Shull Turbocharged June 6, 2007 Share June 6, 2007 Just now went to check on my spare tyres and top up air(if needed)..saw the pressure..420kPa..wu ya boh? thats double of what we usually pump in normal tyres leh leh.. any idea what makes spare tyres need so high a pressure? ↡ Advertisement Link to post Share on other sites More sharing options...
Latioboy 1st Gear June 6, 2007 Share June 6, 2007 i thought the spare tyres are kept in the compartment for dunno how long.. so maybe its set at 420 .. and since tyres naturally deflate by themselves, so.. by the time you use them, at least its not too under inflated... Link to post Share on other sites More sharing options...
Mach Clutched June 6, 2007 Share June 6, 2007 Space saver spare is it ? These need much higher pressure as they are much skinnier. Link to post Share on other sites More sharing options...
Boyboy 1st Gear June 7, 2007 Share June 7, 2007 Pressure = force over area. for those space-saving spare tyre, smaller area (contact patch), but force need to be the same (still support the weight of the car).. so pressure higher i use a bicycle pump to pump my spare.. cos the volume is small, and the pressure so high, i dun quite trust the kiosk pump to handle it. bike pump can handle more than twice the max pressure of petrol kiosk pump.. Link to post Share on other sites More sharing options...
Boyboy 1st Gear June 7, 2007 Share June 7, 2007 ur explanation is wrong like that can pump ur normal tyre harder, so can pump less often? actually i used to do that Link to post Share on other sites More sharing options...
Shull Turbocharged June 7, 2007 Author Share June 7, 2007 petrol kiosk pump can handle until 415kPa..that is 5kPa short of the recommended pressure.. Link to post Share on other sites More sharing options...
Fitvip Supersonic June 7, 2007 Share June 7, 2007 Pump up to 415 and blow the last 5 to make up! Link to post Share on other sites More sharing options...
Boyboy 1st Gear June 7, 2007 Share June 7, 2007 wha.. that's worse than i thought.. actually, i pump my spare higher than recommended pressure.. cos i know i wun take it out for a few months the old style pumps can pump higher than the digital pumps. at least the gauge goes higher . but i wun take the risk. Link to post Share on other sites More sharing options...
Octopus 3rd Gear June 8, 2007 Share June 8, 2007 i use a bicycle pump to pump my spare.. cos the volume is small, and the pressure so high, i dun quite trust the kiosk pump to handle it. bike pump can handle more than twice the max pressure of petrol kiosk pump.. Huh? bicycle pump can pump till so high pressure??? Need alot of effort or not? Perhaps I might consider getting a bicycle pump and keep in back booth for emergency case..... Link to post Share on other sites More sharing options...
Boyboy 1st Gear June 9, 2007 Share June 9, 2007 (edited) can. bike tyres need way higher pressure. 420kpa (max for new digital pump) works out to abt 60 PSI. most decent bike tyre pumps can take up to 120 PSI. i also have an air suspension pump. it reads 300psi max.. but so far i only need up to 165PSI for emergency use, get a fix a flat and portable compressor pump types.. the bike pump is pretty useless other than to keep space saving spares inflated. EDIT: effort is not a lot, but takes a long time . for normal tyre that is.. for my spare tyre, to pump up from 40PSI to 60 PSI takes abt 5 min. quite ok Edited June 9, 2007 by Boyboy Link to post Share on other sites More sharing options...
Fcw75 Hypersonic June 9, 2007 Share June 9, 2007 Yes, Honda space saving tyre must pump to 420kPa. You go to the digital pump at Shell station, they can go much higher than 420kPa. The ones at Esso/Mobil cannot, maximum 415kPa only. Not sure about Caltex or SPC. Link to post Share on other sites More sharing options...
Rally1000 Neutral Newbie June 9, 2007 Share June 9, 2007 i use a bicycle pump to pump my spare.. cos the volume is small, and the pressure so high, i dun quite trust the kiosk pump to handle it. bike pump can handle more than twice the max pressure of petrol kiosk pump.. Bro can recommend the brand of pump you use? Link to post Share on other sites More sharing options...
Boyboy 1st Gear June 10, 2007 Share June 10, 2007 use shell digital pump la, as bro FCw75 has recommended i'm using parktool floor pump. but not cheap. abt 40+ ↡ Advertisement Link to post Share on other sites More sharing options...
SPARE PARTS LIST
SPARE PARTS LIST
Any recommended tyre shop
Continental CSC 7.
Continental CSC 7.
Tyre puncture
Tyre puncture
Tyre Rotation and balancing
Continental closing Alor Setar plant
