Sickscientist Clutched June 3, 2007 Share June 3, 2007 I've seen cars which have wider rear wheels... What advantage does it have?? Was thinking how do they do rotation when sizes are different.... ↡ Advertisement Link to post Share on other sites More sharing options...
Weihui Clutched June 3, 2007 Share June 3, 2007 Those cars you have seen mostly are rear wheel drive I guess. For FWD it won't do any good. Only make your car heavier and understeer more. Link to post Share on other sites More sharing options...
Daryl_lum Neutral Newbie June 3, 2007 Share June 3, 2007 Don't think there's any use in having differing sizes. just some weird myth again... Link to post Share on other sites More sharing options...
Coupe07 Neutral Newbie June 3, 2007 Share June 3, 2007 its not a myth.... its a "privilege" for rear wheel drive cars..... Link to post Share on other sites More sharing options...
Otsego Clutched June 3, 2007 Share June 3, 2007 yea, The Nissan Fairlady and Merc SLK both the rear wheels are wider then front but i wonder how they do wheel rotation Link to post Share on other sites More sharing options...
Furrynadz 5th Gear June 3, 2007 Share June 3, 2007 balancing is a must rotation is not Link to post Share on other sites More sharing options...
Bulls_is_back 1st Gear June 3, 2007 Share June 3, 2007 they don't ,,, but actually If the tyre is non directional, just swap left to right and vice versa If the tyre is directional, they can still take off tyres and swap L to the R side. For the Asymetrical thread pattern tyres, then lan lan lor. Link to post Share on other sites More sharing options...
Otsego Clutched June 3, 2007 Share June 3, 2007 ok what about FF cars? do their front tyre wider then rears? Link to post Share on other sites More sharing options...
Bulls_is_back 1st Gear June 3, 2007 Share June 3, 2007 They usually don't. The whole idea of FF is to get safe understeer. You might want wider front than rear only if you know what you are doing. What about putting spacers in front so that the front wheels is wider apart compared to the rear. Then put some front strut bars/fender bars/lower bars to stiffen everything up in front. That will be interesting :) Link to post Share on other sites More sharing options...
Yc86 Clutched June 3, 2007 Share June 3, 2007 Won't having a stiffer front than the rear induce more understeer? Link to post Share on other sites More sharing options...
Yc86 Clutched June 3, 2007 Share June 3, 2007 FF drag cars usually have wider tyres in the front, for more traction.. not sure if a car with a wider track on the front will have any handling problems though. Link to post Share on other sites More sharing options...
Liping24 Neutral Newbie June 4, 2007 Share June 4, 2007 wider rear wheels....cannot do rotation. They are rich to just replace the tyres when time comes. Tyre rotations are to maximise the tyres usefulness. Link to post Share on other sites More sharing options...
Bulls_is_back 1st Gear June 4, 2007 Share June 4, 2007 Balance out the extra grip.... maybe Link to post Share on other sites More sharing options...
Ahbengdriver 6th Gear June 4, 2007 Share June 4, 2007 (edited) Its for RWD cars where the power is sent to the rear wheels to take advantage of the torque and acceleration, otherwise wheel may spin. Wider wheels = more rubber contact so takes advantage of the power which is otherwsie wasted. See Formula One cars? Of cos if yr car has not enuf power and not RWD u dont need staggered tyres Edited June 4, 2007 by Ahbengdriver Link to post Share on other sites More sharing options...
oomph Neutral Newbie June 4, 2007 Share June 4, 2007 no rotation or switch L-R if thread design permits. a number of 350Zs and Beemers have this configuration on the streets of the lion city. Link to post Share on other sites More sharing options...
Cupid Neutral Newbie June 4, 2007 Share June 4, 2007 Quote yea, The Nissan Fairlady and Merc SLK both the rear wheels are wider then front but i wonder how they do wheel rotation Mitsubishi i also like that leh Link to post Share on other sites More sharing options...
Bulls_is_back 1st Gear June 4, 2007 Share June 4, 2007 I believe the i has a RMR layout. The wider rears is there to compensate the rear weight bias. Link to post Share on other sites More sharing options...
Sickscientist Clutched June 4, 2007 Author Share June 4, 2007 Thanks all for the clarification... Now I have a better understanding on cars with wider rear track... Cheers...! ↡ Advertisement Link to post Share on other sites More sharing options...
Washing machine front loading
