Bigtoothpick 3rd Gear June 20, 2007 Share June 20, 2007 hi wanna find out, if you're using directional tyres, do you swop left/right when doing tyre rotation? i.e. remove tyres from rim and swop. So far the 2 places i've been, they just swop front and back, tells me "cannot" switch left/right (duh...), charges about $20 to $25. Should it cost more if I ask to swop left/right? Typically how much more and where recommended? Prefer east side (Sengkang/Tampines/Loyang). i'm running on 17", come tyre change it burns a hole in my pocket Thanks ↡ Advertisement Link to post Share on other sites More sharing options...
Kb27 Supersonic June 20, 2007 Share June 20, 2007 Directional tyres cannot switch left/right only front/back. Otherwise the tyres will point at the wrong dirction. Link to post Share on other sites More sharing options...
Byond 1st Gear June 20, 2007 Share June 20, 2007 tyres rotation..change front to back for my case. This is due to the front portion..that houses ur engine..it wears off fast..so need to even out the tyre wear. This is what i know..front left to right and back left to right...i think it will make ur front tyres wear out faster than ur back tyres. The point here is to even out the wear from all 4 tyres... Link to post Share on other sites More sharing options...
Scaglietti Neutral Newbie June 20, 2007 Share June 20, 2007 Only swap from the front axle to tbe back. Keep it to the same side. Don't dismount the tyres from the rims. BC Link to post Share on other sites More sharing options...
Cordia_gsr Neutral Newbie June 20, 2007 Share June 20, 2007 If you really want to have the cross rotation, you will need to dismount the tires from the rims and reinstall on the opposite direction. But it's not money worth to do so.... Link to post Share on other sites More sharing options...
Topgun Neutral Newbie June 20, 2007 Share June 20, 2007 If your tyres are directional AND with asymmetrical threads, then can only swap front and back same side, do not 'cross' swap... Link to post Share on other sites More sharing options...
Bigtoothpick 3rd Gear June 20, 2007 Author Share June 20, 2007 Ah. You have a point, re asymmetrical thread. Thanks Anyone knows if Falken ST115 Azenis has asymmetrical thread... Link to post Share on other sites More sharing options...
Bigtoothpick 3rd Gear June 20, 2007 Author Share June 20, 2007 Directional tyres cannot switch left/right only front/back.Otherwise the tyres will point at the wrong dirction. yup. i know that. Thought of removing from rims but didn't know about asymmetrical thread though. Link to post Share on other sites More sharing options...
Bigtoothpick 3rd Gear June 20, 2007 Author Share June 20, 2007 if thread not asymmetrical, any reason why should not dismount tyre from rim. i mean other than costs i guess Link to post Share on other sites More sharing options...
Kklee 6th Gear June 20, 2007 Share June 20, 2007 I think it's ok to remove the tyre from the rim.... tyre puncture repair, also the same. Link to post Share on other sites More sharing options...
Kb27 Supersonic June 20, 2007 Share June 20, 2007 Ok, I see what you mean. If you are just moving directional (symmetrical thread) tyres from left to right without moving the rims, it seems to be ok. Except maybe some tyres have marking that says inner side, would then become "outer" after the swap. I'm not sure what's the effect if any. I guess it depends on the way the tyre is manufactured, whether extra strengthening goes to "outer" side or not. I think just rotate front/back is good enough. Just make sure the wheel alignment is correct is more important. Link to post Share on other sites More sharing options...
Kklee 6th Gear June 20, 2007 Share June 20, 2007 Hmm... just thought of it, if the thread design is symmetrical, wouldn't the tyres be non-directional? Link to post Share on other sites More sharing options...
Bigtoothpick 3rd Gear June 20, 2007 Author Share June 20, 2007 mmmmm... i don't think so. If symmetry is between the two sidewalls (i.e. line along centre of tyre width), but the thread design is not the same along direction of rotation, e.g. W-shaped will become M-shaped the other way, then tyre is still directional... Link to post Share on other sites More sharing options...
Coupe07 Neutral Newbie June 20, 2007 Share June 20, 2007 thread starter says remove tyres from rims to swop left n right... this is the most economical way. Front to back, slight diffeerence only Link to post Share on other sites More sharing options...
Kklee 6th Gear June 20, 2007 Share June 20, 2007 Agree...miss out on that. Link to post Share on other sites More sharing options...
Scaglietti Neutral Newbie June 20, 2007 Share June 20, 2007 IMO, if your car alignment is good, there is not much benefit from cross swapping your directional tyres. I would not spend the $$ to dismount, re-mount and rebalance the tyres. BC Link to post Share on other sites More sharing options...
Kklee 6th Gear June 20, 2007 Share June 20, 2007 Even with proper alignment, if parked at MSCP in higher floors, usually the front left tyre outer edge will experience more wear. If the rims are upsizes and tyres are expensive, the effort and $$$ would not be wasted. Link to post Share on other sites More sharing options...
Eyke Supercharged June 20, 2007 Share June 20, 2007 depends on the car you drive. for cars with significant negative camber, eg. Focus, will result in more inner edge wear for tyres and would benefit from a "X" rotation. if you just do front to back, the inner edges will always be the inner edges and will worn out long before the outer edges. ↡ Advertisement Link to post Share on other sites More sharing options...
Portable Tyre Pump
Portable Tyre Pump
Petlas Or Giti?
Petlas Or Giti?
Tyre puncture
Tyre puncture
Continental CSC 7.
Continental CSC 7.
