oomph Neutral Newbie May 7, 2007 Share May 7, 2007 thinking of ditching my spare tyre (odyssey) and get one of those canned puncture sealants. i understand that these do help inflate the tyre and seal it temporarily, but wonder if anyone here got experience using this can give a review, particularly for the following: - how long can the sealant last ? - can the puncture be serviced the regular way (plugs/patch) and reused or is that prohibited ? - storing the can itself - how long before it expires and doesn't work ? I'm in favour for replacing the spare tyre with 2 cans of puncture sealants and a fire extinguisher AND a 4-channel amplifier :) ↡ Advertisement Link to post Share on other sites More sharing options...
Tarzan666 2nd Gear May 7, 2007 Share May 7, 2007 i bought the can at lim ah boy..at kelantan lane ther..1 can $7...bear in mind if tear is 2 wide...it will nt be able 2 fill up.. oso the can does not have enuf air 2 pump whole tyre.i bought a portable air compressor frm carrefour 2 supplement it.. expiry check the can lah... Link to post Share on other sites More sharing options...
Brock 1st Gear May 7, 2007 Share May 7, 2007 If I'm not mistaken, Gad still has one in his car for a longggg while already. I have one for the past year. Still no rupture or explosion or leaks. From what I know (I haven't personally experienced it yet), after using it, one should go to the tyre shop to get the punctured tyre replaced. The rims should also be cleaned of the stuff that was filled by the canister sealant, lest the rims get damaged by the chemicals. The stuff inside actually hardens up and seals up the puncture. I don't think the tyre can be reused due to the hardened substance coating the tyre. Link to post Share on other sites More sharing options...
oomph Neutral Newbie May 7, 2007 Author Share May 7, 2007 wah then its quite expensive - result is to change 2 tires right for proper 'matching' ? Link to post Share on other sites More sharing options...
Gadgeter 2nd Gear May 8, 2007 Share May 8, 2007 [reply] If I'm not mistaken, Gad still has one in his car for a longggg while already. I have one for the past year. Still no rupture or explosion or leaks. From what I know (I haven't personally experienced it yet), after using it, one should go to the tyre shop to get the punctured tyre replaced. The rims should also be cleaned of the stuff that was filled by the canister sealant, lest the rims get damaged by the chemicals. The stuff inside actually hardens up and seals up the puncture. I don't think the tyre can be reused due to the hardened substance coating the tyre. Bro, Your memory serve you well. Yes, I have 1 in my car. Used it and replenished it. If the punctured is too wide, then the sealant will not helped much. Below are my experience of which I 'managed' to use the can which I have kept in the boot for almost a year. Findings: 1 Can is enough to pump 1 tyre (Assuming it is the same brand we are referring). When you drive to the workshop to patch up the tyre, make sure you ask the mechanic to remove the tyre from the rim so that he can remove the chemical in the tyre. My Experience: Managed to drive my car to the tyre shop to patch up the hole. But the mechanic had a hard time trying to fix it as the chemical have harden within the tyre. Drove off after the patch job. After a few days, realised my car car have slight vibration. Tried a few rounds of balancing but the tyre dun seems to be able to balanced. Went to another workshop, after a few try (still cannot balance) the mechanic asked if I had pumped any chemical into the tyre. It was the chemical the causes the vibration as the tyre are not balanced. The Chemical also causes the internal paint work of the rim to corrode as it was left inside for more than 1 month. Hope the above info helps. Link to post Share on other sites More sharing options...
Brock 1st Gear May 8, 2007 Share May 8, 2007 Well, largely it depends on you. If you've got $ to spare, change both left and right tyres. I'm not sure whether Gad did manage to change his repaired tyre after xxx days/weeks/months, but for me, I would rather change both. The wheels are the only thing separating you and the road. If the tyres are pretty brand new, then you may wanna consider using it till it's time to change but of course do careful monitoring. Gad: Did you eventually replace that tyre or you are still driving with it? Link to post Share on other sites More sharing options...
Mach Clutched May 8, 2007 Share May 8, 2007 Has anyone tried this tyre sealant product - sounds great, but does it really work ? http://www.activeproduct.biz/ Link to post Share on other sites More sharing options...
Yeobh 4th Gear May 11, 2007 Share May 11, 2007 Suggest yr jack up the car, so that it is easier for the can.Even 12volt tyre pump will find it very strenuous to inflate the tyre from ground up unless yr have the heavy duty type that generate very high air pressure of 350psi at low volume.Most of the 12volt elect air pump sold in supermarket or petrol kioks are just good for inflating beachballs and floats. Link to post Share on other sites More sharing options...
Yeobh 4th Gear May 11, 2007 Share May 11, 2007 (edited) I am not sure about this brand, but similar products were introduced into the Spore marketplace about a decade ago but just fail to make any mark. The reason is the semi liquid tend to creat unnecessary forces resulting in wheel unbalance at high speed. Edited May 11, 2007 by Yeobh Link to post Share on other sites More sharing options...
oomph Neutral Newbie May 12, 2007 Author Share May 12, 2007 2 clear issues: 1. rim corrosion - is this just surface reaction of something deeper ? 2. unbalanced tire - this is probably more dangerous overall... possibly good for commercial vehicles and taxis rather than "performance" personal rides I suppose. Link to post Share on other sites More sharing options...
oomph Neutral Newbie May 12, 2007 Author Share May 12, 2007 (edited) EDIT - MORE DETAILS OF THE PRODUCT POSTED ABOVE http://www.ride-on.com/prod_plt.asp Ride-On Tire Protection System (TPS) Passenger & Light Truck (PLT) tire sealant formula is designed for use in cars and light trucks operating at speeds in excess of 30 miles per hour (50 km/h). The PLT formula will seal punctures in tubeless tires from perforating objects up to 1/8" in diameter that enter the tread area of the tire. The PLT formula should be used for light trucks and cars that are expected to travel at highway speeds and where tire balance is of concern. Ride-On TPS PLT formula is the only product that has been independently tested by the world's leading DOT approved tire testing facility to not affect tire balance when tested on a dynamic tire balancer. Ride-On TPS PLT formula is the only tire sealant in the world that allows a tire that it has been installed in to be re-balanced if necessary on a dynamic tire balancer. NO OTHER SEALANT CAN MAKE THAT CLAIM! Edited May 12, 2007 by oomph Link to post Share on other sites More sharing options...
Brock 1st Gear May 12, 2007 Share May 12, 2007 That's why it's more advisable to drive to nearest tyre shop, get it cleaned and 'wormed'. Got $$$, buy new ones instead. Link to post Share on other sites More sharing options...
Aucsl Neutral Newbie July 31, 2007 Share July 31, 2007 Hi, anyone tried the above product? What is the pro & con? Thinking to install it on my next tire replacement. Link to post Share on other sites More sharing options...
Ysc3 Twincharged February 26, 2008 Share February 26, 2008 hi ! just wondering if you have done the TPS treatment for your tires ? Link to post Share on other sites More sharing options...
Kevin_teutonictech Neutral Newbie January 6, 2012 Share January 6, 2012 Guys, I've tried this and it works. It's called Slime Spair Tyre Kit. http://www.slime.com/shop/smart-spair-15-minute-emergency-tire-repair-ss-pdq06/ Here's a video to check out: With this, you don't even have to get your punctured tyre replaced/repaired by going to a workshop. Saves so much time and money. Interested parties contact me directly at 9.8.2.2.2.0.0.4. I have a contact who distributes it! Cheers to no more tyre puncture problems! Link to post Share on other sites More sharing options...
Willismith Neutral Newbie January 10, 2012 Share January 10, 2012 There has been some in fact, but I've not had a full answer yet so I need to clarify some more. Bridgestone has already said that it doesn't recommend repairing Z rated tyres at all anyway, but that a lot of tyres (not just their own) have spiral wound belts and damage to them could compromise the tyre's strength. Link to post Share on other sites More sharing options...
Good-Carbuyer 1st Gear January 10, 2012 Share January 10, 2012 thinking of ditching my spare tyre (odyssey) and get one of those canned puncture sealants. i understand that these do help inflate the tyre and seal it temporarily, but wonder if anyone here got experience using this can give a review, particularly for the following: - how long can the sealant last ? - can the puncture be serviced the regular way (plugs/patch) and reused or is that prohibited ? - storing the can itself - how long before it expires and doesn't work ? I'm in favour for replacing the spare tyre with 2 cans of puncture sealants and a fire extinguisher AND a 4-channel amplifier :) Can know whats wrong with the spare tyre? If 2 tire flat at the same time and you got a spare tyre, you still got hope of driving home, if you know how? Link to post Share on other sites More sharing options...
Roberttan 5th Gear January 11, 2012 Share January 11, 2012 those sealant had been here in the last 2 decades, and NO one can sustain the business long. due to wheel balacing problem. Just remember ,after you pump in the liquid you still the the tyre to be repair from inside at the same time remove all those chemical but i think the tyre mech will show you some unhappiness due to very strong smelly chemical and spill , if you are kind tell them befor they remove ↡ Advertisement Link to post Share on other sites More sharing options...
Any recommended tyre shop
Continental CSC 7.
Continental CSC 7.
Tyre puncture
Tyre puncture
Tyre Rotation and balancing
Continental closing Alor Setar plant
