Yuan 6th Gear July 9, 2007 Share July 9, 2007 Dear all, Just a newbie question to ask bros and sis. Can brake fade occur in normal road usage and street driving? My current brake is such that the pedal travel feel is a bit spongy and when I depressed my pedal to stop the car, it still can stop lah but not effective. Yesterday, I almost hit a car cos I step on my brakes but somehow my car couldn't stop and I had to stomp on my brakes a second time for it to stop.....I ask one experienced driver and was recommended to upgrade my brake system and which I am looking around now. I constantly tap my brakes and brake very often and sometimes can be hard. Still on stock pads and stock hose and stock rotor. I just service my car (20k servicing) 6 weeks ago and my stock pads are still okay and good as informed by the mechanic. ↡ Advertisement Link to post Share on other sites More sharing options...
Watwheels Supersonic July 9, 2007 Share July 9, 2007 First check your brake fluid level. (see user manual) If necessary ask a mecahenic to help u check for leaks. Link to post Share on other sites More sharing options...
Yuan 6th Gear July 9, 2007 Author Share July 9, 2007 Bro, thanks for your advice. I just checked my brake fluid last Saturday (2 days ago). Still on the healthy range. Link to post Share on other sites More sharing options...
Eyke Supercharged July 9, 2007 Share July 9, 2007 well, isn't stock the best? Link to post Share on other sites More sharing options...
Yuan 6th Gear July 9, 2007 Author Share July 9, 2007 Yes. Stock is best. But cannot figure out why it happen leh? Maybe upgrade to better stock stuff. Link to post Share on other sites More sharing options...
Terenc3 1st Gear July 9, 2007 Share July 9, 2007 Upgrade stock meh? Link to post Share on other sites More sharing options...
Silver_blade Turbocharged July 9, 2007 Share July 9, 2007 Have you done any mod on the vacuum hose eg. broquet, etc? Link to post Share on other sites More sharing options...
Holysniper Neutral Newbie July 9, 2007 Share July 9, 2007 Dear all, Just a newbie question to ask bros and sis. Can brake fade occur in normal road usage and street driving? My current brake is such that the pedal travel feel is a bit spongy and when I depressed my pedal to stop the car, it still can stop lah but not effective. Yesterday, I almost hit a car cos I step on my brakes but somehow my car couldn't stop and I had to stomp on my brakes a second time for it to stop.....I ask one experienced driver and was recommended to upgrade my brake system and which I am looking around now. I constantly tap my brakes and brake very often and sometimes can be hard. Still on stock pads and stock hose and stock rotor. I just service my car (20k servicing) 6 weeks ago and my stock pads are still okay and good as informed by the mechanic. tot u say stock is good? if u upgrade means not stock already. Link to post Share on other sites More sharing options...
Yuan 6th Gear July 9, 2007 Author Share July 9, 2007 I have not done anything to the vacuum hose. Link to post Share on other sites More sharing options...
Yuan 6th Gear July 9, 2007 Author Share July 9, 2007 Then it becomes unstock. Link to post Share on other sites More sharing options...
Silver_blade Turbocharged July 9, 2007 Share July 9, 2007 Then it could be moisture in the brake system. To replace the brake fluid may just do the trick. Link to post Share on other sites More sharing options...
Yuan 6th Gear July 9, 2007 Author Share July 9, 2007 Yes.... Link to post Share on other sites More sharing options...
Yuan 6th Gear July 9, 2007 Author Share July 9, 2007 How did it have moisture? Link to post Share on other sites More sharing options...
Silver_blade Turbocharged July 9, 2007 Share July 9, 2007 Over time, some moisture (from the air) will get into the brake system. But your mileage looks to be low for that. Best to have it checked asap..for any leak, brake pump failure, etc... Link to post Share on other sites More sharing options...
Yuan 6th Gear July 9, 2007 Author Share July 9, 2007 Wah! So dangerous. Can even happen to new car? Link to post Share on other sites More sharing options...
Yeobh 4th Gear July 9, 2007 Share July 9, 2007 Brake fluid being hygroscopic,overtime will gradually loses its heat resistance and absords water from the air, via the reserviour breathers and flexible hoses. Get yr mech to test the brake fluid for moisture content and if it is on the unsafe side then flush the whole system and pressure or vaccum the system to make sure the system is 100% free from air bubbles. ↡ Advertisement Link to post Share on other sites More sharing options...
Reckless Cyclist
Reckless Cyclist
Shop Houses Collapse at Syed Alwi Road
Road Trip To Thailand
Advice needed for New Zealand road trip
