Lufu 1st Gear May 11, 2003 Share May 11, 2003 wonder what kind of effect would I see... still pondering if I should ?? ↡ Advertisement Link to post Share on other sites More sharing options...
Michel Neutral Newbie May 11, 2003 Share May 11, 2003 You should direct the question to those in SLC. They will be able to answer your query better. Link to post Share on other sites More sharing options...
Hkfung Neutral Newbie May 11, 2003 Share May 11, 2003 drop in low end (~2-2.5K) power and improve in >mid end IMHO, a SRI with proper heat shield will do Link to post Share on other sites More sharing options...
Jonnie Neutral Newbie May 12, 2003 Share May 12, 2003 just got accquainted to CAI and now SRI! Wat does SRI stand for and its purpose??? Link to post Share on other sites More sharing options...
Hkfung Neutral Newbie May 13, 2003 Share May 13, 2003 cai-cold air intake sri-short ram intake so, wats the diff between them? 1 is longer pipe and the other shorter Link to post Share on other sites More sharing options...
Firefox Neutral Newbie May 13, 2003 Share May 13, 2003 smoother drive but ur air filter gets dirty much faster. Link to post Share on other sites More sharing options...
Mitlan Neutral Newbie May 13, 2003 Share May 13, 2003 CAI will decrease low end torque? MICHEL i think we are drving the same car 98' 1.3m lancer? have u done anything to your car?.. Link to post Share on other sites More sharing options...
Modeldriver Neutral Newbie May 13, 2003 Share May 13, 2003 Have you tried ? Am basically concerned with the noise level increase. Is it that much louder ? Link to post Share on other sites More sharing options...
Hkfung Neutral Newbie May 13, 2003 Share May 13, 2003 my stock resonator is removed and 3" pipe with insulation as the cold-air intake near the right front bumper area...noise is not that loud..maybe ard 10-20%. the only drawback is the lose of low end torque (<2K RPM) but it is easier to reach >3K RPM Link to post Share on other sites More sharing options...
Modeldriver Neutral Newbie May 13, 2003 Share May 13, 2003 What car U drive ? Manual/auto ? U DIY the intake ? Improvement on HP/torque besides being easier to reach >3k RPM ? Link to post Share on other sites More sharing options...
Hkfung Neutral Newbie May 13, 2003 Share May 13, 2003 auto civic'01. done up by one of the SHC bro. the following are his marketing extracts interested bo ? Factory setup takes in air from engine bay, which is hot, abt 70C to 80C. Hot air is less dense, hence poorer effeciency in the combustion department. It will channel cool air from outside, which is denser, and hence better combustion. The setup has been tested heavy downpour and the airbox is still dry. I also do customised heat shield and 6 points grounding. Go to the following link to CHECKOUT all the cars that i have done. Common feedbacks are; Car feels less sluggish, throttle is more responsive, accelerations are smoother across rpm range. cheerios! Link to post Share on other sites More sharing options...
Epsilon 2nd Gear May 13, 2003 Share May 13, 2003 by Alex?...how much did you pay then? Link to post Share on other sites More sharing options...
Modeldriver Neutral Newbie May 14, 2003 Share May 14, 2003 uh... what link ? Link to post Share on other sites More sharing options...
Hkfung Neutral Newbie May 14, 2003 Share May 14, 2003 u got mail Link to post Share on other sites More sharing options...
Epsilon 2nd Gear May 14, 2003 Share May 14, 2003 hi, what is that pink coloured item at the bottom left? Link to post Share on other sites More sharing options...
Hkfung Neutral Newbie May 14, 2003 Share May 14, 2003 the pic is not my ride...if i'm not wrong, it is meant for ICE purposes which suppose to stablise the power to the ICE components (etc. amp) unless someone says differently Link to post Share on other sites More sharing options...
Super4 Clutched May 14, 2003 Share May 14, 2003 Yes SIR!!! Better Response throttle..... ↡ Advertisement Link to post Share on other sites More sharing options...
Taxi goes to Cat E.....impact on Cat A?
COVID-19: Retrenchments
