Mean76 1st Gear May 17, 2007 Share May 17, 2007 Hi all, I am driving a Terios Auto for a month liao. Generally, I am happy with the pick up (I know the pick up is damn slow but still acceptable) But I am more concerned with the overall speed and RPM. When I'm driving 80-90kmh, the RPM is around 2300~2500 The moment I hit 100kmh, the RPM is 3000 and above. I heard from my colleague that his Fit hits only RPM 2500 when he's at 110kmh Is there any legal mod to increase the speed to 110kmh and still maintain a reasonable RPM around 2500-3000? I tried being light footed but in vain. Oh yeah, I drove a manual previously so I'm a crap with autos BTW, the specification as shown below. Engine type 3SZ, inline 4-cylinder, 16-valve DOHC, DVVT Total displacement cc 1,495 Bore x stroke mm 72.0 x 91.8 Max. output kW/rpm 77/6,000 Max. torque Nm/rpm 140/4,400 Compression ratio 10 Fuel system EFI (Electronic Fuel Injection) Fuel tank capacity litres 50 4 A/T 1st: 2.731, 2nd: 1.526, 3rd: 1.000, 4th: 0.696, Rev.: 2.290 Final reduction gear ratio 4 A/T 4WD: 5.571 Tyres 215/65R16 Fuel consumption 4 A/T L/100km 8.0 8.4 CO2 emission 4 A/T g/km 188 196 ↡ Advertisement Link to post Share on other sites More sharing options...
BoneStock 5th Gear May 17, 2007 Share May 17, 2007 it is not possible to change your rpm at a certain speed because the gear ratios and the final drive ratio are fixed. just enjoy your ride Link to post Share on other sites More sharing options...
Mean76 1st Gear May 17, 2007 Author Share May 17, 2007 damn ... should have gotta a manual ... Link to post Share on other sites More sharing options...
BoneStock 5th Gear May 17, 2007 Share May 17, 2007 manual doesnt mean the rpm will not be high at a certain speed. same still applies i.e. the gear ratios and final drive ratio. Unless you change the gearbox or the final drive... My previous Honda's ride also has higher rpms than normal. At 100kph, the rpm was ~2.7~2.8k if I can still recall. Other than this, the ride was very enjoyable...very torquey, FC very good too. Link to post Share on other sites More sharing options...
Roadhogger 2nd Gear May 17, 2007 Share May 17, 2007 hi..the RPM at 90kph should be around 2600 to 2700rpm...the gear ratio should be fixed. Check out www.rushteriosclub.com. There is guys that claims after doing some grounding the RPM becomes 2100 . I am very . Link to post Share on other sites More sharing options...
Watwheels Supersonic May 17, 2007 Share May 17, 2007 Unless u change your gearbox, it cannot be changed. But u can try your luck on the sponsor's little red box(I'm not the salesman ), it may or may not work well. IMO the 4 speed AT is a bit outdated. They should have the 5speedAT to make it more respondsive to drive and the final gear to run at lower rpm to make it more FC friendly. If your car does not have electronic controlled throttle, being light footed have little effect. ↡ Advertisement Link to post Share on other sites More sharing options...
Daihatsu admit tampering with safety tests for 30 years
Daihatsu Owners
Daihatsu Owners
Daihatsu Charade with Le Mans livery?
[Official] 2020 Toyota Raize / Daihatsu Rocky / Perodua Ativa / Subaru Rex
Daihatsu Extol
Daihatsu Extol
Daihatsu Materia/Toyota bB
Daihatsu Unveils Adorable, Quirky Custom Cars For 2021 Tokyo Auto Salon
Daihatsu Copen
Daihatsu Copen
