Thanks! ↡ Advertisement Link to post Share on other sites More sharing options...
Genes 6th Gear July 15, 2007 Share July 15, 2007 They will tell u brake sensor problem, and change one for u nia. for now when u need to move and u cant get it to go to D rite, stop engine, insert key to transmission lock and shift to N then start ur car. p/s: trans lock is the covered lid right on top of ur gear lever. Link to post Share on other sites More sharing options...
Dafansu Turbocharged July 15, 2007 Share July 15, 2007 are all your brake lights ok? did any fuse blow. for auto car, u need to press the brake to change gear and the brake is link to the brake fuse. if this fuse blow u cant shift. Link to post Share on other sites More sharing options...
Genes 6th Gear July 15, 2007 Share July 15, 2007 Not mine. Anyway Civic FD is DBW. If sensor cannot detect that brake is being pressed then the P-lock will not disengage itself to allow the gear to be moved. Link to post Share on other sites More sharing options...
Curahee 1st Gear July 15, 2007 Author Share July 15, 2007 Hmmm seems like my one its sensor problem from what u describe. I need to keep on pressing my brake pedal repeatedly and some time press it very hard in order to engage. Damn it, only 1 yr old car got such problem liao. Link to post Share on other sites More sharing options...
Curahee 1st Gear July 15, 2007 Author Share July 15, 2007 This one i not very sure. Juz service 1 mth ago. Dun think so fast spoil lei. Link to post Share on other sites More sharing options...
Passion 5th Gear July 15, 2007 Share July 15, 2007 Brother,same issue as mine.My civic FD also encounter this problem.Send back to AD to check,most probably brake switch spoil.My one is brake switch spoil,sometime on,sometime off.A brake switch cost around 65 to 80 dollars. Link to post Share on other sites More sharing options...
Ultramega 1st Gear July 15, 2007 Share July 15, 2007 next time just press the shift lock button. then can shift already. u keep trying and trying will only spoil the gear box even more. Link to post Share on other sites More sharing options...
Fitzy Neutral Newbie July 15, 2007 Share July 15, 2007 Yup agree, if it happen again, just use the shift lock button to engage to D. Its better to go for a check. Link to post Share on other sites More sharing options...
Curahee 1st Gear July 15, 2007 Author Share July 15, 2007 Noted! Thanks a lot. Link to post Share on other sites More sharing options...
Seaweed 1st Gear July 15, 2007 Share July 15, 2007 still warranty...send it for them to repair since its FOC....if not..just use a toothpick to stuck the shift lock button...that's it...disable the shift lock permanent liao...no point fixing this kind of things if it cost any single cent... Link to post Share on other sites More sharing options...
Passion 5th Gear July 16, 2007 Share July 16, 2007 Brother,don't teach other the wrong thing.When shift lock is lock,the brake light shouldn't light up as well.As his case is similar to mine,i doubt is fuse problem.This is dangerous as when traveling at high speed,and you suddenly e-brake,the vehicle behind might not be able to see you slowing down as the light did not light up.This happen to me once.So pls send it for repair before any mischap happen. Link to post Share on other sites More sharing options...
Mzrmazda3 6th Gear July 16, 2007 Share July 16, 2007 Bro, hope that you have solved your gear thingy by now Link to post Share on other sites More sharing options...
Seaweed 1st Gear July 16, 2007 Share July 16, 2007 that depends on what break down!! if you step the brake then brake light don't on...then you are right...but permanently depressing the shift lock button will not cause brake light not to lit up...the shift lock is just a safety feature for auto.. Link to post Share on other sites More sharing options...
Penthousepauper Clutched July 16, 2007 Share July 16, 2007 Dear Bros, i have a problem recently. I cannot shift my gear from P to other mode. May i know what is wrong with the car? I drive a honda civic auto. Car abt a year old. Whenever i switch on engine, pull down handbrake, i cannot shift the gear from P to D. In the end, stuck in the car, cannot move. Need to try many many times and pray hard that it will engage. It become a headache esp in shopping malls when ppl waiting for my car to move off from the lot, i take 5 to 10 mins to move off, very inconvenient and pai sei. Any bro can en light me on this issue? Tmr gg to Kah Motor to rectify this problem. Thanks! wow, one year old and got this kind of problem? Link to post Share on other sites More sharing options...
Passion 5th Gear July 16, 2007 Share July 16, 2007 I know permanently depressing shift lock will not cause brake light not to lit up.Look at what he mention,he need to depress the brake pedal alot of times,and it might not work sometimes.This is the same issue as mine.So i guess,the brake light might not light up in the event of e-brake.and the car behind might come crashing up. Link to post Share on other sites More sharing options...
Curahee 1st Gear July 16, 2007 Author Share July 16, 2007 Yeah. Problem is brake switch spoil. Now change already. Working fine now. Hope dun spoil again. Kena window problem & gear problem within a year. Now i convince that i kena a lemon civic. Link to post Share on other sites More sharing options...
Curahee 1st Gear July 16, 2007 Author Share July 16, 2007 Har nor what to do. LL. Before this is my window. Dunno what's next ↡ Advertisement Link to post Share on other sites More sharing options...
Yusheng from Singapore, Malaysia or China
How to trace owner from vehicle registration number?
Black flakes from washing machine
No basis for employers to cut pay if flexi-work does not affect productivity: Gan Siow Huang
GSS 2021 join forces with Lazada
From India to S.Africa in an off-peak Hyundai Matrix
Eye surgery - cannot drive
Recirculation mode not working
