Super4 Clutched May 14, 2003 Share May 14, 2003 Yup...hahaha.... ↡ Advertisement Link to post Share on other sites More sharing options...
Super4 Clutched May 14, 2003 Share May 14, 2003 Notice, there's grounding done too.... Link to post Share on other sites More sharing options...
Modeldriver Neutral Newbie May 14, 2003 Share May 14, 2003 got it, thanks ! Link to post Share on other sites More sharing options...
Turtlekar 2nd Gear May 14, 2003 Share May 14, 2003 cai-cold air intakesri-short ram intake so, wats the diff between them? 1 is longer pipe and the other shorter got one more: DAI= Direct Air Intake Link to post Share on other sites More sharing options...
Turtlekar 2nd Gear May 14, 2003 Share May 14, 2003 drop in low end (~2-2.5K) power and improve in >mid end IMHO, a SRI with proper heat shield will do that's not quite true....it depends on how u design the CAI Link to post Share on other sites More sharing options...
Typoerror Neutral Newbie May 14, 2003 Share May 14, 2003 any words of wisdom to share??...i would like to go into CAI without suffering low end ...from dyno graph of AEM CAI, low end is maintained with increase in mid and high end ...but rather ex...donno if DIY CAI can attain this kinda result.. Link to post Share on other sites More sharing options...
S2P2 Neutral Newbie May 14, 2003 Share May 14, 2003 CAI should give you better low end Link to post Share on other sites More sharing options...
Turtlekar 2nd Gear May 14, 2003 Share May 14, 2003 (edited) CAI will give u good low and improved mid range....but definitely not the high end...cos it's relative to your compression ratio.....i done my car DIY stuff and throttle response is almost immediate improvement.....come down to the Friday meetup and i can show u how i done it btw, the dynograph is just some kind of commercial gimmick....they will always mentioned a hugh margin gain in term of bhp and torque, but how true??? u should know the answer rite.... Edited May 14, 2003 by Turtlekar Link to post Share on other sites More sharing options...
Epsilon 2nd Gear May 14, 2003 Share May 14, 2003 so does CAI improve fuel consumption? Link to post Share on other sites More sharing options...
Turtlekar 2nd Gear May 14, 2003 Share May 14, 2003 i can only say slight and very marginal improvement....cos when there is more air going into your combustion chamber, u require less fuel.....that is where your O2 sensor does the work by feeding back info to your ECU and then to the fuel injector....but it will be a very mild one unless u wanna put in a airflow controller (SAFC) which control your mixture, either running on rich or lean..... Link to post Share on other sites More sharing options...
Hkfung Neutral Newbie May 14, 2003 Share May 14, 2003 drop in low end (~2-2.5K) power and improve in >mid end IMHO, a SRI with proper heat shield will do that's not quite true....it depends on how u design the CAI i reason the lost of my low end is the removal of resonator box as shown in the pic..wat u reckon Link to post Share on other sites More sharing options...
Typoerror Neutral Newbie May 14, 2003 Share May 14, 2003 so r u using stock air box with direct intake???...will join meetup if i can make it ... imo, AEM CAI looks quite cool .. Link to post Share on other sites More sharing options...
Epsilon 2nd Gear May 14, 2003 Share May 14, 2003 I am using the stock air box with direct intake...w/o the resonator box. Link to post Share on other sites More sharing options...
Hitman Neutral Newbie May 14, 2003 Share May 14, 2003 eh Turtle ... u got do CAI on DIY basis meh ?? So your now got CAI ... can do the Singapore version of The Slow and The Steady with an NOS Mazda or not ?? Link to post Share on other sites More sharing options...
Hkfung Neutral Newbie May 14, 2003 Share May 14, 2003 1 bro mentioned the loud roar of AEM CAI Link to post Share on other sites More sharing options...
Typoerror Neutral Newbie May 14, 2003 Share May 14, 2003 ohhh...i love it Link to post Share on other sites More sharing options...
Hkfung Neutral Newbie May 14, 2003 Share May 14, 2003 how abt this man !!! http://www.injen.com/honda.html Link to post Share on other sites More sharing options...
Hkfung Neutral Newbie May 14, 2003 Share May 14, 2003 CAI version ↡ Advertisement Link to post Share on other sites More sharing options...
Taxi goes to Cat E.....impact on Cat A?
COVID-19: Retrenchments
