Seaweed 1st Gear July 10, 2007 Share July 10, 2007 ha ha ha...bro...you say it liao...ang mo drive from sg to genting....but you driving in sg stop and start traffic leh.... ↡ Advertisement Link to post Share on other sites More sharing options...
Mzrmazda3 6th Gear July 10, 2007 Share July 10, 2007 Actually , I found that I have enough speed to enter gear leh Do not have much PINGing from the Gear and Engine. when I do that. Any old bird and Grand master can advice? Cheers Gimmy Bro, IMHO if you have enter the next gear at a very low rpm, you would be straining your engine as what Bro Sony had said Long term wise it would do more harm to your engine rather than FC savings Link to post Share on other sites More sharing options...
Tanlee 1st Gear July 10, 2007 Share July 10, 2007 wow, 620 for that box. isnt it a bit too expensive. even you are a supporter of the ezstab. their entry model should be ok with your TS. furthermore, for a manual car, i dont see a lot benefits from it, other than brighter light/colder air. Link to post Share on other sites More sharing options...
Sony 1st Gear July 10, 2007 Share July 10, 2007 I did what you guys advice, down slope conering with 5th gear instead of Neutral. Actually Felt no difference. Thanks will just stick to the 5th gear. Cheers Gimmy go thru the corner with the correct speed. have engine brake if you need be. You may have AWD but can your tyres take the forces when you take the corner. Drive like what a safe driver does. Enter with with sufficient engine brake, and pick up speed as you exist. It will be better for your suspension and less body roll as well. Link to post Share on other sites More sharing options...
En0203 2nd Gear July 10, 2007 Share July 10, 2007 maybe the initial post TS put up is on a unstable starting ground. And at times, despite concern on the free-wheel issue, he's not convinced. But if you follow my post with him, I think i have been mild and been of some contribution. actually free-wheeling is not really that big an issue. u only cannot accelerate but braking power is still there all the time. the fact is that the brake is so strong that it can overpower the engine in braking anytime, not really that dangerous if u ask me unless one does hard braking in the middle of the corner, but if that happens whether u have engine brake or not u still buang and another fact is that almost ALL ppl on autogear do that everyday without knowing. why? because theoretically an autobox does not engage engine brake on cornering and downsloping (except few intelligence ones on downslope only). don't tell me the autobox in its overdrive can give u any kind of engine braking through the corner or downslope, neh... wait long long unless u are travelling at more than 3k - 4k rpm on overdrive?? well not in singapore context as the fastest u can go here is 90 km/h and in no way can ur overdrive be in that kind of rpm here. so does that means most of the ppl here (me included) with an autobox is driving dangerously everyday because our autoboxes do not provide any kind of engine braking at corner or downslope? anyway, it's good to see more and more constructive comments here Link to post Share on other sites More sharing options...
Boxster 2nd Gear July 10, 2007 Share July 10, 2007 (edited) 2) I always change gear @ 1500 - 1700 rpm. I entered 5th Gear @ 60km/hr speed. Wah change gear so early ah Assume you changed gear at 1.7k after change around 1.4, 1.5k still can have enough torque to acc.. without knocks ah Knock sensor working very hope that the engine can last you 10 yrs if you intend to keep it otherwise the next buyer will be damm unlucky to have burnt cam shaft Edited July 10, 2007 by Boxster Link to post Share on other sites More sharing options...
Thermodynamics Neutral Newbie July 10, 2007 Share July 10, 2007 Personally I always like to keep my rpm between 2 to 3k. I think some revs are good and more healthy for the engine in the long run. Link to post Share on other sites More sharing options...
Friendstar Supercharged July 10, 2007 Share July 10, 2007 Free-wheeling is dangerous especially during hard-braking. Enough said. Link to post Share on other sites More sharing options...
Friendstar Supercharged July 10, 2007 Share July 10, 2007 Yes very true. Its better in the long run. becos u vary the engine speed over a greater range. Link to post Share on other sites More sharing options...
Friendstar Supercharged July 10, 2007 Share July 10, 2007 Actually , I found that I have enough speed to enter gear leh Do not have much PINGing from the Gear and Engine. when I do that. Any old bird and Grand master can advice? Cheers Gimmy Bro, IMHO if you have enter the next gear at a very low rpm, you would be straining your engine as what Bro Sony had said Long term wise it would do more harm to your engine rather than FC savings yep u would have saved a whopping $3,000 on your petrol consumption! wow. but the bill for the engine repair would have cost a hefty $5,000. LOL Link to post Share on other sites More sharing options...
Thermodynamics Neutral Newbie July 10, 2007 Share July 10, 2007 Ya lor, change gear at such a low rpm is a bit too exaggerating and extreme already. He put a brick underneath the accelerator pedal??? I do not understand why drive car must drive until so extreme to save that little of fuel. Link to post Share on other sites More sharing options...
Sony 1st Gear July 10, 2007 Share July 10, 2007 maybe the initial post TS put up is on a unstable starting ground. And at times, despite concern on the free-wheel issue, he's not convinced. But if you follow my post with him, I think i have been mild and been of some contribution. actually free-wheeling is not really that big an issue. u only cannot accelerate but braking power is still there all the time. the fact is that the brake is so strong that it can overpower the engine in braking anytime, not really that dangerous if u ask me unless one does hard braking in the middle of the corner, but if that happens whether u have engine brake or not u still buang and another fact is that almost ALL ppl on autogear do that everyday without knowing. why? because theoretically an autobox does not engage engine brake on cornering and downsloping (except few intelligence ones on downslope only). don't tell me the autobox in its overdrive can give u any kind of engine braking through the corner or downslope, neh... wait long long unless u are travelling at more than 3k - 4k rpm on overdrive?? well not in singapore context as the fastest u can go here is 90 km/h and in no way can ur overdrive be in that kind of rpm here. so does that means most of the ppl here (me included) with an autobox is driving dangerously everyday because our autoboxes do not provide any kind of engine braking at corner or downslope? anyway, it's good to see more and more constructive comments here You are giving a rather wrong signal here. In auto car, there's no engine brake, thus the safe manner of driving is to apply brake before entering bend/corner... I'm sure your many years of driving will tell you that corner at high speed without any form of brake will only result in some nasty situation if the car cannot hold well. Moreover, there's a difference between free wheeling and having your car in gear. If you are in gear, when the driver sense that the car is losing grip, he can do corrective action by adding torque and not jamming the brake. If it's on freewheel, what do you think an inexperience driver will do? You need to differentiate between freewheel and in gear as well. BTW, the above don't apply to gentle driver. Link to post Share on other sites More sharing options...
Slayer Clutched July 11, 2007 Share July 11, 2007 ha ha ha...bro...you say it liao...ang mo drive from sg to genting....but you driving in sg stop and start traffic leh.... however, the idea is there. :) Link to post Share on other sites More sharing options...
Mzrmazda3 6th Gear July 11, 2007 Share July 11, 2007 Personally I always like to keep my rpm between 2 to 3k. I think some revs are good and more healthy for the engine in the long run. Yup Bro Link to post Share on other sites More sharing options...
Mzrmazda3 6th Gear July 11, 2007 Share July 11, 2007 yep u would have saved a whopping $3,000 on your petrol consumption! wow. but the bill for the engine repair would have cost a hefty $5,000. LOL Agree Bro Furthermore, one will not be able to fully explore one's ride should one continue to drive in such a manner Link to post Share on other sites More sharing options...
Thug Clutched July 11, 2007 Share July 11, 2007 Greetings to all Impreza Drivers and Lovers of AWD. I will first start by sharing my tips to increase FC for my new car. Currently my Impreza 1.6i MT is still under RUN in less than 1600 km The Run in Engine Oil is very thick , thickest compare to Mineral oil and Full Syn oil I have acheived 12-13.5km /litre of petrol with lot of careful driving. TIPS 1) I have installed EZ-stab EXTreme. I have just Spend $620 on this Extreme. Very worth it It aids in Power and Fuel Efficiency 2) I always change gear @ 1500 - 1700 rpm. I entered 5th Gear @ 60km/hr speed. 3) I always set my gear to NEUTRAL during down slope, enter 5th Gear and slowly release clutch when I am about to reach flat road. I do that everyday on CTE. 4) When I saw red light at a distance, I will set Neutral and let it cruise. I dare to do this because it is AWD. Very Stable. Not afraid it will skid or anything. AWD is the best. 5) Check and pump to the correct tyre pressure every alternate days. I am hoping to bring this Impreza to 15km/litre. I am in constant process to search for good products and tips to improve on FC. anyway the petrol price have increased. Since I have bought subaru cars, i do not think i will switch brand. I am aiming for a SUBARU Legacy for my next car. I hope all the GURU out there in MCF will contribute on the tips of BEtter FC. I will humbly accept advices. Cheers GIMMY 3) I always set my gear to NEUTRAL during down slope, enter 5th Gear and slowly release clutch when I am about to reach flat road. I do that everyday on CTE. Jin lei chey leh....morever isn't this cheating? It don't really show the full potential of how fuel saving ur car really is. U installed the 620 bucks thing...and yet drive like this? I don't know, it seems the thing isn't really worth that kinda money. Can easily buy a set of rims wif that... Cheers~ Link to post Share on other sites More sharing options...
Robin 4th Gear July 11, 2007 Share July 11, 2007 errr... shouldnt your title be: Tips to Improve FC or Tips to Reduce FC ?? Link to post Share on other sites More sharing options...
Gim_ong Neutral Newbie July 11, 2007 Author Share July 11, 2007 (edited) Got difference lo, $620 just buy lo. After I have been pamper with the EZ-Stab Extreme, It is quite NO Kick to use their Entry Set. Personal Experience between Extreme and Entry set is that Extreme give me " Step abit of ACClerator then move liao," comapre to the entry set. Maybe it gives me high torque, i am not sure as well, no dyno test to test my car. anyway pretty new to the product. Ez-stab Extreme is just one of my toys. Cheers Gimmy Edited July 11, 2007 by Gim_ong ↡ Advertisement Link to post Share on other sites More sharing options...
Town Council S&C Charges May Increase Soon!
2015 Forester 2.0
2015 Forester 2.0
Advice on exhaust.
Advice on exhaust.
ERP rates increase/decrease thread monitor!
Home renovation tips
New Subaru XV
New Subaru XV
MALAYSIA TIPS - Long Distance Driving Trips
