Steering wheel locked, unable to start ignition
Cumzilla
just now experience for the 1st time unable to turn my key to igniton due to locking of my steering wheel, only after turning my steering wheel abit then i am able to turn the key, what causes this to happen?
umm... normal? it's a steering lock, as in, security function for you to lock your steering when you turn off the engine.
someone correct me if i'm wrong.
can you turn your steering wheel without the key inserted btw?
Edited by Karebu
correct me if wrong..sometimes due to steering not back to original position e.g your wheels not straight, turning other direction when engine off.
look at ur ignition there.. got Lock - Off - On - Start..
when u leave ur car in Lock.. the steering wheel is locked..
if u accidentally shift the wheel, ur key either cannot take out or cannot turn to Start..
this is what i experienced though.
security locking lah.. just turn the ignition key 1 click (not to the full) and then the steerling will release.
bro the problem is the other way round, i cant turn the key to ignite, not i want to unlock the wheel
try turning your steering more (it has abit of allowance to turn even though it's locked) before you put your key.
turn your key and your steering should 'come free'.
that was what i did, i just want to know what causes that to happen, probably bros Celicapimp and Nhrisuzu had answered that query...just hope that its not a problem with the ignition lock cylinder
Edited by Cumzilla
it's a security function to deter those hot-wiring-car-jacking thieves cannot straighten/adjust the steering without the key and the car would go in circles.
erh. depends on your car. some steerings lock:
-turn steering wheel abit after you take out key
-turn steering wheel more than a 'T' after you take out the key
-ignition set to lock
-etc..
hope i've answered your qn
I kena before..I tried to turn steering left and right abit while trying to start ignition with key till it's "loosen" then i can start ignition liao
it cud b a manufacture fault. happens to 03 colt before.
try not to insert the key too deep and play about. another possibility is u cud b using a duplicate key which is not set nicely.
Hi Cumzilla. There is nothing wrong with your ignition lock at all. Like mentioned by Karebu, this is a basic security feature that most of us did not bother about it. Even if thief were to go into the car, using the shocking method of the two wires to start the car, they won't be able to rotate the wheel, so that will prevent them from driving away unless their get away route is all the way straight.
We guys are so used to the wireless remote security that we have all forgotten about the basic car security.
turn the steering wheel slightly to release the pressure
acting on the locking pin and u wud be able to turn the key
this is very normal
Don't worry, its just the standard factory steering lock.
Simply apply pressure to the wheel while turning the key.
No problems at all. [:)]
If you didn't position the steering wheel to the lock position, and "force" the steering wheel to lock in position, it would be more difficult to unlock the wheel.
Just rock the wheel until it frees from the lock.
Its normal.
After you have pulled out your key, you might touch or move your steering.
Because you don't have a key it, it will lock and shutoff the ignition.
Happen freq since my car is low, and would touch the steering unintentionally when getting in and out of car.
