Power window unable to close fully
Jackfoo
bros,
whenever i press the power window to close; it move for about 3/4 up & suddenly move down by itself.
sometime the solution is to press & hold the button till it fully close or by pressing the power window button sereral times.
able to advise which part give way already??
thanks [sunny][sunny][sunny]
motor is gg up lorry. the load of the window is too much for ur window. torque probably decreased due to carbon buildup in motor stator.
is it possible to convert power window to the mechanical ones?
Mechanical one seems more feasable for those who frequently open/close windows, yet lighter and less things to go wrong.. [rolleyes]
actually it is running on worm track motor so it is mechanical in a way. but if u talk abt winding arms, it's kinda weird and wun b chirp. do a 1 for 1 replacement and make sure the window slides up in proper alignment.
mmm.. nt really weird for a coe car. Since most ppl are looking for power windows
can't think of any disadvantage besides the inconvinience. sealing wise should still be the same..
I occasion will have heavy knocking sound when I wind down the window from the driver side wonder if this will affect my locking mechanism which at time also give me problem.
bros,
maybe the window not so power lor.... change it to 'not so power window'
Not sure what car you are driving but I had the same problem. If you observe the movement, it seems to be stuck at a certain point where the window is not rolled up evenly. I had the AD rectify it where they lube the window mechanism. Still observing whether if it fixed the problem.
Same as mine.
Lucky I only have this problem of not able to wind down window fully. Left about 5% cannot go down. Resolved after my last servicing at Jurong Service Centre.
Other than that, everything's ok.
If your ride is still under warranty, bring it back to Kah Motors and let them take a look. Better than guessing here what's wrong. [:)]
Look for SA Wong at Jurong Service Centre.
