Jackfoo 1st Gear May 30, 2007 Share May 30, 2007 bros, whenever i press the power window to close; it move for about 3/4 up & suddenly move down by itself. sometime the solution is to press & hold the button till it fully close or by pressing the power window button sereral times. able to advise which part give way already?? thanks ↡ Advertisement Link to post Share on other sites More sharing options...
Ccssgm 1st Gear May 30, 2007 Share May 30, 2007 The Rubber Bush at the Gear..... Link to post Share on other sites More sharing options...
Jackfoo 1st Gear May 30, 2007 Author Share May 30, 2007 how much this thing (rubber bush) cost? thanks Link to post Share on other sites More sharing options...
Apollo 1st Gear May 30, 2007 Share May 30, 2007 motor is gg up lorry. the load of the window is too much for ur window. torque probably decreased due to carbon buildup in motor stator. Link to post Share on other sites More sharing options...
Yc86 Clutched May 30, 2007 Share May 30, 2007 is it possible to convert power window to the mechanical ones? Mechanical one seems more feasable for those who frequently open/close windows, yet lighter and less things to go wrong.. Link to post Share on other sites More sharing options...
Watwheels Supersonic May 30, 2007 Share May 30, 2007 Apply some lubricant on the grooves where the window is travelling up or down. Link to post Share on other sites More sharing options...
Ccssgm 1st Gear May 31, 2007 Share May 31, 2007 If Yours Is Orginal Install must go back to the Workshop...... Link to post Share on other sites More sharing options...
Apollo 1st Gear May 31, 2007 Share May 31, 2007 actually it is running on worm track motor so it is mechanical in a way. but if u talk abt winding arms, it's kinda weird and wun b chirp. do a 1 for 1 replacement and make sure the window slides up in proper alignment. Link to post Share on other sites More sharing options...
Yc86 Clutched June 2, 2007 Share June 2, 2007 mmm.. nt really weird for a coe car. Since most ppl are looking for power windows can't think of any disadvantage besides the inconvinience. sealing wise should still be the same.. Link to post Share on other sites More sharing options...
Evilernie 4th Gear June 13, 2007 Share June 13, 2007 I occasion will have heavy knocking sound when I wind down the window from the driver side wonder if this will affect my locking mechanism which at time also give me problem. Link to post Share on other sites More sharing options...
Evildoer Neutral Newbie June 13, 2007 Share June 13, 2007 bros, whenever i press the power window to close; it move for about 3/4 up & suddenly move down by itself. sometime the solution is to press & hold the button till it fully close or by pressing the power window button sereral times. able to advise which part give way already?? thanks maybe the window not so power lor.... change it to 'not so power window' Link to post Share on other sites More sharing options...
Jackfoo 1st Gear June 13, 2007 Author Share June 13, 2007 what talk u?? u want me to or or or ??? or or u?? Link to post Share on other sites More sharing options...
Aspri Clutched June 13, 2007 Share June 13, 2007 Not sure what car you are driving but I had the same problem. If you observe the movement, it seems to be stuck at a certain point where the window is not rolled up evenly. I had the AD rectify it where they lube the window mechanism. Still observing whether if it fixed the problem. Link to post Share on other sites More sharing options...
Nutty 4th Gear June 13, 2007 Share June 13, 2007 What's your ride? Link to post Share on other sites More sharing options...
Jackfoo 1st Gear June 13, 2007 Author Share June 13, 2007 bros, my ride is honda civic ES5. Link to post Share on other sites More sharing options...
Nutty 4th Gear June 13, 2007 Share June 13, 2007 Same as mine. Lucky I only have this problem of not able to wind down window fully. Left about 5% cannot go down. Resolved after my last servicing at Jurong Service Centre. Other than that, everything's ok. Link to post Share on other sites More sharing options...
Nutty 4th Gear June 13, 2007 Share June 13, 2007 If your ride is still under warranty, bring it back to Kah Motors and let them take a look. Better than guessing here what's wrong. Look for SA Wong at Jurong Service Centre. Link to post Share on other sites More sharing options...
Alexchoo Neutral Newbie June 13, 2007 Share June 13, 2007 reset the power window? ↡ Advertisement Link to post Share on other sites More sharing options...
Window grill lock
Window grill lock
Home power back up
Home power back up
Alcades power optimizer
Home window - Sliding or casement?
STEK NEX Series Carbon Ceramic with Graphene Window Tint
